<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-RandomBackground, Background from local folder]]></title><description><![CDATA[<p dir="auto">As request by some, first version of showing random full size background from a local folder.</p>
<p dir="auto">[card:Ultimatum22/MMM-RandomBackground]</p>
<p dir="auto">It will load a photo’s from a photo directory in ~/MagicMirror/modules/MMM-RandomBackground, easiest way is by creating a Windows share. If somebody needs help with that let me know.</p>
<p dir="auto">This still has a lot of improvements, I will update the readme with future implementations and a list of issues. If you see any please let me know.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1178/mmm-randombackground-background-from-local-folder</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:58:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1178.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Dec 2016 21:19:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Tue, 21 Aug 2018 17:08:02 GMT]]></title><description><![CDATA[<p dir="auto">hello,<br />
it doesn’t seem to work for me, install ok, but not pictures showed, only a loading text …<br />
i put 2 jpg pictures in a “photos” folder in the MMM-RandomBackground folder…<br />
does i need to name picture specifically ??</p>
<p dir="auto">EDIT : npm install… it’s ok :D</p>
]]></description><link>https://forum.magicmirror.builders/post/43650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43650</guid><dc:creator><![CDATA[elmattt]]></dc:creator><pubDate>Tue, 21 Aug 2018 17:08:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Sat, 04 Aug 2018 13:25:42 GMT]]></title><description><![CDATA[<p dir="auto">For folders outside the MagicMirror directory tree, I use a link ( ln command) to my Nas server share</p>
<p dir="auto">The image showing modules are using the built-in web server for file access, and it’s root is ~/MagicMirror. And cannot see outside that folder tree.</p>
]]></description><link>https://forum.magicmirror.builders/post/43022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43022</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Aug 2018 13:25:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Fri, 03 Aug 2018 02:22:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kivlow" aria-label="Profile: kivlow">@<bdi>kivlow</bdi></a></p>
<p dir="auto">Where MMM-ImageSlideshow is concerned, if your config entry looks like this . . .</p>
<pre><code>{
            disabled: f,
            module: 'MMM-ImageSlideshow',
            position: 'middle_center',
                imagePaths: ['modules/MMM-ImageSlideshow/images'],
                slideshowSpeed: 10000,
                fixedImageWidth: 800,
                randomizeImageOrder: true,
<p dir="auto">… then your image files belong in this directory</p>
<p dir="auto"><code>modules/MMM-ImageSlideshow/images</code></p>
]]></description><link>https://forum.magicmirror.builders/post/42975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42975</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 03 Aug 2018 02:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Thu, 02 Aug 2018 05:52:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello :]<br />
Im new to magic mirror - i want to make digital photo frame on my p3 and raspbian. So i use magicmirror but i not know how to make that MM see my photos i set imagepath to fotos but notching is displayed :[<br />
Ultimatum22 wrote somting about windows share but i dont know what to do :/<br />
Regards Kamil</p>
<p dir="auto">p.s. i try MMM-BackgroundSlideshow, MMM-ImageFileWatcher and MMM-ImageSlideshow all not show my pictures on local folder in magicmirror :/ what to do.</p>
]]></description><link>https://forum.magicmirror.builders/post/42928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42928</guid><dc:creator><![CDATA[kivlow]]></dc:creator><pubDate>Thu, 02 Aug 2018 05:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Fri, 20 Jul 2018 21:06:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/radu022003" aria-label="Profile: radu022003">@<bdi>radu022003</bdi></a><br />
Well, maybe a little amount of pics loading on demands would be answer.<br />
My last MMM-GooglePhotos loads only one photo from Google Photos when it is needed.</p>
]]></description><link>https://forum.magicmirror.builders/post/42421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42421</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 20 Jul 2018 21:06:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Fri, 20 Jul 2018 20:08:18 GMT]]></title><description><![CDATA[<p dir="auto">Hello, I have just starting using this module. I find it very useful and seems to work very good… as long as the pictures are copied on the SD card.<br />
My ideea is to use the pictures that are already on my NAS. I did tried to mount the NAS on the expected folder  /home/pi/MagicMirror/modules/MMM-RandomBackground/photos/. But the module seems not to be able to work with such a big amount of data, arround 30k files.<br />
I also observed that if i delete the pictures from “photos” folder the slideshow is keep running, which leads me to the Ideea that the module is loading the files in RAM or something similar, if it is so, that I can understand why is it not working with 30k files.<br />
Is there any option to use this module in my desired setup?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/42420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/42420</guid><dc:creator><![CDATA[radu022003]]></dc:creator><pubDate>Fri, 20 Jul 2018 20:08:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 14 Aug 2017 10:08:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a> said in <a href="/post/26529">Random background from local folder</a>:</p>
<p dir="auto">@Sean You are correct about ARM architecture, didn’t do my research properly. I did a quick search and it seems like a hazzle indeed. This seems to be a kind of solution, <a href="http://mitchtech.net/dropbox-on-raspberry-pi-via-sshfs/" target="_blank" rel="noopener noreferrer nofollow ugc">http://mitchtech.net/dropbox-on-raspberry-pi-via-sshfs/</a></p>
<p dir="auto">Maybe this could be another solution. But it still needs ‘REMOTE HOST’ server. anyway, I have a NAS in my house, so I could use this.</p>
<p dir="auto">I agree about the space but if you have a decent sdcard, like 32gb you can store plenty of photo’s and change them once in a while. I have set up a shared directory with samba to the photo directory directly. I just put my photo’s in here and restart the pi.</p>
<p dir="auto">Yes. It could be so.</p>
<p dir="auto">Would be nice if google photo’s introduces an api, I use it for photo backup at the moment.</p>
<p dir="auto">We both agree this could be the ultimate final solution.</p>
<p dir="auto">Anyway, last weekends, I tried to test Dropbox API. I think I can make Dropbox Wallpaper module in a few days. But that could be for just a shallow nitch purpose. Usually, using local storage is the better way. However, for my family and <a class="plugin-mentions-user plugin-mentions-a" href="/user/nobita" aria-label="Profile: nobita">@<bdi>nobita</bdi></a>, It could be alternates. I’ll leave mention about that in my module.</p>
]]></description><link>https://forum.magicmirror.builders/post/26530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26530</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 14 Aug 2017 10:08:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 14 Aug 2017 09:59:08 GMT]]></title><description><![CDATA[<p dir="auto">@Sean You are correct about ARM architecture, didn’t do my research properly. I did a quick search and it seems like a hazzle indeed. This seems to be a kind of solution, <a href="http://mitchtech.net/dropbox-on-raspberry-pi-via-sshfs/" target="_blank" rel="noopener noreferrer nofollow ugc">http://mitchtech.net/dropbox-on-raspberry-pi-via-sshfs/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/26529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26529</guid><dc:creator><![CDATA[Ultimatum22]]></dc:creator><pubDate>Mon, 14 Aug 2017 09:59:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 14 Aug 2017 09:57:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a> said in <a href="/post/26527">Random background from local folder</a>:</p>
<p dir="auto">@Sean There is a dropbox client for debian, if you use raspbian on your RPI this should work. I haven’t tested it but if you can get it to synchronize you can link to it from my module like yawns said.</p>
<p dir="auto">That client is for normal Intel/AMD devices. As I know, there is no official Dropbox client for ARM architectures. So people cannot install Dropbox on RPi. (maybe I could be wrong…)<br />
Currently, the only available solution is using <code>Exagear</code>(<a href="https://eltechs.com/product/exagear-desktop/" target="_blank" rel="noopener noreferrer nofollow ugc">https://eltechs.com/product/exagear-desktop/</a>).</p>
<p dir="auto">Anyway, There might be some PROs and CONs about using Dropbox or cloud storage for private photos. I bet considering external network storage is not non-sense.</p>
<ul>
<li>RPI has the limited volume of storage. Some people have tons of images to show. And they might not want to worry about sync between original photos in archives and those in RPI.</li>
<li>Some people are not familiar with FTP or SFTP or anything. (e.g. my wife). She just wants to throw her new photos into some folder simply. (Well, there might be another options like netatalk, smb,…  but my wife has HER OPINIONS.)</li>
<li>Google Photo and iCloud Photos are awesome services, but unfortunately, they don’t support external API. That is why people want to use simple and free ‘dropbox’ alternately.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/26528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26528</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 14 Aug 2017 09:57:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 14 Aug 2017 09:32:24 GMT]]></title><description><![CDATA[<p dir="auto">@Sean There is a dropbox client for debian, if you use raspbian on your RPI this should work. I haven’t tested it but if you can get it to synchronize you can link to it from my module like yawns said.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nobita" aria-label="Profile: nobita">@<bdi>nobita</bdi></a> I don’t want to store my photo’s on dropbox so I don’t have the need implement this option but my above solution should work.</p>
]]></description><link>https://forum.magicmirror.builders/post/26527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26527</guid><dc:creator><![CDATA[Ultimatum22]]></dc:creator><pubDate>Mon, 14 Aug 2017 09:32:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Sun, 13 Aug 2017 07:18:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> Is there any way to implement Dropbox in RPI? I’ve found only one solution <code>Exagear</code>, but it is not free.</p>
]]></description><link>https://forum.magicmirror.builders/post/26485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/26485</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 13 Aug 2017 07:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Wed, 17 May 2017 08:16:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nobita" aria-label="Profile: nobita">@<bdi>nobita</bdi></a> said in <a href="/post/21690">Random background from local folder</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a> you can change from local folder to Dropbox (Share Photo) and can adjust time to display from dropbox</p>
<p dir="auto">Couldn’t you just synchronize your dropbox client into the specific folder and use the module as is?</p>
]]></description><link>https://forum.magicmirror.builders/post/21694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21694</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Wed, 17 May 2017 08:16:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Wed, 17 May 2017 03:40:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a> you can change from local folder to Dropbox (Share Photo) and can adjust time to display from dropbox</p>
]]></description><link>https://forum.magicmirror.builders/post/21690</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21690</guid><dc:creator><![CDATA[nobita]]></dc:creator><pubDate>Wed, 17 May 2017 03:40:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Tue, 25 Apr 2017 19:45:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/woody" aria-label="Profile: Woody">@<bdi>Woody</bdi></a> said in <a href="/post/9652">Random background from local folder</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a><br />
No, not a USB storage. I mean a NAS, a cloud resourse,  any SMB share.</p>
<p dir="auto">Thank you for the module. Is it possible to make this working with a NAS ? And is it also possible e.g. on top_right instead of background?</p>
]]></description><link>https://forum.magicmirror.builders/post/20479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/20479</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Tue, 25 Apr 2017 19:45:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 30 Jan 2017 16:02:23 GMT]]></title><description><![CDATA[<p dir="auto">Oops! My apologies, I was getting this module confused with another. Mea culpa!</p>
]]></description><link>https://forum.magicmirror.builders/post/13027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13027</guid><dc:creator><![CDATA[lignumaqua]]></dc:creator><pubDate>Mon, 30 Jan 2017 16:02:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 30 Jan 2017 15:52:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/docmucki" aria-label="Profile: docmucki">@<bdi>docmucki</bdi></a> What is the value you use, because it is indeed in miliseconds as jfodor said.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lignumaqua" aria-label="Profile: lignumaqua">@<bdi>lignumaqua</bdi></a> Can you post your configuration for my module? It should work full screen if you look at the default ‘fullscreen_below’.</p>
]]></description><link>https://forum.magicmirror.builders/post/13024</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13024</guid><dc:creator><![CDATA[Ultimatum22]]></dc:creator><pubDate>Mon, 30 Jan 2017 15:52:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Mon, 30 Jan 2017 15:36:22 GMT]]></title><description><![CDATA[<p dir="auto">This works, but the background image is only in the top half of the screen (running portrait). Is there a way to make it fill the entire screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/13023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13023</guid><dc:creator><![CDATA[lignumaqua]]></dc:creator><pubDate>Mon, 30 Jan 2017 15:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Fri, 27 Jan 2017 17:29:04 GMT]]></title><description><![CDATA[<p dir="auto">it uses milliseconds. mine is set at 900000 which is 15 minutes.</p>
]]></description><link>https://forum.magicmirror.builders/post/12705</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12705</guid><dc:creator><![CDATA[jfodor]]></dc:creator><pubDate>Fri, 27 Jan 2017 17:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Thu, 26 Jan 2017 19:53:36 GMT]]></title><description><![CDATA[<p dir="auto">Changing the updateInterval seems to have no effect. Always feels like 3 seconds.</p>
]]></description><link>https://forum.magicmirror.builders/post/12605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12605</guid><dc:creator><![CDATA[docmucki]]></dc:creator><pubDate>Thu, 26 Jan 2017 19:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Thu, 26 Jan 2017 17:59:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/in_a_days" aria-label="Profile: in_a_days">@<bdi>in_a_days</bdi></a><br />
Thank you. That was the case.</p>
]]></description><link>https://forum.magicmirror.builders/post/12593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12593</guid><dc:creator><![CDATA[docmucki]]></dc:creator><pubDate>Thu, 26 Jan 2017 17:59:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Thu, 26 Jan 2017 17:44:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/docmucki" aria-label="Profile: docmucki">@<bdi>docmucki</bdi></a></p>
<p dir="auto">I suspect you need to execute</p>
<pre><code>npm install
<p dir="auto">From ~/MagicMirror/modules/MMM-RandomBackground rather than ~/MagicMirror/modules.</p>
<p dir="auto">Try:</p>
<pre><code>cd MMM-RandomBackground
npm install
]]></description><link>https://forum.magicmirror.builders/post/12591</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12591</guid><dc:creator><![CDATA[in_a_days]]></dc:creator><pubDate>Thu, 26 Jan 2017 17:44:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Thu, 26 Jan 2017 17:40:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi, i have some warnings when I try to install this module. Can someone give me a hint what to do?</p>
<p dir="auto">thx,<br />
docmucki</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Ultimatum22/MMM-RandomBackground.git
Klone nach 'MMM-RandomBackground'...
remote: Counting objects: 81, done.
remote: Total 81 (delta 0), reused 0 (delta 0), pack-reused 81
Entpacke Objekte: 100% (81/81), Fertig.
Prüfe Konnektivität... Fertig.
pi@raspberrypi:~/MagicMirror/modules $ npm install
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
npm WARN modules No description
npm WARN modules No repository field.
npm WARN modules No README data
npm WARN modules No license field.
]]></description><link>https://forum.magicmirror.builders/post/12590</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12590</guid><dc:creator><![CDATA[docmucki]]></dc:creator><pubDate>Thu, 26 Jan 2017 17:40:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-RandomBackground, Background from local folder on Wed, 04 Jan 2017 07:43:20 GMT]]></title><description><![CDATA[<p dir="auto">i can only get this to work in the full screen locations. can this be placed in any other locations?</p>
<p dir="auto">i would also second the network share for the photo location.</p>
<p dir="auto">as a note to others you have to create a folder in ~/MagicMirror/modules/MMM-RandomBackground called photos and place your photo’s in there.</p>
]]></description><link>https://forum.magicmirror.builders/post/10385</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10385</guid><dc:creator><![CDATA[jfodor]]></dc:creator><pubDate>Wed, 04 Jan 2017 07:43:20 GMT</pubDate></item></channel></rss>
