<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror will not boot but Pi will, Cache issue?]]></title><description><![CDATA[<p dir="auto">The pi will boot but Magic Mirror won’t. I believe I’m having issues with the cache. It was working for a long time but I have since relocated the mirror and it no longer boots the MM program. when I run npm start i get “no helper found for module” and when I try to update my MM program I get “you dont have enough space var/cache/apt/archives”. Any help would be appreciated as it ran quite well a while ago. Do the modules build up data after being run 24/7? I’m also not entirely sure what a cache is if anybody could help. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11881/magic-mirror-will-not-boot-but-pi-will-cache-issue</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 03:47:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11881.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Dec 2019 16:22:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:47:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> the bigger disk will help…</p>
<p dir="auto">the Wolfram stuff is eating a lot of space.,</p>
<p dir="auto">but I don’t see anything else really large taking a lot of space…  MagicMirror is only taking about 10%<br />
home folder is under 15%</p>
]]></description><link>https://forum.magicmirror.builders/post/66854</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66854</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:47:15 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:37:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’m just curious how you think it went over 80% total capacity? Will this continue to happen over time? Or should i just buy a 16gig SD and it will likely solve the issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/66853</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66853</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:37:57 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:33:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> said in <a href="/post/66850">Magic Mirror will not boot but Pi will, Cache issue?</a>:</p>
<p dir="auto">I don’t know what that means haha</p>
<p dir="auto">the du command dumps out blocks used, and does it by folder.</p>
<p dir="auto">in the last screenshot, there are 13040 blocks used for the entire /var/log subtree<br />
there are 6846289 blocks of space on the memory card disk volume…  so, divide</p>
<p dir="auto">(13040*100) by 6846289 to get the percentage used = 0.19046815%</p>
<p dir="auto">in system design, if u ever got over 80% used of the total capacity (memory, cpu, disk space), the system is in danger of failure ‘soon’… (I am a long time (45 yrs) computer system solution designer)</p>
]]></description><link>https://forum.magicmirror.builders/post/66852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66852</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:33:30 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:26:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/66848">Magic Mirror will not boot but Pi will, Cache issue?</a>:</p>
<p dir="auto">o</p>
]]></description><link>https://forum.magicmirror.builders/post/66850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66850</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:26:01 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:26:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> so, all the space is used IN the /var/log folder itself, not subfolders…</p>
<p dir="auto">but 13040 is a tiny 0.1%   WAY below the critical threshold… (if u are over 80% used, you are in trouble)</p>
]]></description><link>https://forum.magicmirror.builders/post/66848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66848</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:18:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <img src="/assets/uploads/files/1577729903864-58f7d43d-6607-4c09-9993-a57e643fa893-image.png" alt="0_1577729903525_58f7d43d-6607-4c09-9993-a57e643fa893-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/66847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66847</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> sorry, typo</p>
<pre><code> du  /var/log 2&gt;/dev/null
<p dir="auto">may need sudo</p>
<pre><code>sudo du  /var/log 2&gt;/dev/null
]]></description><link>https://forum.magicmirror.builders/post/66846</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66846</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 18:09:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Permission denied. Also tried it with /logs and /log. /log says “is a directory” and the latter says permission denied</p>
]]></description><link>https://forum.magicmirror.builders/post/66845</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66845</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 18:09:23 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:45:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> logs are pretty small… do the du /var/logs | sort | head thing, just on the logs folder…</p>
]]></description><link>https://forum.magicmirror.builders/post/66839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66839</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:45:31 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:44:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I guess I need to delete the wolfram. I’m using an 8GB but I have’t manually changed anything so I’m surprised that it doesn’t work anymore. Maybe the logs put it over the edge.</p>
]]></description><link>https://forum.magicmirror.builders/post/66838</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66838</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:40:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> its not the logs… not even showing in the top 20.</p>
<p dir="auto">that /opt/Wolfram is taking 16.7 % or disk space (1146764/6846289)<br />
/usr/lib &amp; share is taking 53%<br />
I would guess that your memory card is too small…</p>
<p dir="auto">what size is it?<br />
what did u add last?</p>
]]></description><link>https://forum.magicmirror.builders/post/66837</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66837</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:40:42 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:34:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I pasted the wrong image. Thanks for your patience with me</p>
<p dir="auto"><img src="/assets/uploads/files/1577727272135-ff6f75b7-7d77-4203-b3c3-6b434617c8a2-image.png" alt="0_1577727269763_ff6f75b7-7d77-4203-b3c3-6b434617c8a2-image.png" class=" img-fluid img-markdown" /> Screen Shot 2019-12-30 at 11.25.35 AM</p>
]]></description><link>https://forum.magicmirror.builders/post/66835</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66835</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:31:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> need with head -n 20, to give more lines of output</p>
<p dir="auto">/opt/Wolfram is taking a bit of space</p>
]]></description><link>https://forum.magicmirror.builders/post/66834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66834</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:31:00 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:26:03 GMT]]></title><description><![CDATA[<p dir="auto">I hope you can decipher this haha</p>
<p dir="auto"><img src="/assets/uploads/files/1577726761198-d55e67d9-9db4-4a13-9820-e92f4186c64d-image.png" alt="0_1577726759666_d55e67d9-9db4-4a13-9820-e92f4186c64d-image.png" class=" img-fluid img-markdown" />  Screen Shot 2019-12-30 at 11.04.44 AM</p>
]]></description><link>https://forum.magicmirror.builders/post/66832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66832</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:26:03 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:07:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> change head -n 10 to -n 20</p>
]]></description><link>https://forum.magicmirror.builders/post/66831</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66831</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:07:28 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:05:27 GMT]]></title><description><![CDATA[<p dir="auto">Okay so after typing correctly (my apologies, im not very savvy in this)</p>
<p dir="auto"><img src="/assets/uploads/files/1577725524274-910bc738-b0da-4dea-96a3-1b1e1ecdf7ba-image.png" alt="0_1577725523781_910bc738-b0da-4dea-96a3-1b1e1ecdf7ba-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Screen Shot 2019-12-30 at 11.04.44 AM</p>
]]></description><link>https://forum.magicmirror.builders/post/66830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66830</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:05:27 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:02:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> thats only of your home folder… usually not a problem</p>
<p dir="auto">notice I had /</p>
<pre><code>du -a / 2&gt;/dev/null | sort -n -r | head -n 10
]]></description><link>https://forum.magicmirror.builders/post/66828</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66828</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:02:26 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 17:02:09 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1577725265887-95c0ffa2-6bf6-459a-9e75-d1ee858e6efa-image.png" alt="0_1577725265087_95c0ffa2-6bf6-459a-9e75-d1ee858e6efa-image.png" class=" img-fluid img-markdown" /> Screen Shot 2019-12-30 at 11.00.55 AM</p>
<p dir="auto">So this is what that displays. And I really don’t understand why it is taking up so much space because it worked previously. I don’t know what to remove to give more space?</p>
]]></description><link>https://forum.magicmirror.builders/post/66827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66827</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 17:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 16:59:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> ok, disk is full…</p>
<p dir="auto">the du thing above should give u a clue where…</p>
]]></description><link>https://forum.magicmirror.builders/post/66826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66826</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 16:59:30 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 16:58:27 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1577725103670-2b034e88-3f97-4120-9de1-0917fd88bb51-image.png" alt="0_1577725102433_2b034e88-3f97-4120-9de1-0917fd88bb51-image.png" class=" img-fluid img-markdown" /> Screen Shot 2019-12-30 at 10.58.00 AM</p>
]]></description><link>https://forum.magicmirror.builders/post/66825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66825</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 16:58:27 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 16:56:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> do a df -k<br />
it will give u a quick look at used disk space</p>
<pre><code>/dev/root                30358348    6863684   22210168  24% /
]]></description><link>https://forum.magicmirror.builders/post/66824</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66824</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 16:56:44 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 16:55:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a> the system keeps track of all kinds of things…</p>
<p dir="auto">i don’t know why now vs before… you would have to find the next newest log file and scan thru it to try to determine what (if anything) important is going on<br />
here is my list of files in /var/log</p>
<pre><code>alternatives.log  btmp             dpkg.log        lightdm        syslog       user.log
apt               daemon.log       faillog         messages       syslog.1     user.log.1
auth.log          daemon.log.1     fontconfig.log  messages.1     syslog.2.gz  wtmp
auth.log.1        daemon.log.2.gz  kern.log        messages.2.gz  syslog.3.gz  Xorg.0.log
auth.log.2.gz     daemon.log.3.gz  kern.log.1      messages.3.gz  syslog.4.gz  Xorg.0.log.old
auth.log.3.gz     debug            kern.log.2.gz   mongodb        syslog.5.gz
boot.log          debug.1          kern.log.3.gz   motion         syslog.6.gz
bootstrap.log     debug.2.gz       lastlog         private        syslog.7.gz
]]></description><link>https://forum.magicmirror.builders/post/66823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66823</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 16:55:55 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 16:51:32 GMT]]></title><description><![CDATA[<p dir="auto">So I am unsure why it was working a month ago but is not working now. Is it always going to run out of space? Do I need a bigger sd card? What exactly are the purposes of the log files?</p>
]]></description><link>https://forum.magicmirror.builders/post/66822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66822</guid><dc:creator><![CDATA[tkaauf32]]></dc:creator><pubDate>Mon, 30 Dec 2019 16:51:32 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror will not boot but Pi will, Cache issue? on Mon, 30 Dec 2019 16:46:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tkaauf32" aria-label="Profile: tkaauf32">@<bdi>tkaauf32</bdi></a></p>
<p dir="auto">no helper for module is ok, if the module doesn’t have helper… but u may be out of space</p>
<p dir="auto">review /var/log for dusplicates of log files</p>
<p dir="auto">syslog.n (these are old, probably ok to delete)<br />
and syslog</p>
<p dir="auto">etc</p>
<p dir="auto">this might give u an idea where space is used</p>
<p dir="auto">note that this starts at the root…  I have a remote volume attached so it searches that too… ugh<br />
and it only shows the top 10…   head -n 10, u can up that number… but mostly bet its the logs</p>
]]></description><link>https://forum.magicmirror.builders/post/66821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66821</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Dec 2019 16:46:50 GMT</pubDate></item></channel></rss>
