<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Current weather doesn't work]]></title><description><![CDATA[<p dir="auto">My setup is almost done but my current weather module doesn’t work, the Weather Forecast module is working without problem. The settings are the same for the two modules, i tried a separate api-key for current weather module but that didn’t help. The header for the module is working but the data is no go.</p>
<p dir="auto">Any suggestions on how to solve this?<br />
<img src="http://i66.tinypic.com/33epf1d.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/1187/current-weather-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 18:13:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1187.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Dec 2016 08:49:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Current weather doesn't work on Wed, 14 Dec 2016 17:18:01 GMT]]></title><description><![CDATA[<p dir="auto">you’re welcome</p>
]]></description><link>https://forum.magicmirror.builders/post/9368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9368</guid><dc:creator><![CDATA[chrisfoerg]]></dc:creator><pubDate>Wed, 14 Dec 2016 17:18:01 GMT</pubDate></item><item><title><![CDATA[Reply to Current weather doesn't work on Wed, 14 Dec 2016 16:25:12 GMT]]></title><description><![CDATA[<p dir="auto">I replaced “currentweather.js” from github and now it’s working. Thanks for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/9360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9360</guid><dc:creator><![CDATA[sweup]]></dc:creator><pubDate>Wed, 14 Dec 2016 16:25:12 GMT</pubDate></item><item><title><![CDATA[Reply to Current weather doesn't work on Wed, 14 Dec 2016 15:57:37 GMT]]></title><description><![CDATA[<p dir="auto">is it running without the header part?</p>
]]></description><link>https://forum.magicmirror.builders/post/9356</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9356</guid><dc:creator><![CDATA[chrisfoerg]]></dc:creator><pubDate>Wed, 14 Dec 2016 15:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to Current weather doesn't work on Wed, 14 Dec 2016 15:46:45 GMT]]></title><description><![CDATA[<p dir="auto">I think there is a problem with the js files. Your config is working on my magic mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/9355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9355</guid><dc:creator><![CDATA[chrisfoerg]]></dc:creator><pubDate>Wed, 14 Dec 2016 15:46:45 GMT</pubDate></item><item><title><![CDATA[Reply to Current weather doesn't work on Wed, 14 Dec 2016 14:50:36 GMT]]></title><description><![CDATA[<p dir="auto">Thx for reply</p>
<p dir="auto">{<br />
module: ‘currentweather’,<br />
position: ‘top_right’,<br />
header: ‘Värt just nu’,<br />
config: {<br />
locationID: ‘2711537’,  //ID from <a href="http://www.openweathermap.org" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.openweathermap.org</a><br />
appid: ‘12345’<br />
}<br />
},<br />
{<br />
module: ‘weatherforecast’,<br />
header: ‘Värt’,<br />
config: {<br />
}<br />
},</p>
]]></description><link>https://forum.magicmirror.builders/post/9352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9352</guid><dc:creator><![CDATA[sweup]]></dc:creator><pubDate>Wed, 14 Dec 2016 14:50:36 GMT</pubDate></item><item><title><![CDATA[Reply to Current weather doesn't work on Wed, 14 Dec 2016 09:09:43 GMT]]></title><description><![CDATA[<p dir="auto">can you post your config?</p>
]]></description><link>https://forum.magicmirror.builders/post/9345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9345</guid><dc:creator><![CDATA[chrisfoerg]]></dc:creator><pubDate>Wed, 14 Dec 2016 09:09:43 GMT</pubDate></item></channel></rss>
