<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Webcam for MM build?]]></title><description><![CDATA[<p dir="auto">Has anyone here added a camera to their Smart Mirror? I’ve seen camera MM modules and I’m wondering whether I should get a Raspberry Pi camera or if a USB Webcam will be ok since I could maybe use that as my microphone also for voice commands. Any insight/advice would be a great help. Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/11722/webcam-for-mm-build</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 22:43:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11722.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Dec 2019 05:39:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 02 Oct 2020 13:09:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bumrocks" aria-label="Profile: bumrocks">@<bdi>bumrocks</bdi></a> general rules</p>
<p dir="auto">the thing on the left of : does not need quotes</p>
<p dir="auto">if the thing to the right of : is a number or true/false, also does not need quotes</p>
<p dir="auto">if the thing to the right of : has letters in it, then it needs quotes, either kind are ok, but must be the same</p>
<p dir="auto">yes, if the monitor/tv has the ugly no signal/connection, then u want to use hide</p>
]]></description><link>https://forum.magicmirror.builders/post/82660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82660</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Oct 2020 13:09:51 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 02 Oct 2020 05:46:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , my apologies for not thanking you sooner!  I have too many "projects in the works at any given moment and I caved to my frustration with the mirror and took a break.  Intended to be a present to my wife, I am now hoping that I can get this the way I want before her birthday comes around again <em>facepalm</em></p>
<p dir="auto">Anyways, I am back to being committed and frustration slaps me in the face immediately…I added the line that was missing (not sure how I did that when I copy and pasted it to begin with) and now I get this error…</p>
<pre><code>[2020-10-01 23:26:22.548] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
[2020-10-01 23:26:24.211] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
/home/pi/MagicMirror/js/check_config.js:66
			throw new Error("Wrong syntax in config file!");
Error: Wrong syntax in config file!
    at /home/pi/MagicMirror/js/check_config.js:66:10
    at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.12.0 config:check script.
npm ERR!     /home/pi/.npm/_logs/2020-10-02T05_26_24_231Z-debug.log
<p dir="auto">Here is my config file from top to bottom as it is now…</p>
 * MIT Licensed.
var config = {
	port: 8080,
	ipWhitelist: [], // Set [] to allow all IP addresses
	language: "en",
	timeFormat: 24,
	units: "imperial",
			     // false, default for all  NON-armv6l devices
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "US Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
			module: "currentweather",
				locationID: "5417598", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				appid: "cf2de0d28398c756b6bad589d8e33c2a"
			module: "weatherforecast",
			header: "Weather Forecast",
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "BBC Top News Stories",
						url: "http://feeds.bbci.co.uk/news/rss.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
    module: 'MMM-SleepWake',
    config:{
       delay:  15,               // default
       mode:  Hide
<p dir="auto">Lastly, did I understand that if I am using an energy star lcd tv with floating “no signal” message when Pi is off that I should use "mode:  Hide " ?</p>
]]></description><link>https://forum.magicmirror.builders/post/82643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/82643</guid><dc:creator><![CDATA[bumrocks]]></dc:creator><pubDate>Fri, 02 Oct 2020 05:46:29 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sun, 06 Sep 2020 12:25:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bumrocks" aria-label="Profile: bumrocks">@<bdi>bumrocks</bdi></a> you are missing</p>
<p dir="auto">config:{</p>
<p dir="auto">after the module:<br />
line</p>
]]></description><link>https://forum.magicmirror.builders/post/81383</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81383</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 12:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sun, 06 Sep 2020 07:26:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , :)  Thank you!  It appears I have made the necessary changes and will test here shortly!  :crossed_fingers_light_skin_tone:</p>
<p dir="auto">Ug!  I have apparently edited my config file improperly…Message I get after checking it…</p>
<pre><code>pi@mm2:~/MagicMirror $ npm run config:check
&gt; magicmirror@2.12.0 config:check /home/pi/MagicMirror
&gt; node js/check_config.js
[2020-09-06 01:16:00.192] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
[2020-09-06 01:16:00.266] [LOG]    Line 101 col 16 Parsing error: Unexpected token below
npm ERR! errno 1
npm ERR!
npm ERR!     /home/pi/.npm/_logs/2020-09-06T07_16_00_294Z-debug.log
<p dir="auto">Here are the lines in question…</p>
<pre><code>    module: 'MMM-SleepWake',
    source: 'external',
    mode:  see below,
     // detectionDir: folder containing externally generated file when motion starts
     //               will be created if needed
     // detectionFile:  filename generated for motion start. default = 'detected'
<p dir="auto">“mode: see below,” is line 101 as referenced in file check above…</p>
]]></description><link>https://forum.magicmirror.builders/post/81373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81373</guid><dc:creator><![CDATA[bumrocks]]></dc:creator><pubDate>Sun, 06 Sep 2020 07:26:10 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sun, 06 Sep 2020 01:01:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bumrocks" aria-label="Profile: bumrocks">@<bdi>bumrocks</bdi></a> yes, the file is in the etc tree, so u need sudo</p>
]]></description><link>https://forum.magicmirror.builders/post/81363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81363</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 01:01:15 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sun, 06 Sep 2020 00:37:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , well my issue of the moment is it will not let me save the changes made to the motion.conf file, arg!  I tried to change the files attributes to “anyone” and I get…</p>
<pre><code>Error setting permissions: Operation not permitted
]]></description><link>https://forum.magicmirror.builders/post/81362</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81362</guid><dc:creator><![CDATA[bumrocks]]></dc:creator><pubDate>Sun, 06 Sep 2020 00:37:23 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sun, 06 Sep 2020 00:19:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bumrocks" aria-label="Profile: bumrocks">@<bdi>bumrocks</bdi></a> the motion log is on /var/log/motion/motion.log</p>
<p dir="auto">so u can see what it is doing</p>
]]></description><link>https://forum.magicmirror.builders/post/81361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81361</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 00:19:03 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sun, 06 Sep 2020 00:17:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bumrocks" aria-label="Profile: bumrocks">@<bdi>bumrocks</bdi></a> the start/ stop events are coded in the module doc here</p>
<p dir="auto"><a href="https://raw.githubusercontent.com/sdetweil/MMM-SleepWake/master/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MMM-SleepWake/master/README.md</a></p>
<p dir="auto">like this (motion.conf lines)<br />
u need to remove the ; to uncomment them in the motion.conf<br />
u have to put the right path there, {user} is just a placeholder</p>
<p dir="auto">movies<br />
ffmpeg off<br />
images I think are off by default</p>
<p dir="auto">you may also want to change the event gap ( time between motion start and reporting motion stop)  I have mine set to 15 seconds. defaults to 60 ( 1 minute)</p>
<p dir="auto">also lightflash in case you turn on the room lights. is this motion by itself? I have that turned off<br />
and also motion_frames,  how many consecutives frames at 60/second should have motion before reporting… I have mine set to 2.</p>
]]></description><link>https://forum.magicmirror.builders/post/81360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81360</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Sep 2020 00:17:56 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Sat, 05 Sep 2020 23:22:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , I am unclear where or how to turn off recording images and video and where the “start/stop” commands are noted within the module instructions…</p>
<p dir="auto">I want to use my logitech usb camera for mic control and the camera for detection as well.  I have already installed your sleepwake module as well…Just need it all configured at this point and struggling on my own, apparently…</p>
<p dir="auto">Also note, in my /usr/share/doc/motion/ it does not contain a motion_guide.html</p>
<p dir="auto">Here is my config file…</p>
<p dir="auto">Edited to reflect that I believe I made the changes you mention on your SleepWake page to the motion file…</p>
<pre><code># Rename this distribution example file to motion.conf
# This config file was generated by motion 4.1.1
# Documentation:  /usr/share/doc/motion/motion_guide.html
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon off
# File to store the process ID, also called pid file. (default: not defined)
process_id_file /var/run/motion/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
logfile /var/log/motion/motion.log
# Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
log_level 6
# Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
log_type all
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
videodevice /dev/video0
# v4l2_palette allows one to choose preferable palette to be use by motion
# See motion_guide.html for the valid options and values.  (default: 17)
v4l2_palette 17
# Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
# The video input to be used (default: -1)
# Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
# Set to 0 for uvideo(4) on OpenBSD
input -1
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Override the power line frequency for the webcam. (normally not necessary)
# Values:
# -1 : Do not modify device setting
# 0  : Power line frequency Disabled
# 1  : 50hz
# 2  : 60hz
# 3  : Auto
power_line_frequency -1
# Rotate image this number of degrees. The rotation affects all saved images as
# well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 0
# Flip image over a given axis (vertical or horizontal), vertical means from left to right
# horizontal means top to bottom. Valid values: none, v and h.
flip_axis none
# Image width (pixels). Valid range: Camera dependent, default: 320
width 320
# Image height (pixels). Valid range: Camera dependent, default: 240
height 240
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 2
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 0
# Full Network Camera URL.  Valid Services: http:// ftp:// mjpg:// rtsp:// mjpeg:// file:// rtmp://
; netcam_url value
# Username and password for network camera if required. Syntax is user:password
; netcam_userpass value
# The setting for keep-alive of network socket, should improve performance on compatible net cameras.
# off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
# force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
# on:    Use HTTP/1.1 requests that support keep alive as default.
# Default: off
netcam_keepalive off
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# RTSP connection uses TCP to communicate to the camera. Can prevent image corruption.
# Default: on
rtsp_uses_tcp on
# Name of camera to use if you are using a camera accessed through OpenMax/MMAL
# Default: Not defined
; mmalcam_name vc.ril.camera
# Camera control parameters (see raspivid/raspistill tool documentation)
; mmalcam_control_params -hf
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value 128.
# Only recommended for cameras without auto brightness
auto_brightness off
# Set the initial brightness of a video device.
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 0
# Set the contrast of a video device.
contrast 0
# Set the saturation of a video device.
saturation 0
# Set the hue of a video device (NTSC feature).
hue 0
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
threshold 1500
# Automatically tune the threshold down if possible (default: off)
threshold_tune off
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle_filter EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
# A script (on_area_detected) is started immediately when motion is         4 5 6
# detected in one of the given areas, but only once during an event.        7 8 9
# One or more areas can be specified with this option. Take care: This option
# does NOT restrict detection to these areas! (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
; mask_file value
# PGM file to completely mask out a area of image.
# mask_privacy value
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the picture
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames and
# cause unsmooth movies. To smooth movies use larger values of post_capture instead.
pre_capture 0
# Number of frames to capture after motion is no longer detected (default: 0)
post_capture 0
# Event Gap is the seconds of no motion detection that triggers the end of an event.
# An event is defined as a series of motion images taken within a short timeframe.
# Recommended value is 60 seconds (Default). The value -1 is allowed and disables
# events causing all Motion to be written to one single movie file and no pre_capture.
# If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
# event ends right after no more motion is detected and post_capture is over.
event_gap 60
# Maximum length in seconds of a movie
# When value is exceeded a new movie file is created. (Default: 0 = infinite)
max_movie_time 0
# Always save images even if there was no motion (default: off)
emulate_motion off
# Image File Output
# Output 'normal' pictures when motion is detected (default: off)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
output_pictures off
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_debug_pictures off
# The quality (in percent) to be used by the jpeg and webp compression (default: 75)
quality 75
# Type of output images
# Valid values: jpeg, ppm or webp (default: jpeg)
picture_type jpeg
# Use ffmpeg to encode videos of motion (default: off)
ffmpeg_output_movies on
# Use ffmpeg to make videos showing the moving pixels (ghost images) (default: off)
ffmpeg_output_debug_movies off
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 400000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 1 - 100 where 1 means worst quality and 100 is best.
ffmpeg_variable_bitrate 0
# Container/Codec output videos
# Valid values: mpeg4, msmpeg4, swf,flv, ffv1, mov, mp4, mkv, hevc
ffmpeg_video_codec mkv
# When creating videos, should frames be duplicated in order
# to keep up with the requested frames per second
# (default: true)
ffmpeg_duplicate_frames true
# Interval in seconds between timelapse captures.  Default: 0 = off
timelapse_interval 0
# Timelapse file rollover mode. See motion_guide.html for options and uses.
timelapse_mode daily
# Frame rate for timelapse playback
timelapse_fps 30
# Container/Codec for timelapse video. Valid values: mpg or mpeg4
timelapse_codec mpg
# External pipe to video encoder
# Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Bool to enable or disable extpipe (default: off)
use_extpipe off
# External program (full path and opts) to pipe raw video to
# Generally, use '-' for STDIN...
;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
;extpipe x264 - --input-res %wx%h --fps %fps --bitrate 2000 --preset ultrafast --quiet -o %f.mp4
;extpipe mencoder -demuxer rawvideo -rawvideo w=%w:h=%h:fps=%fps -ovc x264 -x264encopts preset=ultrafast -of lavf -o %f.mp4 - -fps %fps
;extpipe ffmpeg -y -f rawvideo -pix_fmt yuv420p -video_size %wx%h -framerate %fps -i pipe:0 -vcodec libx264 -preset ultrafast -f mp4 %f.mp4
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = camera id number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off, preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
locate_motion_mode off
# Set the look and style of the locate box if enabled.
# Valid values: box, redbox, cross, redcross (default: box)
# Set to 'box' will draw the traditional box.
# Set to 'redbox' will draw a red box.
# Set to 'cross' will draw a little cross to mark center.
# Set to 'redcross' will draw a little red cross to mark center.
locate_motion_style box
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %Y-%m-%d\n%T-%q
# Draw a user defined text on the images using same options as C function strftime(3)
# Default: Not defined = no text
# Text is placed in lower left corner
; text_left CAMERA %t
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion settings
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
text_double off
# Text to include in a JPEG EXIF comment
# May be any text, including conversion specifiers.
# The EXIF timestamp is included independent of this text.
;exif_text %i%J/%K%L
# Target Directories and filenames For Images And Films
# For the options snapshot_, picture_, movie_ and timelapse_filename
# you can use conversion specifiers
# Quotation marks round string are allowed.
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
target_dir /var/lib/motion
# File path for snapshots (jpeg, ppm or webp) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg, .ppm or .webp is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will always
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg, ppm or .webp) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
picture_filename %v-%Y%m%d%H%M%S-%q
# File path for motion triggered ffmpeg films (movies) relative to target_dir
# File extensions(.mpg .avi) are automatically added so do not include them
movie_filename %v-%Y%m%d%H%M%S
# File path for timelapse movies relative to target_dir
# Default: %Y%m%d-timelapse
timelapse_filename %Y%m%d-timelapse
# Global Network Options
# Enable IPv6 (default: off)
ipv6_enabled off
# Live Stream Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
stream_port 8081
# 50% scaled down substream (default: 0 = disabled)
# substream_port 8082
# Quality of the jpeg (in percent) images produced (default: 50)
stream_quality 50
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by stream_maxrate when motion is detected (default: off)
stream_motion off
# Maximum framerate for stream streams (default: 1)
stream_maxrate 1
# Restrict stream connections to localhost only (default: on)
stream_localhost on
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual stream rate by desired number of seconds
# Actual stream rate is the smallest of the numbers framerate and stream_maxrate
stream_limit 0
# Set the authentication method (default: 0)
# 0 = disabled
# 1 = Basic authentication
# 2 = MD5 digest (the safer authentication)
stream_auth_method 0
# Authentication for the stream. Syntax username:password
# Default: not defined (Disabled)
; stream_authentication username:password
# Percentage to scale the stream image for preview
# This is scaled on the browser side, motion will keep sending full frames
# Default: 25
; stream_preview_scale 25
# Have stream preview image start on a new line
# Default: no
; stream_preview_newline no
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
webcontrol_port 8080
# Restrict control connections to localhost only (default: on)
webcontrol_localhost on
# Output for http server, select off to choose raw text plain (default: on)
webcontrol_html_output on
# Authentication for the http based control. Syntax username:password
; webcontrol_authentication username:password
# Parameters to include on webcontrol.  0=none, 1=limited, 2=advanced, 3=restricted
# Default: 0 (none)
webcontrol_parms 0
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
;track_port /dev/ttyS0
# Motor number for x-axis (default: 0)
;track_motorx 0
# Set motorx reverse (default: 0)
;track_motorx_reverse 0
# Motor number for y-axis (default: 0)
;track_motory 1
# Set motory reverse (default: 0)
;track_motory_reverse 0
# Maximum value on x-axis (default: 0)
;track_maxx 200
# Minimum value on x-axis (default: 0)
;track_minx 50
# Maximum value on y-axis (default: 0)
;track_maxy 200
# Minimum value on y-axis (default: 0)
;track_miny 50
# Center value on x-axis (default: 0)
;track_homex 128
# Center value on y-axis (default: 0)
;track_homey 128
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined by event_gap
; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option event_gap.
; on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'.   (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion don't detect a lost camera!
# It depends on the driver, some drivers dosn't detect a lost camera at all
# Some hangs the motion thread. Some even hangs the PC! (default: none)
; on_camera_lost value
# Command to be executed when a camera that was lost has been found (default: none)
# NOTE: If motion doesn't properly detect a lost camera, it also won't know it found one.
; on_camera_found value
# Common Options for database features.
# Options require database options to be active also.
# Log to the database when creating motion triggered picture file  (default: on)
; sql_log_picture on
# Log to the database when creating a snapshot image file (default: on)
; sql_log_snapshot on
# Log to the database when creating motion triggered movie file (default: off)
; sql_log_movie off
# Log to the database when creating timelapse movies file (default: off)
; sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Default value:
# Create tables :
# Mysql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
# Postgresql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
# Database Options
# database type : mysql, postgresql, sqlite3 (default : not defined)
; database_type value
# database to log to (default: not defined)
# for sqlite3, the full path and name for the database.
; database_dbname value
# The host on which the database is located (default: localhost)
; database_host value
# User account name for database (default: not defined)
; database_user value
# User password for database (default: not defined)
; database_password value
# Port on which the database is located
#  mysql 3306 , postgresql 5432 (default: not defined)
; database_port value
# Database wait time in milliseconds for locked database to
# be unlocked before returning database locked error (default 0)
; database_busy_timeout 0
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# Specify the device associated with the loopback device
# For example /dev/video1 (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# camera config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one camera
# config file for each camera in addition to this config file.
# Remember: If you have more than one camera you must have one
# camera file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND camera1.conf and camera2.conf.
# Only put the options that are unique to each camera in the
# camera config files.
; camera /etc/motion/camera1.conf
; camera /etc/motion/camera2.conf
; camera /etc/motion/camera3.conf
; camera /etc/motion/camera4.conf
# Camera config directory
# Any files ending in '.conf' in this directory will be read
# as a camera config file.
; camera_dir /etc/motion/conf.d
]]></description><link>https://forum.magicmirror.builders/post/81357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/81357</guid><dc:creator><![CDATA[bumrocks]]></dc:creator><pubDate>Sat, 05 Sep 2020 23:22:12 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 13 Dec 2019 12:47:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guongthongminh" aria-label="Profile: guongthongminh">@<bdi>guongthongminh</bdi></a> said in <a href="/post/65934">Webcam for MM build?</a>:</p>
<p dir="auto">I tried it but the result is still the same.</p>
<p dir="auto">that is not an error, just a message to tell you where motion events will go</p>
]]></description><link>https://forum.magicmirror.builders/post/65940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65940</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Dec 2019 12:47:18 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 13 Dec 2019 09:13:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I tried it but the result is still the same. Hope you help!<br />
<img src="https://i.imgur.com/FDzKm2G.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65934</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Fri, 13 Dec 2019 09:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 13:19:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guongthongminh" aria-label="Profile: guongthongminh">@<bdi>guongthongminh</bdi></a> do this to update the module</p>
<pre><code>cd ~/MagicMirror/modules/MMM-SleepWake
git pull
<p dir="auto">the restart the mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/65556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65556</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 06 Dec 2019 13:19:37 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 13:11:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guongthongminh" aria-label="Profile: guongthongminh">@<bdi>guongthongminh</bdi></a> sorry, hang on… they started enforcing specific api call formats…</p>
]]></description><link>https://forum.magicmirror.builders/post/65555</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65555</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 06 Dec 2019 13:11:02 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 07:51:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I found this further so you can help me!<br />
<img src="https://www.upsieutoc.com/images/2019/12/06/51cffd5884d653d8a.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65548</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65548</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Fri, 06 Dec 2019 07:51:29 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 03:47:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I did like this in motion.conf<br />
<img src="https://www.upsieutoc.com/images/2019/12/06/4fb76bb411968bdc0.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65542</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65542</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Fri, 06 Dec 2019 03:47:35 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 03:26:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guongthongminh" aria-label="Profile: guongthongminh">@<bdi>guongthongminh</bdi></a> see the readme of the module</p>
<p dir="auto"><a href="https://github.com/sdetweil/MMM-SleepWake/blob/master/README.md#usage" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-SleepWake/blob/master/README.md#usage</a></p>
<p dir="auto">It tells u how to configure the motion detector to wake up the mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/65539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65539</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 06 Dec 2019 03:26:41 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 03:18:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> tôi phát hiện rằng camera của tôi không được mở.<br />
Tôi nghĩ module tự ngắt kết nối màn hình sau 1 khoảng thời gian và không tự kết nối màn hình lại được. (Tôi đã thêm các lệnh theo <a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a>)</p>
]]></description><link>https://forum.magicmirror.builders/post/65538</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65538</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Fri, 06 Dec 2019 03:18:11 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Fri, 06 Dec 2019 01:57:59 GMT]]></title><description><![CDATA[<p dir="auto">Your module is great but I don’t know how to wake the screen when it detects movement. Can you help me finish it?</p>
]]></description><link>https://forum.magicmirror.builders/post/65536</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65536</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Fri, 06 Dec 2019 01:57:59 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Thu, 05 Dec 2019 02:57:33 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much!<br />
I’ll try it now</p>
]]></description><link>https://forum.magicmirror.builders/post/65495</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65495</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Thu, 05 Dec 2019 02:57:33 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Thu, 05 Dec 2019 02:52:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guongthongminh" aria-label="Profile: guongthongminh">@<bdi>guongthongminh</bdi></a> i use the motion addon to detect motion, and my own module to turn off/on screen</p>
<p dir="auto">sudo apt-get install motion</p>
<p dir="auto">its config is /etc/motion/motion.conf<br />
i turn off recording images and video<br />
and add the motion start/top commands per the module instructions</p>
<p dir="auto">my module is MMM-SleepWake on github</p>
]]></description><link>https://forum.magicmirror.builders/post/65494</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65494</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 05 Dec 2019 02:52:19 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Thu, 05 Dec 2019 02:50:07 GMT]]></title><description><![CDATA[<p dir="auto">I am using the MMM-Motion-Detection module but it does not work because the camera only turned on for a few seconds and then turned off</p>
]]></description><link>https://forum.magicmirror.builders/post/65493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65493</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Thu, 05 Dec 2019 02:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Thu, 05 Dec 2019 02:46:46 GMT]]></title><description><![CDATA[<p dir="auto">I use a ps3 camera.<br />
Which module do you use?</p>
]]></description><link>https://forum.magicmirror.builders/post/65492</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65492</guid><dc:creator><![CDATA[guongthongminh]]></dc:creator><pubDate>Thu, 05 Dec 2019 02:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to Webcam for MM build? on Thu, 05 Dec 2019 02:30:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guongthongminh" aria-label="Profile: guongthongminh">@<bdi>guongthongminh</bdi></a> i use a logitech c270 webcam</p>
]]></description><link>https://forum.magicmirror.builders/post/65490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65490</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 05 Dec 2019 02:30:53 GMT</pubDate></item></channel></rss>
