<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen instead of desktop after installing PIR sensor]]></title><description><![CDATA[<p dir="auto">Hi, MM Community,<br />
I recently installed an Adafruit PIR sensor, and configured it using this MagicMirrorCentral guide (<a href="https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/</a>), and I rebooted like the instructions said. Instead of my normal desktop showing up, all I get is a black screen with my cursor on it, but there is nothing to click. I can’t even get to the terminal to run any commands. Please help me with this, what have I done wrong, and how can I fix it?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11835/black-screen-instead-of-desktop-after-installing-pir-sensor</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 04:20:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11835.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Dec 2019 22:25:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 30 Dec 2019 05:59:39 GMT]]></title><description><![CDATA[<p dir="auto">I had a simmilar Problem an had to use my old Backup after investigating hours. It seems that there are Problems between versions of node and electron. Do you have a white Window shortly and then the black desktop screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/66781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66781</guid><dc:creator><![CDATA[Lightspeed]]></dc:creator><pubDate>Mon, 30 Dec 2019 05:59:39 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 30 Dec 2019 02:17:37 GMT]]></title><description><![CDATA[<p dir="auto">I had a similar problem when I used MMM-PIR-Sensor module.  Everything had been working for about 6 months then I updated something and it stoped working.  I re-installed everything several times and through a process of elimination and google searches it acmes down to this particular module.</p>
<p dir="auto">I have now got it a working again by finding the latest update from a branched version of MMM-PIR-Sensor module.</p>
<p dir="auto">I never did find the cause.</p>
]]></description><link>https://forum.magicmirror.builders/post/66777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66777</guid><dc:creator><![CDATA[diccon]]></dc:creator><pubDate>Mon, 30 Dec 2019 02:17:37 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:55:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Been there, done that, didn’t work. I’ve been searching Google for this issue, and came up short. Didn’t find much results, but I will try some more searching,</p>
]]></description><link>https://forum.magicmirror.builders/post/66476</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66476</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:55:33 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:54:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> I might try to change desktop with login</p>
]]></description><link>https://forum.magicmirror.builders/post/66474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66474</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:54:21 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:52:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Boot options, and then what?</p>
]]></description><link>https://forum.magicmirror.builders/post/66473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66473</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:52:22 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:50:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> in the terminal window, if u run sudo raspi-config<br />
and look at boot options…</p>
<p dir="auto">beyond that there are 1 few (hundred) posts about problems  like this if u search google</p>
]]></description><link>https://forum.magicmirror.builders/post/66472</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66472</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:40:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Clicked reconfigure, nothing shows up. Clicked desktop, just shows a list of desktops. Shows 4 desktops. I’ve been through them all, shows the same black screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/66471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66471</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:40:22 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:37:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> ok, select Desktops or reconfigure</p>
]]></description><link>https://forum.magicmirror.builders/post/66470</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66470</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:37:52 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:37:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> This is what mine looks like. The white bar at the top of the screen is vnc viewer, not the screen. I’m using vnc viewer on my laptop.<br />
<img src="/assets/uploads/files/1577118979651-fb54c8d6-fef4-4369-b632-05227fd16e62-image.png" alt="0_1577118980626_fb54c8d6-fef4-4369-b632-05227fd16e62-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/66469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66469</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:37:01 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:33:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> if u right click, does the popup menu have desktop preferences?<br />
is should</p>
<p dir="auto"><a href="https://forum.lxde.org/viewtopic.php?f=8&amp;t=31338" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.lxde.org/viewtopic.php?f=8&amp;t=31338</a></p>
]]></description><link>https://forum.magicmirror.builders/post/66468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66468</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:28:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> This is Raspbian Stretch, yep.</p>
]]></description><link>https://forum.magicmirror.builders/post/66467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66467</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:26:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> this is stretch  or???</p>
<p dir="auto">lsb_release -a  in the terminal window</p>
]]></description><link>https://forum.magicmirror.builders/post/66466</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66466</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:26:50 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:26:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Exactly. It seems to be running, but my wallpaper, taskbar, and icons are gone. Black screen shows in its place.</p>
]]></description><link>https://forum.magicmirror.builders/post/66465</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66465</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:26:13 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:25:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> said in <a href="/post/66463">Black screen instead of desktop after installing PIR sensor</a>:</p>
<p dir="auto">by right clicking somewhere on the screen</p>
<p dir="auto">ok, so desktop is running, even tho u might not be able to see it…</p>
]]></description><link>https://forum.magicmirror.builders/post/66464</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66464</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I could only get to terminal, by right clicking somewhere on the screen. I tried stopping MM using pm2, didn’t have any effect.</p>
]]></description><link>https://forum.magicmirror.builders/post/66463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66463</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:21:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> but it can’t hurt to stop it…</p>
<p dir="auto">if you can get to terminal, then its not a desktop problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/66462</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66462</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:21:24 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:21:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I cannot ssh into it. I am able to access the terminal though. MM is running on pm2, I just setup an autostart script for it. I don’t think MM is causing the issue, because the issue started just when I was setting up the PIR sensor.</p>
]]></description><link>https://forum.magicmirror.builders/post/66460</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66460</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:21:10 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:17:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> can u ssh into the machine?</p>
<p dir="auto">is MM running on pm2?  do pm2 status, and if not stopped do pm2 stop for each line (use number or name)</p>
]]></description><link>https://forum.magicmirror.builders/post/66459</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66459</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:17:29 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> Ahh, its ok. Thanks for your help, I’ll figure something out.</p>
]]></description><link>https://forum.magicmirror.builders/post/66458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66458</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:09:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> As said, copy the whole MM-folder, eg. via scp to another PC and then reinstall Raspbian.<br />
I’m sorry that I can’t provide a more satisfying solution:disappointed_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/66456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66456</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:08:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> I can’t reinstall Raspbian because this is for a science fair project, due in two weeks, and I put too much work into it for me to be able to finish on time if I reinstall. There has to be a way to get my desktop back without reinstalling.</p>
]]></description><link>https://forum.magicmirror.builders/post/66455</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66455</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:08:50 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 16:05:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> MagicMirror framework is installed, yes.</p>
]]></description><link>https://forum.magicmirror.builders/post/66454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66454</guid><dc:creator><![CDATA[09succotash]]></dc:creator><pubDate>Mon, 23 Dec 2019 16:05:09 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen instead of desktop after installing PIR sensor on Mon, 23 Dec 2019 15:43:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/09succotash" aria-label="Profile: 09succotash">@<bdi>09succotash</bdi></a> Umpf…the last thing that comes to my mind…disconnect the PIR-Sensor from GPIO. Maybe it is not connected to the right pins, which may cause that strange behaviour.</p>
<p dir="auto">Do you have the MM-software installed? If so, then copy the whole MagicMirror directory to a save place and reinstall Raspbian from scratch. It’s probably the fastest and easiest solution after all, if nothing else is installed on the RPi.</p>
<p dir="auto">Maybe someone else here in the forum can help? Guys?</p>
]]></description><link>https://forum.magicmirror.builders/post/66445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66445</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Mon, 23 Dec 2019 15:43:17 GMT</pubDate></item></channel></rss>
