<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together]]></title><description><![CDATA[<p dir="auto">Does anybody have a working config.js with MMM-Page-Selector &amp; MMM-CalendarExt2 working together that I can use as an example? I can get them working individually with other modules but not together.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/11635/config-js-example-of-mmm-page-selector-mmm-calendarext2-working-together</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 14:06:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11635.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Nov 2019 16:16:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Sun, 24 Nov 2019 17:04:49 GMT]]></title><description><![CDATA[<p dir="auto">I have it working but I don’t think you can do what you are trying to do in your config, CalendarExt2 overwrites everything so what I did was keep it in the same place on every page and then adjust the items around it. That is the only way to make it work - you can’t have it it one place on page one, try to change the view on page two</p>
<p dir="auto">Start with a simple two page rotation with all the same modules showing (in the same places). Make sure it shows as the pages rotate</p>
]]></description><link>https://forum.magicmirror.builders/post/65026</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65026</guid><dc:creator><![CDATA[lawrence_jeff]]></dc:creator><pubDate>Sun, 24 Nov 2019 17:04:49 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Wed, 20 Nov 2019 17:20:06 GMT]]></title><description><![CDATA[<p dir="auto">Address is set to localhost:</p>
<pre><code>address: "localhost"
<p dir="auto">The developer responded about the issue:</p>
<p dir="auto"><a href="https://github.com/eouia/MMM-CalendarExt2/issues/43" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-CalendarExt2/issues/43</a></p>
]]></description><link>https://forum.magicmirror.builders/post/64836</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64836</guid><dc:creator><![CDATA[Monty]]></dc:creator><pubDate>Wed, 20 Nov 2019 17:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Wed, 20 Nov 2019 17:02:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monty" aria-label="Profile: Monty">@<bdi>Monty</bdi></a> but u didn’t answer on address:  you answered on whitelist.</p>
<p dir="auto">if the address is ‘localhost’, then only apps on this same machine can connect<br />
whitelist is another problem.  leave it open until u solve the problems…</p>
<pre><code>	address: "", // Address to listen on, can be:
	port: 8080,
	ipWhitelist: [],
]]></description><link>https://forum.magicmirror.builders/post/64835</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64835</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Nov 2019 17:02:24 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Wed, 20 Nov 2019 16:57:10 GMT]]></title><description><![CDATA[<p dir="auto">I had the whitelist as [] which supposedly allows everything. I just changed it to this:</p>
<pre><code>ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
<p dir="auto">That works and I am able to browse localhost. I think it’s a different issue to you though because Ext2 still doesn’t show for me in the browser.</p>
]]></description><link>https://forum.magicmirror.builders/post/64834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64834</guid><dc:creator><![CDATA[Monty]]></dc:creator><pubDate>Wed, 20 Nov 2019 16:57:10 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Wed, 20 Nov 2019 16:29:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monty" aria-label="Profile: Monty">@<bdi>Monty</bdi></a> what is the setting in config.js for address:</p>
]]></description><link>https://forum.magicmirror.builders/post/64832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64832</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Nov 2019 16:29:20 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Wed, 20 Nov 2019 16:13:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keith" aria-label="Profile: Keith">@<bdi>Keith</bdi></a> Thanks for the response. I have tried with browser and even after allowing everything in the whitelist it still doesn’t allow connections via the browser (connection refused) Similar to other peoples experiences on the forum.</p>
<p dir="auto">I will raise an issue on the Github page and refer back to here.</p>
]]></description><link>https://forum.magicmirror.builders/post/64830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64830</guid><dc:creator><![CDATA[Monty]]></dc:creator><pubDate>Wed, 20 Nov 2019 16:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Wed, 20 Nov 2019 13:33:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monty" aria-label="Profile: Monty">@<bdi>Monty</bdi></a> I have the same problem with CalendarExt. Try viewing the mm using a browser, this caused my calendar to show up on mm and in the browser.  Not the answer but might lead you to a solution.</p>
<p dir="auto">Keith</p>
]]></description><link>https://forum.magicmirror.builders/post/64821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64821</guid><dc:creator><![CDATA[Keith]]></dc:creator><pubDate>Wed, 20 Nov 2019 13:33:36 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Tue, 19 Nov 2019 17:37:41 GMT]]></title><description><![CDATA[<p dir="auto">That’s quite handy, thanks. I don’t see any obvious issues in the logs. The only issues are related to OpenWeather long forecast and Electron running on an insecure port (nothing to do with this problem) Everything else seems fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/64775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64775</guid><dc:creator><![CDATA[Monty]]></dc:creator><pubDate>Tue, 19 Nov 2019 17:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Tue, 19 Nov 2019 17:20:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monty" aria-label="Profile: Monty">@<bdi>Monty</bdi></a> if you open the developers window, ctrl-shift-i on the mirror keyboard, select the tab labeled console, and scroll up, do you see any errors…</p>
<p dir="auto">you can also filter that console by placing part of the module name in the filter field  (ext for example)</p>
]]></description><link>https://forum.magicmirror.builders/post/64773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64773</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 19 Nov 2019 17:20:26 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Tue, 19 Nov 2019 17:16:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">So yes I have MMM-Page-Selector selector working fine. I created pages: {PageOne, PageTwo} etc and I have various modules displaying correctly one the pages One and Two (Weather, Internet connection status and some other modules) Everything works perfectly as expected.</p>
<p dir="auto">E.g.</p>
<pre><code>  {
    module: 'MMM-connection-status',
    header: "Internet Connection",
    position: 'top_right', // Or any valid MagicMirror position.
    pages: {"PageOne": "top_right"},
<p dir="auto">My problem is when I try and add MMM-CalendarExt2 calendars to one of the pages, nothing shows up. It’s just blank on the screen where the Ext2 calendar should show up but all the other modules still display fine.</p>
<p dir="auto">E.g. here is my Ext2 config (excuse the formatting)</p>
<pre><code>{
  module: 'MMM-CalendarExt2',
      rotateInterval: 0,
      updateInterval:600*100,
    calendars : [
        name: "My Calendar",
        url: '**removed***
        beforeDays: 6,
        afterDays: 6,
        scanInterval: 600*100
    views: [
        mode: "daily",
        slotCount: 1,
        filterPassedEvent: true,
//        position: "top_left",
        pages: {"PageOne": "top_left"},
        hideOverflow:false,
        maxItems: "9",
        mode: "daily",
        slotCount: 2,
//        position: "top_center",
        pages: {"PageTwo": "top_center"},
        fromNow:+1,
    scenes: [
]]></description><link>https://forum.magicmirror.builders/post/64771</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64771</guid><dc:creator><![CDATA[Monty]]></dc:creator><pubDate>Tue, 19 Nov 2019 17:16:06 GMT</pubDate></item><item><title><![CDATA[Reply to Config.js example of  MMM-Page-Selector &amp; MMM-CalendarExt2 working together on Tue, 19 Nov 2019 16:35:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monty" aria-label="Profile: Monty">@<bdi>Monty</bdi></a> so, you have to create a page (in page selector), and then put the CalendarExt2 module on that page, right?</p>
<p dir="auto">then you can show that page or some other page by selecting the page</p>
]]></description><link>https://forum.magicmirror.builders/post/64766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64766</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 19 Nov 2019 16:35:14 GMT</pubDate></item></channel></rss>
