<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Display not bright enough]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">After a long search for the right parts and waiting for them to ship, I finally finished my first MM.<br />
<strong>I’ve used:</strong></p>
<ul>
<li>A deep ikea frame 50x70 <a href="https://www.ikea.com/nl/nl/p/hovsta-fotolijst-donkerbruin-30396325/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ikea.com/nl/nl/p/hovsta-fotolijst-donkerbruin-30396325/</a></li>
<li>Large piece of two way mirror I found online and had cut in 4 pieces of 50x70</li>
<li>RPi 3B</li>
<li>15" display from a (super) old monitor that had model no b156wx01</li>
<li>LCD controller that fit the display model no.</li>
<li>currently ducktaped everything to the back panel. Planning on using velcro.</li>
</ul>
<p dir="auto">Now that the mirror is in place, i’d like to follow up with improvements on issues that I encountered. Hope you guys have tips</p>
<p dir="auto"><strong>Learnings</strong></p>
<ol>
<li>
<p dir="auto">The most important one for me: The display is by far not bright enough. So bad that I can’t even see it’s on during the day. Now I understand this can be the mirror too, but I was hoping to fix that with a brighter display. Adjusting the brightness on the display only makes the picture more white. Can this be related to the power adapter I’m using? Might a higher voltage/wattage help here?<br />
If not, i’d like to order a new display, but I have no idea on what to look for when searching for a more powerful display. Will an LED display do the trick?</p>
</li>
<li>
<p dir="auto">I need 2 power supplies. 1 for the Pi. 1 for the display. Does anyone know of a display that charges by USB? Or does anyone have tips for only needing 1 power supply?</p>
</li>
<li>
<p dir="auto">The frame is not made to hold glass this heavy. I have to be very careful. I, unfortunately do not have the right tools at reach to build my own (sturdy) and clean frame. I really prefer something as thin as the Ikea frame. Knowing how difficult it is to find a good piece of two-way glass for a decent price. I have 3 left. If anyone can make/ or has a good spare frame 50x70 cm I’m willing to trade one of my two-way mirror glass pieces for a frame. I’m located in the Netherlands.</p>
</li>
</ol>
<p dir="auto"><strong>Pics</strong><br />
<img src="/assets/uploads/files/1577369456986-schermafbeelding-2019-12-26-om-15.10.23.png" alt="0_1577369456359_Schermafbeelding 2019-12-26 om 15.10.23.png" class=" img-fluid img-markdown" /><br />
will post more soon (when it’s dark :smiling_face_with_open_mouth_cold_sweat: )</p>
]]></description><link>https://forum.magicmirror.builders/topic/11860/display-not-bright-enough</link><generator>RSS for Node</generator><lastBuildDate>Fri, 14 Aug 2026 12:22:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11860.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Dec 2019 14:06:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Display not bright enough on Fri, 27 Dec 2019 15:06:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: MadScientist">@<bdi>MadScientist</bdi></a> said in <a href="/post/66641">Display not bright enough</a>:</p>
<p dir="auto">Hi there,<br />
what you want is a display with high contrast. I think VA panels have the best.</p>
<p dir="auto">I can fully confirm the better contrast on VA panels compared to TN panels.</p>
]]></description><link>https://forum.magicmirror.builders/post/66674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66674</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Fri, 27 Dec 2019 15:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to Display not bright enough on Fri, 27 Dec 2019 12:48:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
what you want is a display with high contrast. I think VA panels have the best. At least on paper.</p>
<p dir="auto">To power my mirror I use a 12V power supply for the LCD and a buck converter to reduce the 12V to 5V for my RasPi. That’s a dirt cheap solution which is working really well for more than 2 years.<br />
There are also really, really cheap universal LCD controller boards that run on 5V only (around 4-5€, up to FullHD resolution, 30 pin LVDS, 2-CH, 8-bit) You configure them via jumpers. Although they have only a VGA output. Which means you’ll need an additional VGA to HDMI adapter (usually less than 3€). T</p>
<p dir="auto">And of course: In bright conditions you should pick a mirror with a higher transmission rate. In darker conditions a lower transmission rate will do.  What mirror have you got?</p>
]]></description><link>https://forum.magicmirror.builders/post/66641</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66641</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Fri, 27 Dec 2019 12:48:34 GMT</pubDate></item><item><title><![CDATA[Reply to Display not bright enough on Thu, 26 Dec 2019 19:47:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xdenneboom" aria-label="Profile: xdenneboom">@<bdi>xdenneboom</bdi></a> I also have an IKEA Ribba Frame 70x50 cm² with the same setup (Chinese controller board controls 24’’ LCD-Screen from an old TV). For Power Supply I use a 12 V DC  external adaptor and a step down converter to get the 5V for the Pi from the 12V supply of the frame.</p>
<p dir="auto">I reinforced the Frame on the top inside with a small latch, glued the glass in the frame to improve stability and took some wooden latches to mount the display on the original backplate (see picture). <img src="/assets/uploads/files/1577389644737-img_1267.jpg" alt="0_1577389644465_IMG_1267.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/66611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66611</guid><dc:creator><![CDATA[rabbit83ka]]></dc:creator><pubDate>Thu, 26 Dec 2019 19:47:28 GMT</pubDate></item><item><title><![CDATA[Reply to Display not bright enough on Thu, 26 Dec 2019 15:14:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xdenneboom" aria-label="Profile: xdenneboom">@<bdi>xdenneboom</bdi></a>  I have an IKEA frame, too (Ribba), but mounted a second one behind a he first too gain more depth. Here <a href="https://forum.magicmirror.builders/topic/11610/drrrrums-please-my-first-magicmirror?page=1">is my mirror</a> where you can see how I managed the power supply for the display and the RPi.<br />
Regarding the brightness of your display try to enhance the contrast instead of the brightness only.</p>
]]></description><link>https://forum.magicmirror.builders/post/66601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66601</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Thu, 26 Dec 2019 15:14:24 GMT</pubDate></item></channel></rss>
