<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[help,i broke the mirror]]></title><description><![CDATA[<p dir="auto">i’ve spent days getting my display how i want it,i deided to add a couple more modules-mmm-formula1 and mmm-googletasks and when i restarted i got the black electron screen,i went back to my last working config-still the same.<br />
ssh into pi, try npm start and this is the output-</p>
<p dir="auto">magicmirror@2.9.0 start /home/pi/MagicMirror<br />
sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a></p>
<p dir="auto">Starting MagicMirror: v2.9.0<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
No helper found for module: clock.<br />
No helper found for module: worldclock.<br />
No helper found for module: MMM-DumpsterDay.<br />
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘node_helper’<br />
App threw an error during load<br />
at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)<br />
at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)<br />
at Function.Module._load (internal/modules/cjs/loader.js:528:25)<br />
at Module.require (internal/modules/cjs/loader.js:658:17)<br />
at require (internal/modules/cjs/helpers.js:20:18)<br />
at Object. (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:18)<br />
at Object. (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:81:3)<br />
at Module._compile (internal/modules/cjs/loader.js:711:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)<br />
at Module.load (internal/modules/cjs/loader.js:620:32)<br />
Whoops! There was an uncaught exception…<br />
{ Error: Cannot find module ‘node_helper’<br />
at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }<br />
MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
Launching application.</p>
<p dir="auto">i’ve searched for similar problems but not found the answer and i’m conserned about doing more damage1<br />
please help! aaarrrggghhh</p>
]]></description><link>https://forum.magicmirror.builders/topic/11592/help-i-broke-the-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 08:03:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11592.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Nov 2019 07:09:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to help,i broke the mirror on Thu, 14 Nov 2019 09:11:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blauenfeldt" aria-label="Profile: Blauenfeldt">@<bdi>Blauenfeldt</bdi></a><br />
wooohoo,<br />
awesome,<br />
that worked,<br />
thankyou,<br />
relief…</p>
]]></description><link>https://forum.magicmirror.builders/post/64417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64417</guid><dc:creator><![CDATA[mrdenmark]]></dc:creator><pubDate>Thu, 14 Nov 2019 09:11:05 GMT</pubDate></item><item><title><![CDATA[Reply to help,i broke the mirror on Thu, 14 Nov 2019 09:03:07 GMT]]></title><description><![CDATA[<p dir="auto">Someone got it working on this post:<br />
<a href="https://forum.magicmirror.builders/topic/11554/magicmirror-won-t-start-after-installing-module/6">https://forum.magicmirror.builders/topic/11554/magicmirror-won-t-start-after-installing-module/6</a><br />
hope this helps</p>
]]></description><link>https://forum.magicmirror.builders/post/64416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64416</guid><dc:creator><![CDATA[Blauenfeldt]]></dc:creator><pubDate>Thu, 14 Nov 2019 09:03:07 GMT</pubDate></item></channel></rss>
