<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM doesn't load after update. Hangs Pi]]></title><description><![CDATA[<p dir="auto">I wanted to work on it after 6 months and it asked for a bunch of updates. I did <code>git stash</code> and <code>git stash pop</code> etc since it would not let me update otherwise.<br />
however, after updating the main system, there were updates to MMM NOAA and MMM-singlestock. after I did that, the system didn’t work at all.<br />
what should I load here (config.js file, any code etc? ) to get some help on this.<br />
I deleted MMM-SingleStock but it doesn’t changes anything.<br />
upon launching the system it gives a bunch of msgs and then goes to launching application, but the computer just freezes and I have to start by unplugging it.<br />
here is a snap shot of the msgs I get.<br />
<img src="/assets/uploads/files/1577835599521-20191231_161257.jpg" alt="0_1577835597893_20191231_161257.jpg" class="img-markdown  img-fluid" /></p>
<p dir="auto">Please help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11896/mm-doesn-t-load-after-update-hangs-pi</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 00:58:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11896.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Dec 2019 23:44:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM doesn't load after update. Hangs Pi on Wed, 01 Jan 2020 14:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/magicmirrorer" aria-label="Profile: magicmirrorer">@<bdi>magicmirrorer</bdi></a> git branch will show the different collections of code<br />
git checkout ??? Where ??? Is one of those names will load that collection into the working directory</p>
]]></description><link>https://forum.magicmirror.builders/post/66921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66921</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 01 Jan 2020 14:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to MM doesn't load after update. Hangs Pi on Wed, 01 Jan 2020 05:01:07 GMT]]></title><description><![CDATA[<p dir="auto">what does changing back to master branch mean? how does one do that ?</p>
]]></description><link>https://forum.magicmirror.builders/post/66919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66919</guid><dc:creator><![CDATA[magicmirrorer]]></dc:creator><pubDate>Wed, 01 Jan 2020 05:01:07 GMT</pubDate></item><item><title><![CDATA[Reply to MM doesn't load after update. Hangs Pi on Wed, 01 Jan 2020 00:11:24 GMT]]></title><description><![CDATA[<p dir="auto">I am having similar issues on the develop path.  I had to change back to the master branch and it went back to working.</p>
<p dir="auto">My error looks like:</p>
<pre><code>mm-0 [18:41:00.356] [ERROR]
mm-0 WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
mm-0 Require stack:
mm-0 - /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js
mm-0 - /home/pi/MagicMirror/js/app.js
mm-0 - /home/pi/MagicMirror/js/electron.js
mm-0 - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
]]></description><link>https://forum.magicmirror.builders/post/66910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/66910</guid><dc:creator><![CDATA[ESOB]]></dc:creator><pubDate>Wed, 01 Jan 2020 00:11:24 GMT</pubDate></item></channel></rss>
