<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Fuel doesn't work]]></title><description><![CDATA[<p dir="auto">Hello,<br />
i hope anyone can help me.<br />
I want to use the modul “MMM-Fuel”.<br />
It doesn’t work. it is not displayed.<br />
here is my entry in the config-file:</p>
<p dir="auto">{<br />
module: “MMM-Fuel”,<br />
position: “botton_left”,<br />
config: {<br />
api_key: “*************************”,<br />
lat: 49.9556351,<br />
lng: 9.772477,<br />
types: [“diesel”],<br />
}<br />
}</p>
<p dir="auto">following message is generated:</p>
<p dir="auto">request to <a href="https://creativecommons.tankerkoenig.de/json/list.php?lat=49.9556351&amp;lng=9.772477&amp;rad=5&amp;type=all&amp;apikey=*mykey&amp;sort=dist" target="_blank" rel="noopener noreferrer nofollow ugc">https://creativecommons.tankerkoenig.de/json/list.php?lat=49.9556351&amp;lng=9.772477&amp;rad=5&amp;type=all&amp;apikey=*mykey&amp;sort=dist</a> failed, reason: getaddrinfo EAI_AGAIN <a href="http://creativecommons.tankerkoenig.de" target="_blank" rel="noopener noreferrer nofollow ugc">creativecommons.tankerkoenig.de</a> <a href="http://creativecommons.tankerkoenig.de:443" target="_blank" rel="noopener noreferrer nofollow ugc">creativecommons.tankerkoenig.de:443</a>’</p>
<p dir="auto">thanks for your help</p>
<p dir="auto">best regards<br />
Oliver</p>
]]></description><link>https://forum.magicmirror.builders/topic/11875/mmm-fuel-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 19:17:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11875.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Dec 2019 20:03:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Fuel doesn't work on Mon, 30 Dec 2019 18:03:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oli1204" aria-label="Profile: oli1204">@<bdi>oli1204</bdi></a> glad that it works now!</p>
]]></description><link>https://forum.magicmirror.builders/post/66842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66842</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:03:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel doesn't work on Mon, 30 Dec 2019 17:28:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fozi" aria-label="Profile: Fozi">@<bdi>Fozi</bdi></a> said in <a href="/post/66769">MMM-Fuel doesn't work</a>:</p>
<p dir="auto">s the same error thrown?</p>
<p dir="auto">hello,</p>
<p dir="auto">its so embarassing. the mistake was really botton instead of bottom.</p>
<p dir="auto">very much thanks for your help.</p>
<p dir="auto">best regards</p>
<p dir="auto">Olivr</p>
]]></description><link>https://forum.magicmirror.builders/post/66833</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66833</guid><dc:creator><![CDATA[oli1204]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:28:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel doesn't work on Sun, 29 Dec 2019 21:25:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oli1204" aria-label="Profile: oli1204">@<bdi>oli1204</bdi></a> There seems to be a problem with the DNS resolution. Just for curiosity… Could you try the <a href="https://github.com/terenc3/MMM-Tankerkoenig" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Tankerkoenig</a> Module? It basically does the same as MMM-Fuel.</p>
<p dir="auto">Is the same error thrown?</p>
<p dir="auto">BTW: The position is misspelled…it must be “botto<strong>m</strong>_left”</p>
]]></description><link>https://forum.magicmirror.builders/post/66769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66769</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Sun, 29 Dec 2019 21:25:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel doesn't work on Sun, 29 Dec 2019 20:14:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/66762">MMM-Fuel doesn't work</a>:</p>
<p dir="auto">nslookup from a terminal window</p>
<p dir="auto">thanks for your help…but i don 't know what to do…<br />
sorry this is my first Magicmirror…</p>
]]></description><link>https://forum.magicmirror.builders/post/66763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66763</guid><dc:creator><![CDATA[oli1204]]></dc:creator><pubDate>Sun, 29 Dec 2019 20:14:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fuel doesn't work on Sun, 29 Dec 2019 20:06:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oli1204" aria-label="Profile: oli1204">@<bdi>oli1204</bdi></a> said in <a href="/post/66761">MMM-Fuel doesn't work</a>:</p>
<p dir="auto">getaddrinfo EAI_AGAIN</p>
<p dir="auto">this says that your system cannot find that entry via name resolution</p>
<p dir="auto">nslookup  <a href="http://creativecommons.tankerkoenig.de" target="_blank" rel="noopener noreferrer nofollow ugc">creativecommons.tankerkoenig.de</a></p>
<p dir="auto">on my system  it looks like this</p>
<pre><code>nslookup  creativecommons.tankerkoenig.de
Server:  dns9.quad9.net
Address:  9.9.9.9  // &lt; --- my name server
Non-authoritative answer:
Address:  188.68.35.147
]]></description><link>https://forum.magicmirror.builders/post/66762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66762</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Dec 2019 20:06:18 GMT</pubDate></item></channel></rss>
