<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Glass?]]></title><description><![CDATA[<p dir="auto">I’m sure this gets asked a lot, but I’m a bit stuck here…</p>
<p dir="auto">What is the best glass option for a magic/smart mirror? Obviously mirror film on glass would be my cheapest option, but does it still work as well or will I end up with a crappy finished product?</p>
<p dir="auto">Would anyone in North America be able to direct me to a cheaper source for this? (As opposed to <a href="http://twowaymirrors.com" target="_blank" rel="noopener noreferrer nofollow ugc">twowaymirrors.com</a> which will cost me a small fortune for the size I need)</p>
]]></description><link>https://forum.magicmirror.builders/topic/11730/glass</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 00:11:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11730.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Dec 2019 22:24:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Glass? on Sat, 07 Dec 2019 06:58:02 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a>, that clears it up for me. I suppose I’m ready start shopping around for supplies then!</p>
]]></description><link>https://forum.magicmirror.builders/post/65593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65593</guid><dc:creator><![CDATA[Mrr]]></dc:creator><pubDate>Sat, 07 Dec 2019 06:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to Glass? on Fri, 06 Dec 2019 15:39:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrr" aria-label="Profile: Mrr">@<bdi>Mrr</bdi></a> The thickness of the glass does not affect the display, as transmission is refelctiveness is determined by the special cover on the surfaces of the glass. But it mak as huge difference in the weight of glass.<br />
Eg. I have a 4mmx50cmx70cm Pilkington Mirropane Chrome Spy which which weighs 3.5 kg. The 6mm version would weigh already 5.5 kg and had cost 30€ more. That said, just 2mm on these dimensions cause +2kg + nearly 50% more costs!<br />
So if you have now stability constrains, then 4mm are fine. Otherwise, if you need -due to constructional constraints of the frame- more stability, then go for 6mm.</p>
]]></description><link>https://forum.magicmirror.builders/post/65561</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65561</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Fri, 06 Dec 2019 15:39:48 GMT</pubDate></item><item><title><![CDATA[Reply to Glass? on Fri, 06 Dec 2019 09:18:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> thank you! I’ll check that out and see if it helps me any :)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> I’m thinking about using an old 32" tv screen, but now I’m wondering if I should aim smaller. I’m currently working on finding any leads as to cheaper source for the glass amongst my circle of friends, hopefully that will lower costs a bit too</p>
<p dir="auto">In terms of the thickness of the glass itself, how does this affect the display?</p>
]]></description><link>https://forum.magicmirror.builders/post/65551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65551</guid><dc:creator><![CDATA[Mrr]]></dc:creator><pubDate>Fri, 06 Dec 2019 09:18:56 GMT</pubDate></item><item><title><![CDATA[Reply to Glass? on Fri, 06 Dec 2019 06:55:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrr" aria-label="Profile: Mrr">@<bdi>Mrr</bdi></a> I’d second what <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said. In the long run glass is the way to go, although it costs more. But the results are unmatched compared to film. It would be a pitty to save money on the wrong end. What size of the display are you talking?</p>
]]></description><link>https://forum.magicmirror.builders/post/65546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65546</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Fri, 06 Dec 2019 06:55:42 GMT</pubDate></item><item><title><![CDATA[Reply to Glass? on Fri, 06 Dec 2019 01:33:31 GMT]]></title><description><![CDATA[<p dir="auto">yeh, thats why mine aren’t covered yet…  I have a 55 in tv to cover…</p>
]]></description><link>https://forum.magicmirror.builders/post/65535</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65535</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 06 Dec 2019 01:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to Glass? on Fri, 06 Dec 2019 01:20:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrr" aria-label="Profile: Mrr">@<bdi>Mrr</bdi></a></p>
<p dir="auto">Get a price here. I don’t know how it compares to what you’ve already seen.<br />
<a href="https://www.tapplastics.com/product/plastics/cut_to_size_plastic/two_way_mirrored_acrylic/558" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.tapplastics.com/product/plastics/cut_to_size_plastic/two_way_mirrored_acrylic/558</a></p>
<p dir="auto">Personally, I’d stay away from the “film” stuff. I don’t think you’d be very happy dealing with it or the result.</p>
]]></description><link>https://forum.magicmirror.builders/post/65534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65534</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 06 Dec 2019 01:20:06 GMT</pubDate></item></channel></rss>
