<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Sonos no Artwork]]></title><description><![CDATA[<p dir="auto">Hi, does anybody know why the Module is not shown artwork wenn I play music from Apple Music or Amazon music?</p>
<p dir="auto">only Radio works…</p>
]]></description><link>https://forum.magicmirror.builders/topic/11593/mmm-sonos-no-artwork</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 23:26:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11593.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Nov 2019 07:35:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Sonos no Artwork on Fri, 15 Nov 2019 07:24:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bd0g" aria-label="Profile: BD0G">@<bdi>BD0G</bdi></a> ok thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/64474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64474</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Fri, 15 Nov 2019 07:24:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Sonos no Artwork on Fri, 15 Nov 2019 00:16:36 GMT]]></title><description><![CDATA[<p dir="auto">I have installed snille’s version as well. I can get the output via a webpage using “ipaddress of Pi”:5005/zones</p>
<p dir="auto">This is only after switching to the node-sonos-http-api directory and then running npm start. If I close the console window it stops providing that information to the webpage.<br />
If I run the <a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a> file that just changes to the node-sonos-http-api directory and does a Display=0: npm start then the data is not sent to the webpage. So I modified the <a href="http://sonos.sh" target="_blank" rel="noopener noreferrer nofollow ugc">sonos.sh</a> to just change to the node-sonos-http-api directory and do a npm start only without the Display=0:</p>
<p dir="auto">Still will not send the data to the webpage to check.</p>
<p dir="auto">So I figured I would do an npm start from the node-sonos-http-api directory and then use another console window to launch the MagicMirror. Still does not display what is playing on Sonos even though the data is displaying on the webpage to check it.</p>
<p dir="auto">My config comes back with no errors when using the linter. I just get multiple modules reporting “Loading” I have waited for 20 minutes and no load of modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/64460</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64460</guid><dc:creator><![CDATA[BD0G]]></dc:creator><pubDate>Fri, 15 Nov 2019 00:16:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Sonos no Artwork on Thu, 14 Nov 2019 16:40:27 GMT]]></title><description><![CDATA[<p dir="auto">Maybe it has to do with the css settings.<br />
I use snilles custom.css. Add his settings to your custom.css file and restart MM. You find them at the end of his <a href="http://Readme.md" target="_blank" rel="noopener noreferrer nofollow ugc">Readme.md</a></p>
]]></description><link>https://forum.magicmirror.builders/post/64430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64430</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Thu, 14 Nov 2019 16:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Sonos no Artwork on Thu, 14 Nov 2019 16:29:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> I have the snille module…</p>
]]></description><link>https://forum.magicmirror.builders/post/64429</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64429</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Thu, 14 Nov 2019 16:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Sonos no Artwork on Thu, 14 Nov 2019 11:59:33 GMT]]></title><description><![CDATA[<p dir="auto">Which Sonos-module are you using?<br />
There are actually two: One from CFenner and a fork from snille.<br />
I have the fork from snille installed (<a href="https://github.com/snille/MMM-Sonos" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/snille/MMM-Sonos</a>), which works with TuneIn Radio, my paid Spotify and Amazon Music account.<br />
Maybe you try snille’s fork, in case you have CFenner’s module?</p>
<p dir="auto">Best<br />
Fozi</p>
]]></description><link>https://forum.magicmirror.builders/post/64422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64422</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Thu, 14 Nov 2019 11:59:33 GMT</pubDate></item></channel></rss>
