<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stupid newbie questions]]></title><description><![CDATA[<p dir="auto">This is my very first project of this type, and I’m learning all this from scratch.  I’m going through the Complete Setup Tutorial and I got to the section about screen rotation and what to add in, how do I save the changes I’ve made?</p>
<p dir="auto">Also, I don’t know how to change the settings.  Time, weather, etc.  Is there a first timers guide?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1181/stupid-newbie-questions</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 00:11:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1181.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Dec 2016 12:20:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stupid newbie questions on Fri, 16 Dec 2016 13:01:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> yup went to the file directly</p>
]]></description><link>https://forum.magicmirror.builders/post/9438</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9438</guid><dc:creator><![CDATA[impuislupus]]></dc:creator><pubDate>Fri, 16 Dec 2016 13:01:55 GMT</pubDate></item><item><title><![CDATA[Reply to Stupid newbie questions on Fri, 16 Dec 2016 06:33:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/impuislupus" aria-label="Profile: impuislupus">@<bdi>impuislupus</bdi></a> Did you Rename the config file?</p>
]]></description><link>https://forum.magicmirror.builders/post/9424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9424</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 16 Dec 2016 06:33:48 GMT</pubDate></item><item><title><![CDATA[Reply to Stupid newbie questions on Fri, 16 Dec 2016 05:14:54 GMT]]></title><description><![CDATA[<p dir="auto">So Im new to the this and i seem to hit a wall was able to to get as far as everyone else has in this thread. Ive been using pi 3 everything is update from what i can tell but evey time i run the program it run into the same issue minus the “Error found”… I obtained my API key i slighty edited the file config but still can’t get it to locate it.</p>
<p dir="auto">Loading config …<br />
WARNING! Could not load config file. Starting with default configuration.<br />
Loading module helpers …<br />
No helper found for module: helloworld.<br />
All module helpers loaded.<br />
Starting server op port 8080 …<br />
Server started …<br />
Sockets connected &amp; modules started …</p>
]]></description><link>https://forum.magicmirror.builders/post/9422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9422</guid><dc:creator><![CDATA[impuislupus]]></dc:creator><pubDate>Fri, 16 Dec 2016 05:14:54 GMT</pubDate></item><item><title><![CDATA[Reply to Stupid newbie questions on Tue, 13 Dec 2016 22:18:12 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I think I’ve got it.  Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/9331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9331</guid><dc:creator><![CDATA[DarthMosh]]></dc:creator><pubDate>Tue, 13 Dec 2016 22:18:12 GMT</pubDate></item><item><title><![CDATA[Reply to Stupid newbie questions on Tue, 13 Dec 2016 15:37:15 GMT]]></title><description><![CDATA[<p dir="auto">Using nano to edit the config.txt you just exit nano (ctrl + x) it will then ask you if you want to save your changes, type Y and then enter, that’s it, you are back out to the terminal, reboot your pi and the screen is rotated.</p>
<p dir="auto">If your PI is connected to the net it should have set the time, date and timezone automatically.</p>
<p dir="auto">Each module has a readme-file, all settings are explained in those files.</p>
]]></description><link>https://forum.magicmirror.builders/post/9297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9297</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 13 Dec 2016 15:37:15 GMT</pubDate></item></channel></rss>
