<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspbian is fullscreen, but the MM not]]></title><description><![CDATA[<p dir="auto">Hey.<br />
I have a Problem with the Resolution from the MM Window.</p>
<p dir="auto">I changed in all config (raspbian-config, config.txt the Resolution to 1920x1080.<br />
The system runs fullscreen, but MM not.<br />
Somebody have an idea?</p>
<p dir="auto"><img src="/assets/uploads/files/1576592092739-img_20191217_151342-972x1636.jpg" alt="0_1576592091010_IMG_20191217_151342-972x1636.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/11797/raspbian-is-fullscreen-but-the-mm-not</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 00:50:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11797.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Dec 2019 14:14:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Mon, 07 Feb 2022 20:22:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teandryk" aria-label="Profile: teandryk">@<bdi>teandryk</bdi></a> u can set that in config.js</p>
<p dir="auto">electronOptions: {width: xxx, height: yyy},</p>
<p dir="auto">but it should have done it automatically</p>
]]></description><link>https://forum.magicmirror.builders/post/99426</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99426</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 07 Feb 2022 20:22:10 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Mon, 07 Feb 2022 19:01:39 GMT]]></title><description><![CDATA[<p dir="auto">fount it,<br />
in ~/MagicMirror/js/electron.js in</p>
<p dir="auto">function createWindow()<br />
…<br />
width: 800,<br />
height: 600,<br />
…</p>
<p dir="auto">To get the current resolution:</p>
<p dir="auto">fbset</p>
]]></description><link>https://forum.magicmirror.builders/post/99420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99420</guid><dc:creator><![CDATA[teandryk]]></dc:creator><pubDate>Mon, 07 Feb 2022 19:01:39 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Mon, 07 Feb 2022 18:59:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teandryk" aria-label="Profile: teandryk">@<bdi>teandryk</bdi></a> are u on the  pi display or over vnc</p>
]]></description><link>https://forum.magicmirror.builders/post/99418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99418</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 07 Feb 2022 18:59:00 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Mon, 07 Feb 2022 18:45:37 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the fast reply but it does not work. I done</p>
<p dir="auto">cd ~<br />
pm2 stop <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a><br />
rm -rf .config/Electron<br />
pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a></p>
<p dir="auto">and still have 600x800</p>
]]></description><link>https://forum.magicmirror.builders/post/99415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99415</guid><dc:creator><![CDATA[teandryk]]></dc:creator><pubDate>Mon, 07 Feb 2022 18:45:37 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Mon, 07 Feb 2022 18:31:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teandryk" aria-label="Profile: teandryk">@<bdi>teandryk</bdi></a> do this</p>
<p dir="auto">stop mm</p>
<pre><code>cd ~
<p dir="auto">note the dot in front of config</p>
<p dir="auto">restart mm</p>
]]></description><link>https://forum.magicmirror.builders/post/99413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99413</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 07 Feb 2022 18:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Mon, 07 Feb 2022 18:28:16 GMT]]></title><description><![CDATA[<p dir="auto">Have the same issue and can’t seem to find the answer. Did anyone figure out how to fix it? Can you share, please?</p>
]]></description><link>https://forum.magicmirror.builders/post/99412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99412</guid><dc:creator><![CDATA[teandryk]]></dc:creator><pubDate>Mon, 07 Feb 2022 18:28:16 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Wed, 18 Dec 2019 08:39:00 GMT]]></title><description><![CDATA[<p dir="auto">Hey.<br />
I have no Problems with Black border.<br />
Raspbian is fullscreen.<br />
But MM is only in a small Window.</p>
]]></description><link>https://forum.magicmirror.builders/post/66154</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66154</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Wed, 18 Dec 2019 08:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Tue, 17 Dec 2019 20:50:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Here is how I rotated mine and probably the same method was used.</p>
<p dir="auto"><a href="https://www.youtube.com/watch?v=pCB-CHvc6j0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=pCB-CHvc6j0</a></p>
<p dir="auto">The video also discusses removing the black border as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/66140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66140</guid><dc:creator><![CDATA[BD0G]]></dc:creator><pubDate>Tue, 17 Dec 2019 20:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Tue, 17 Dec 2019 16:19:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a>   how did u rotate the screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/66130</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66130</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Dec 2019 16:19:27 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Tue, 17 Dec 2019 16:17:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> part of the raspi buster setup asks you if you see a border around the screen, if so (looks like yes) it adjusts the overscan</p>
<p dir="auto">to fix, from the buster desktop, top left menu,  select Preferences, Configuration, then System, screen overscan</p>
<p dir="auto">sorry, pic says that is not the problem… MM doesn’t understand rotated to portrait mode</p>
]]></description><link>https://forum.magicmirror.builders/post/66129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Dec 2019 16:17:44 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Tue, 17 Dec 2019 14:24:56 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
No… Only full HD.</p>
]]></description><link>https://forum.magicmirror.builders/post/66127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66127</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Tue, 17 Dec 2019 14:24:56 GMT</pubDate></item><item><title><![CDATA[Reply to Raspbian is fullscreen, but the MM not on Tue, 17 Dec 2019 14:16:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a><br />
Is the monitor UHD(4K)?</p>
]]></description><link>https://forum.magicmirror.builders/post/66126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66126</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 17 Dec 2019 14:16:59 GMT</pubDate></item></channel></rss>
