<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Directory problems after I Install MagicMirror2]]></title><description><![CDATA[<p dir="auto">Summary MagicMirror appears to mess up my directory commands.</p>
<p dir="auto">When I install Raspbian on my Raspberry Pi 3B, it seems that the directory functions work fine.  For example code like this works fine:  cd ~/games The ls command also runs fine.  Other programs run well.  I can see the directories and sub directories and get to them.    The I follow the bash -c “$(curl -sL <a href="https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh</a>)”  The program get installed and magicmirror2 runs well upon pressing entry.   I can modify the files as shown in the tutorials.</p>
<p dir="auto">Very Nice</p>
<p dir="auto">However, when I restart the computer, I don’t seem to have a way to use the command cd ~/MagicMirror &amp;&amp; DISPLAY=:0 npm start.    The command cd~/magicmirror doesn’t work  -  It shows no directory by that name.  When I go to the root directory and enter " ls" command I see that the magicmirror directory does exist.  The string " cd ~/MagicMirror &amp;&amp; DISPLAY=:0 npm start" cannot find the magicmirror command.</p>
<p dir="auto">Your thoughts are much appreciated<br />
Dave</p>
]]></description><link>https://forum.magicmirror.builders/topic/11882/directory-problems-after-i-install-magicmirror2</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 04:36:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11882.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Dec 2019 01:25:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Directory problems after I Install MagicMirror2 on Tue, 31 Dec 2019 02:01:07 GMT]]></title><description><![CDATA[<p dir="auto">Also. Please use the updated install script from here<br />
<a href="https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer">https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer</a></p>
]]></description><link>https://forum.magicmirror.builders/post/66860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66860</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Dec 2019 02:01:07 GMT</pubDate></item><item><title><![CDATA[Reply to Directory problems after I Install MagicMirror2 on Tue, 31 Dec 2019 01:53:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davdij2525" aria-label="Profile: Davdij2525">@<bdi>Davdij2525</bdi></a> did u run the install script as root user? sudo  su?</p>
<p dir="auto">Please reinstall as a normal user, typically logged on as pi</p>
]]></description><link>https://forum.magicmirror.builders/post/66859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66859</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Dec 2019 01:53:24 GMT</pubDate></item></channel></rss>
