<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror not starting]]></title><description><![CDATA[<p dir="auto">My MagicMirror is not starting. It used to. Here is the pm2 log <a href="https://hastebin.com/zeyoqidura.js" target="_blank" rel="noopener noreferrer nofollow ugc">https://hastebin.com/zeyoqidura.js</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/11864/magicmirror-not-starting</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 03:41:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11864.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Dec 2019 06:11:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror not starting on Fri, 27 Dec 2019 18:41:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aimorris" aria-label="Profile: aimorris">@<bdi>aimorris</bdi></a> Not sure I can help. I am not really good analyzing logs but I could see this</p>
<pre><code>ssh_askpass: exec(/usr/bin/ssh-askpass): No such file or directory
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists
<p dir="auto">Are you trying to start MM remotely? Does MM require root (sudo)? If you start it remotely, have you tried to start it locally?</p>
]]></description><link>https://forum.magicmirror.builders/post/66682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66682</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Fri, 27 Dec 2019 18:41:26 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror not starting on Fri, 27 Dec 2019 12:45:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aimorris" aria-label="Profile: aimorris">@<bdi>aimorris</bdi></a> sorry, nothing shows at the link</p>
]]></description><link>https://forum.magicmirror.builders/post/66639</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66639</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Dec 2019 12:45:57 GMT</pubDate></item></channel></rss>
