<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mirror Black Screen - helpless]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I would like to apologize for my English in advance. But thanks to Google, it is understandable.</p>
<p dir="auto">My Mirror crashes after about 1 hour of running time. The screen stays black. I have already played it several times and only run with the standard modules. Additionally, I let the developer console show me.</p>
<p dir="auto">But after an hour he hangs up completely. The console gives no error, or crashes. I am really helpless at first what to do. Would you have an idea why it may be?</p>
<p dir="auto">Raspbian Buster</p>
<p dir="auto">MMM Verison 2.9</p>
<p dir="auto">Raspberry Pi3B+</p>
]]></description><link>https://forum.magicmirror.builders/topic/11679/mirror-black-screen-helpless</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 01:42:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11679.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Nov 2019 12:20:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mirror Black Screen - helpless on Wed, 27 Nov 2019 02:56:59 GMT]]></title><description><![CDATA[<ol>
<li>
<p dir="auto">Check your internet connection at the mirror. Several modules are set to update on the hour.</p>
</li>
<li>
<p dir="auto">Did you update your raspbian installation? Like so:</p>
</li>
</ol>
<pre><code>sudo apt update
sudo apt upgrade -y
<ol start="3">
<li>You may wish to allocate more memory to the graphics portion of the Raspberry Pi. Run <code>sudo raspi-config</code> and find the section that allocates memory to the graphics processing (I think it is under “advanced options”). I have mine set to 128 MB.</li>
</ol>
<p dir="auto">Good luck.</p>
]]></description><link>https://forum.magicmirror.builders/post/65178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65178</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 27 Nov 2019 02:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Black Screen - helpless on Wed, 27 Nov 2019 00:13:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/notch" aria-label="Profile: Notch">@<bdi>Notch</bdi></a> are you using pm2 to start/stop the mirror app?  if so, do</p>
<pre><code>pm2 logs
<p dir="auto">to dump out the logs</p>
]]></description><link>https://forum.magicmirror.builders/post/65168</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65168</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 27 Nov 2019 00:13:02 GMT</pubDate></item></channel></rss>
