<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading]]></title><description><![CDATA[<p dir="auto">Does anyone else use this module/anyone having trouble with it?</p>
<p dir="auto">I got my API keys and set up the config file. When I launch MM, not only does the PlaceInfo module not load (when set to either top_center or bottom_center), but none of my modules will load besides top_left, top_center, and middle_center regions. I’m getting no errors in the terminal. Here is my config.js entry:</p>
<pre><code>{
module: 'MMM-PlaceInfo',
position: 'top-center',
weatherAPIKey: "myopenweatherAPIkey",
currencyAPIKey: "myfixer.ioAPIkey",
currencyPrecision: 2,
currencyRelativeTo: 'USD',
places: [
title: "London",
flag: "gb",
currency: "GBP",
timezone: "Europe/London",
weatherID: "2643743",
title: "Tokyo",
flag: "jp",
currency: "JPY",
timezone: "Asia/Tokyo",
weatherID: "1857910",
]]></description><link>https://forum.magicmirror.builders/topic/11895/https-github-com-njwilliams-mmm-placeinfo-not-loading</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 12:34:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11895.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Dec 2019 18:26:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Mon, 30 Jun 2025 17:19:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/lmhmm" aria-label="Profile: lmhmm">@<bdi>lmhmm</bdi></a></p>
<p dir="auto">I finally managed to get the module running. I used the following fork</p>
<p dir="auto"><a href="https://github.com/magicmirror-sdmy/MMM-PlaceInfo" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/magicmirror-sdmy/MMM-PlaceInfo</a></p>
<p dir="auto">Thanks once again for the help from you both</p>
]]></description><link>https://forum.magicmirror.builders/post/127145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127145</guid><dc:creator><![CDATA[Zoltan]]></dc:creator><pubDate>Mon, 30 Jun 2025 17:19:34 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Sun, 29 Jun 2025 14:37:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lmhmm" aria-label="Profile: lmhmm">@<bdi>lmhmm</bdi></a><br />
Thanks all. I am much closer than before. I now at least have a visual of the module. I however currently see on the mirror the following just below the Flag, City, Time.</p>
<p dir="auto">Currency failed (401)<br />
Weather failed (HTTP 400)</p>
<p dir="auto">I think it might be that i am blocked being in South Africa but i will still try a few things</p>
<p dir="auto">Thanks so much for the advise and help, its much appreciated</p>
]]></description><link>https://forum.magicmirror.builders/post/127127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127127</guid><dc:creator><![CDATA[Zoltan]]></dc:creator><pubDate>Sun, 29 Jun 2025 14:37:20 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Sun, 29 Jun 2025 06:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I use this very successfully and it works fully for weather and currency.</p>
<p dir="auto">The secret is to use apilayer not fixer make these alterations:</p>
<p dir="auto">Line57 <a href="https://api.apilayer.com/fixer/latest" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.apilayer.com/fixer/latest</a></p>
<p dir="auto">58&amp;59, 151 GBP</p>
<p dir="auto">460 ?apikey=</p>
<p dir="auto">That’s it just change in the js file. I don’t know but I downloaded the Open Weather module and it still keeps working for this. I have AccuWeatherDeluxe installed also.</p>
<p dir="auto">So nothing new on weather.</p>
<p dir="auto">It’s a great module,</p>
<p dir="auto">Good Luck,</p>
<p dir="auto">Lorraine</p>
]]></description><link>https://forum.magicmirror.builders/post/127117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127117</guid><dc:creator><![CDATA[lmhmm]]></dc:creator><pubDate>Sun, 29 Jun 2025 06:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Wed, 25 Jun 2025 15:16:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zoltan" aria-label="Profile: Zoltan">@<bdi>Zoltan</bdi></a> did that solve the problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/127075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127075</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Jun 2025 15:16:44 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Mon, 23 Jun 2025 18:01:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks very much for the heads up. I remember now when one of my displays crashed due to the 2.5 that had to be changed to 3.0.  Thanks for the quick response</p>
]]></description><link>https://forum.magicmirror.builders/post/127058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127058</guid><dc:creator><![CDATA[Zoltan]]></dc:creator><pubDate>Mon, 23 Jun 2025 18:01:37 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Sun, 29 Jun 2025 11:25:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zoltan" aria-label="Profile: Zoltan">@<bdi>Zoltan</bdi></a> the latest problems are because<br />
Openweather changed their business model and require user to supply credit card to use the new /onecall endpoint</p>
<p dir="auto">So you have to set apiversion to 3.0 and the endpoint to /onecall</p>
<p dir="auto"><img src="/assets/uploads/files/1750625477394-img_1611.png" alt="IMG_1611.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/127052</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127052</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Jun 2025 11:25:29 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Sun, 22 Jun 2025 19:02:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dresch360" aria-label="Profile: Dresch360">@<bdi>Dresch360</bdi></a><br />
I suspect it is a “,” issue but I also cant seem to figure it. Did you manage?</p>
]]></description><link>https://forum.magicmirror.builders/post/127051</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/127051</guid><dc:creator><![CDATA[Zoltan]]></dc:creator><pubDate>Sun, 22 Jun 2025 19:02:03 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Mon, 21 Jun 2021 02:01:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dresch360" aria-label="Profile: dresch360">@<bdi>dresch360</bdi></a> can u open the developers window. ctrl-shift-i on the mirror keyboard  and select the console tab</p>
]]></description><link>https://forum.magicmirror.builders/post/92263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92263</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Jun 2021 02:01:39 GMT</pubDate></item><item><title><![CDATA[Reply to https:&#x2F;&#x2F;github.com&#x2F;njwilliams&#x2F;MMM-PlaceInfo not loading on Mon, 21 Jun 2021 01:40:53 GMT]]></title><description><![CDATA[<p dir="auto">I’m having the same issue. Any updates?</p>
]]></description><link>https://forum.magicmirror.builders/post/92262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92262</guid><dc:creator><![CDATA[Dresch360]]></dc:creator><pubDate>Mon, 21 Jun 2021 01:40:53 GMT</pubDate></item></channel></rss>
