<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-VigilanceMeteoFrance]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">I just released a third Magic Mirror Module, <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-VigilanceMeteoFrance</a>, it displays the current level of vigilance of weather phenomena in <strong>France</strong> and the associated risks :</p>
<p dir="auto"><img src="https://github.com/grenagit/MMM-VigilanceMeteoFrance/raw/master/MMM-VigilanceMeteoFrance_screenshots.png" alt="MMM-VigilanceMeteoFrance ScreenShots" class=" img-fluid img-markdown" /></p>
<p dir="auto">I hope you like the module.<br />
Please inform me of any problems.</p>
<p dir="auto">Grena</p>
]]></description><link>https://forum.magicmirror.builders/topic/11782/mmm-vigilancemeteofrance</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 07:18:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11782.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Dec 2019 09:58:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Fri, 12 Jan 2024 07:14:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto"><a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-VigilanceMeteoFrance</a> 2.2 was released and uses the <strong>simplified authentication system</strong> from Météo France .</p>
<p dir="auto"><strong>A single Application ID is now required instead of 2 keys for the module to work, please update your configuration!</strong> <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance#appid" target="_blank" rel="noopener noreferrer nofollow ugc">More info here</a></p>
<p dir="auto"><em>Grena</em></p>
]]></description><link>https://forum.magicmirror.builders/post/114379</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/114379</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Fri, 12 Jan 2024 07:14:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Wed, 03 Jan 2024 18:31:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grena" aria-label="Profile: grena">@<bdi>grena</bdi></a><br />
Merci pour la rapidité de ta réponse. J’attends donc avec impatience cette nouvelle version</p>
<p dir="auto">Bonne soirée</p>
]]></description><link>https://forum.magicmirror.builders/post/113903</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113903</guid><dc:creator><![CDATA[Philip 0]]></dc:creator><pubDate>Wed, 03 Jan 2024 18:31:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Wed, 03 Jan 2024 13:08:43 GMT]]></title><description><![CDATA[<blockquote>
Bonjour,</p>
<p dir="auto">Bonjour <a class="plugin-mentions-user plugin-mentions-a" href="/user/philip-0" aria-label="Profile: Philip-0">@<bdi>Philip-0</bdi></a>,</p>
<p dir="auto">Je ne comprends pas à quoi correspondent les 2 informations à renseigner : apiConsumerKey et apiConsumerSecret</p>
<p dir="auto">Il semble y avoir eu une évolution du portail API de Météo France sans communication particulière en direction des utilisateurs (je découvre donc les nouveauté suite à ton message). Actuellement, seul un Application ID est nécessaire pour générer un token Oauth2 permettant d’accéder aux données contrairement aux 2 clés utilisées précédemment (procédure qui semble toujours fonctionnelle).</p>
<p dir="auto">La durée de validité est d’1 heure dans le 1er cas et il faut indiquer une durée (laquelle pa ex. ?) dans le second. Est-ce à dire qu’après cette période, le module ne fonctionne plus ? Dans ce cas, que faut-il faire ?</p>
<p dir="auto">Il n’y a rien à faire, le module va régénérer un nouveau token Oauth2 avant de récupérer de nouvelles données !</p>
<p dir="auto">Je vous remercie par avance pour votre aide</p>
<p dir="auto">Bref, j’ai préparé une mise à jour du module et de sa documentation pour prendre en compte ces évolutions et permettent à tous les utilisateurs (nouveaux et anciens) d’utiliser MMM-VigilanceMeteoFrance. Je dois encore tester cela avant de pousser la nouvelle version !</p>
]]></description><link>https://forum.magicmirror.builders/post/113888</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113888</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Wed, 03 Jan 2024 13:08:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Tue, 02 Jan 2024 16:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grena" aria-label="Profile: grena">@<bdi>grena</bdi></a><br />
Bonjour,<br />
Nouveau sur MagicMirror, j’éprouve quelques difficultés à comprendre comment installer le module MMM-VigilanceMeteoFrance.</p>
<p dir="auto">Je suis inscrit sur le portail des API Météofrance (Bulletin vigilance).</p>
<p dir="auto">A quoi correspond le token Oauth2 et quelle est la différence avec API Key . Lequel faut-il utiliser ? A quelle information (apiConsumerKey ou apiConsumerSecret) correspond-il ? et où trouver l’autre ?<br />
La durée de validité est d’1 heure dans le 1er cas et il faut indiquer une durée (laquelle pa ex. ?) dans le second.<br />
<p dir="auto">Cordialement</p>
]]></description><link>https://forum.magicmirror.builders/post/113820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/113820</guid><dc:creator><![CDATA[Philip 0]]></dc:creator><pubDate>Tue, 02 Jan 2024 16:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Wed, 03 May 2023 10:11:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto"><a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-VigilanceMeteoFrance</a> 2.0 was released and uses the <strong>new vigilance API</strong> (v1) from Météo France which provides more complete data.</p>
<p dir="auto"><strong>Free keys are now required for the module to work!</strong> <a href="https://portail-api.meteofrance.fr/devportal/services/aide" target="_blank" rel="noopener noreferrer nofollow ugc">More info here</a></p>
]]></description><link>https://forum.magicmirror.builders/post/109153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/109153</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Wed, 03 May 2023 10:11:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Tue, 07 Jul 2020 13:45:33 GMT]]></title><description><![CDATA[<p dir="auto">Ayè !   :)</p>
<p dir="auto">Du coup j’attends ta réponse avec impatience…</p>
<p dir="auto">Wilfried</p>
]]></description><link>https://forum.magicmirror.builders/post/78176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78176</guid><dc:creator><![CDATA[Wilfried]]></dc:creator><pubDate>Tue, 07 Jul 2020 13:45:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Fri, 03 Jul 2020 06:37:40 GMT]]></title><description><![CDATA[<p dir="auto">Bonjour <a class="plugin-mentions-user plugin-mentions-a" href="/user/wilfried" aria-label="Profile: Wilfried">@<bdi>Wilfried</bdi></a>,</p>
<p dir="auto">Je ne suis pas certain que ta question ait été postée au bon endroit… Ici, on parle du module <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-VigilanceMeteoFrance</a> que j’ai développé pour exploiter les données fournies sur la vigilance météo en France.</p>
<p dir="auto">Tu peux peut-être essayer d’ouvrir un nouveau sujet pour poser ta question ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/77973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77973</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Fri, 03 Jul 2020 06:37:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Wed, 01 Jul 2020 15:04:18 GMT]]></title><description><![CDATA[<p dir="auto">bonjour,</p>
<p dir="auto">Je suis totalement noob sur MM²</p>
<p dir="auto">Est-ce que quelqu’un a déjà modifié le module WeatherForecast afin qu’il récupère la météo depuis Météo France plutôt ?</p>
<p dir="auto">Merci de votre aide</p>
]]></description><link>https://forum.magicmirror.builders/post/77875</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/77875</guid><dc:creator><![CDATA[Wilfried]]></dc:creator><pubDate>Wed, 01 Jul 2020 15:04:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Wed, 15 Apr 2020 16:11:41 GMT]]></title><description><![CDATA[<p dir="auto">Autant pour moi, j’ai regardé vite fait le code, je l’ai pas assez détaillé…<br />
Donc je n’ai plus rien à dire, le module est parfait !<br />
Merci !!!</p>
]]></description><link>https://forum.magicmirror.builders/post/72837</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72837</guid><dc:creator><![CDATA[omoioli]]></dc:creator><pubDate>Wed, 15 Apr 2020 16:11:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Wed, 15 Apr 2020 12:47:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omoioli" aria-label="Profile: omoioli">@<bdi>omoioli</bdi></a> said in <a href="/post/72593">MMM-VigilanceMeteoFrance</a>:</p>
<p dir="auto">Ca ne changerait rien au résultat final, c’est juste un changement de variable, mais ça permettrais d’être sur que le module a bien eu la réponse de l’api…</p>
<p dir="auto">En fait, si tu regardes la fonction <code>processVigi</code>, je teste (sommairement) la conformité des données reçues pour l’affichage final. Il y a notamment <code>data.department != this.config.department</code> pour détecter si le département n’est pas le bon…</p>
<p dir="auto">En cas de données non utilisables, le module reste bloqué sur " Chargement… ", on voit donc très rapidement qu’il y a un problème ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/72823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72823</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Wed, 15 Apr 2020 12:47:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Mon, 13 Apr 2020 06:37:57 GMT]]></title><description><![CDATA[<p dir="auto">Salut,<br />
Pour moi, tout a l’air de fonctionner, avec le département dans le header, ça change bien a chaque notification … Impeccable !<br />
J’ai juste une petite remarque, qui n’est qu’un détail, mais j’ai regardé ton code du module pour voir les infos retournées par l’api, et j’ai remarqué que pour le header, tu indiquais le numéro de département demandé à la notification, mais tu pourrais peut-être indiquer le numéro de département retourné par l’api ?<br />
Ca ne changerait rien au résultat final, c’est juste un changement de variable, mais ça permettrais d’être sur que le module a bien eu la réponse de l’api…<br />
Je sais pas si je suis clair … mais comme je t’ai dit c’est juste un détail…<br />
En tout cas merci pour ton module !</p>
]]></description><link>https://forum.magicmirror.builders/post/72593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72593</guid><dc:creator><![CDATA[omoioli]]></dc:creator><pubDate>Mon, 13 Apr 2020 06:37:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Sat, 11 Apr 2020 08:53:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/omoioli" aria-label="Profile: omoioli">@<bdi>omoioli</bdi></a></p>
<p dir="auto">En fait si ça marche! J’avais mal orthographié la notification… maintenant le changement fonctionne bien.</p>
<p dir="auto">Super !</p>
<p dir="auto">Il faudrait peut-être prévoir d’indiquer le numero de département à côté de la vigilance pour voir que le module s’est mis à jour …</p>
<p dir="auto">En effet, c’est une bonne idée ;) Je viens tout juste d’intégrer la fonctionnalité dans la <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance/tree/testing" target="_blank" rel="noopener noreferrer nofollow ugc">branche testing</a> ! L’affichage du nom et du numéro du département n’est pas activé par défaut, il faut donc rajouter la ligne suivante<code>showDepartment: true,</code> dans ton fichier de configuration.</p>
<p dir="auto">En tout cas merci pour ce module !</p>
<p dir="auto">Avec plaisir :D J’attends ton retour final pour valider ces nouvelles fonctionnalités et les basculer dans la branche principale pour que tout le monde puisse en profiter !</p>
]]></description><link>https://forum.magicmirror.builders/post/72435</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72435</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Sat, 11 Apr 2020 08:53:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Sat, 11 Apr 2020 07:19:02 GMT]]></title><description><![CDATA[<p dir="auto">En fait si ça marche! J’avais mal orthographié la notification… maintenant le changement fonctionne bien.<br />
Mais je pense que mettre le numéro de département au moins dans le header, ça pourrait être pas mal…<br />
]]></description><link>https://forum.magicmirror.builders/post/72433</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72433</guid><dc:creator><![CDATA[omoioli]]></dc:creator><pubDate>Sat, 11 Apr 2020 07:19:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Fri, 10 Apr 2020 19:29:15 GMT]]></title><description><![CDATA[<p dir="auto">Je teste depuis quelques jours le module, mais je ne sais pas si cela marche, tout ce que je teste est en vigilance verte, c’est vrai qu’il fait beau un peu partout …<br />
]]></description><link>https://forum.magicmirror.builders/post/72407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72407</guid><dc:creator><![CDATA[omoioli]]></dc:creator><pubDate>Fri, 10 Apr 2020 19:29:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Mon, 06 Apr 2020 11:16:45 GMT]]></title><description><![CDATA[<p dir="auto">Désolé, je viens juste de voir ton message, oui, ça m’intéresse de tester ça, je vois pour une mise à jour depuis ta branche testing.<br />
Je suis pas mal occupé en ce moment, mais je te fais un retour dès que je peux.</p>
]]></description><link>https://forum.magicmirror.builders/post/72070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72070</guid><dc:creator><![CDATA[omoioli]]></dc:creator><pubDate>Mon, 06 Apr 2020 11:16:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Tue, 31 Mar 2020 18:19:39 GMT]]></title><description><![CDATA[<p dir="auto">Bonjour <a class="plugin-mentions-user plugin-mentions-a" href="/user/omoioli" aria-label="Profile: omoioli">@<bdi>omoioli</bdi></a>,</p>
<p dir="auto">Oui c’est tout à fait possible grâce au système de <a href="https://github.com/MichMich/MagicMirror/wiki/notifications" target="_blank" rel="noopener noreferrer nofollow ugc">notifications</a> du Magic Mirror. Je n’utilise pas de système de contrôle vocal mais l’idée peu être étendue à l’utilisation de menus, de boutons, d’un système de rotation automatique… Et ça me semble intéressant 	:thumbsup:</p>
<p dir="auto">Bref, j’ai intégré la fonctionnalité (fonctionnelle d’après mes tests) dans la <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance/tree/testing" target="_blank" rel="noopener noreferrer nofollow ugc">branche testing</a> ! Si tu es partant pour tester la fonctionnalité avec ton module de contrôle vocal, on peut en discuter en privé ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/71482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71482</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Tue, 31 Mar 2020 18:19:39 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Mon, 30 Mar 2020 18:07:07 GMT]]></title><description><![CDATA[<p dir="auto">Bonjour a tous, super module pour compléter la météo !<br />
Il serait possible de pouvoir modifier le département à la volée par notification (en utilisation avec un module de voix par exemple …) pour avoir un aperçu de la vigilance dans plusieurs secteurs ?</p>
]]></description><link>https://forum.magicmirror.builders/post/71442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71442</guid><dc:creator><![CDATA[omoioli]]></dc:creator><pubDate>Mon, 30 Mar 2020 18:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Sat, 15 Feb 2020 10:55:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigfer" aria-label="Profile: BigFer">@<bdi>BigFer</bdi></a> said in <a href="/post/69504">MMM-VigilanceMeteoFrance</a>:</p>
<p dir="auto">Module mis à jour sans problème. Super pratique !</p>
<p dir="auto">Super ! Merci ;)</p>
<p dir="auto">Pour ton autre question, peux-tu ouvrir un sujet spécifique pour ne pas créer de hors-sujet dans celui-ci ? J’y répondrai avec plaisir :slightly_smiling_face:</p>
<p dir="auto">Pour plus de lisibilité, n’hésites pas à utiliser le bouton " Code " &lt;/&gt; pour coller tes lignes de code et ta configuration !</p>
]]></description><link>https://forum.magicmirror.builders/post/69547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69547</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Sat, 15 Feb 2020 10:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Thu, 13 Feb 2020 12:26:42 GMT]]></title><description><![CDATA[<p dir="auto">Bonjour,<br />
Module mis à jour sans problème. Super pratique !<br />
J’ai une question : J’ai un agenda google dans le module standard calendrier avec des RDV. Je n’arrive pas à faire afficher les RDV dans le module standard ‘Alert’. Comment fonctionne ce module, faut-il ajouter des paramètres dans le calendrier… je rame.<br />
J’ai trouvé ça dans la doc :<br />
Pour les notifications, utilisez:<br />
self.sendNotification(“SHOW_ALERT”, {type: “notification”});<br />
Pour les alertes, utilisez:<br />
self.sendNotification(“SHOW_ALERT”, {});<br />
A quoi ça sert ?<br />
Pourtant,  c’est bien là que s’affiche le nouveau message de vigilance, non ?<br />
J’utilise le module ‘AlarmClock’ qui lui m’affiche bien l’alarme !<br />
Voici la config de mon module :<br />
// alert<br />
{<br />
module: ‘alert’,<br />
config:<br />
{<br />
welcome_message:“Bonjour voici les alertes”,<br />
" ce message s’affiche bien au démarrage" !<br />
display_time:10000,</p>
<pre><code>			}
<p dir="auto">Merci pour l’aide !<br />
cordialement, BigFer</p>
]]></description><link>https://forum.magicmirror.builders/post/69504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69504</guid><dc:creator><![CDATA[BigFer]]></dc:creator><pubDate>Thu, 13 Feb 2020 12:26:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Thu, 13 Feb 2020 10:01:31 GMT]]></title><description><![CDATA[<p dir="auto">Je viens d’ajouter une <strong>nouvelle fonctionnalité</strong> à mon module <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-VigilanceMeteoFrance</a> !</p>
<p dir="auto"><em>Un notification sera affichée dans les cas suivants :</em></p>
<ul>
<li>Vigilance jaune, orange ou rouge au démarrage du MagicMirror.</li>
<li>Augmentation ou diminution du niveau de vigilance.</li>
<li>Ajout d’un ou plusieurs nouveaux risques.</li>
</ul>
<p dir="auto">Cette fonctionnalité est activée par défaut mais il est très simple de la désactiver dans les options. Vous pouvez aussi choisir la durée d’affichage du message (1 minute par défaut).</p>
<p dir="auto"><em>Pour mettre à jour le module :</em></p>
<pre><code class="language-shell">cd ~/MagicMirror/modules/MMM-VigilanceMeteoFrance
git pull
<p dir="auto">N’hésitez pas si vous avez des questions ou des problèmes !</p>
]]></description><link>https://forum.magicmirror.builders/post/69499</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69499</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Thu, 13 Feb 2020 10:01:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Sat, 04 Jan 2020 18:13:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigfer" aria-label="Profile: BigFer">@<bdi>BigFer</bdi></a></p>
<p dir="auto">Le module MMM-Vigicrues de <a class="plugin-mentions-user plugin-mentions-a" href="/user/grena" aria-label="Profile: grena">@<bdi>grena</bdi></a> est genial</p>
]]></description><link>https://forum.magicmirror.builders/post/67182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67182</guid><dc:creator><![CDATA[ELMAGO]]></dc:creator><pubDate>Sat, 04 Jan 2020 18:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Sat, 04 Jan 2020 11:42:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigfer" aria-label="Profile: BigFer">@<bdi>BigFer</bdi></a></p>
<p dir="auto">Merci pour le module. Je débute sur MM et ça me plaît beaucoup. bonne continuation !</p>
<p dir="auto">Merci à toi, je suis content que mon module soit utile ;) Si tu as besoin de conseils pour Magic Mirror, n’hésites pas !</p>
<p dir="auto">Un peu de mal pour le département, écrit une fois departement et une fois department !</p>
<p dir="auto">Oui, j’ai fait le choix de tout écrire en anglais (par habitude quand il s’agit de langage informatique). Mais c’est pour ça que l’on rédige un <a href="https://github.com/grenagit/MMM-VigilanceMeteoFrance/blob/master/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">ReadMe</a> !</p>
<p dir="auto">Si tu habites à proximité d’un cours d’eau, tu peux compléter tes informations avec <a href="https://forum.magicmirror.builders/topic/11908/mmm-vigicrues">MMM-VigiCrues</a>…</p>
]]></description><link>https://forum.magicmirror.builders/post/67170</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67170</guid><dc:creator><![CDATA[grena]]></dc:creator><pubDate>Sat, 04 Jan 2020 11:42:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Fri, 03 Jan 2020 09:08:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grena" aria-label="Profile: grena">@<bdi>grena</bdi></a> Hello, j’habite en Moselle (France). Super ce module, je l’ai installé. Un peu de mal pour le département, écrit une fois departement et une fois department ! Mais, on cherche un tout petit peu et on trouve. Merci pour le module. Je débute sur MM et ça me plait beaucoup. bonne continuation ! (petite copie d’écran de mon MM)!(<img src="/assets/uploads/files/1578042427354-capture.jpg" alt="0_1578042428426_Capture.JPG" class=" img-fluid img-markdown" /> )<br />
BigFer</p>
]]></description><link>https://forum.magicmirror.builders/post/67071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67071</guid><dc:creator><![CDATA[BigFer]]></dc:creator><pubDate>Fri, 03 Jan 2020 09:08:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-VigilanceMeteoFrance on Sun, 15 Dec 2019 10:17:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grena" aria-label="Profile: grena">@<bdi>grena</bdi></a></p>
<p dir="auto">Merci super cool.<br />
Tiens moins au jus on arrive à la saison des inondation 😋</p>
]]></description><link>https://forum.magicmirror.builders/post/66037</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66037</guid><dc:creator><![CDATA[ELMAGO]]></dc:creator><pubDate>Sun, 15 Dec 2019 10:17:12 GMT</pubDate></item></channel></rss>
