<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Publishing MM module]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I’m working on a new module and created the necessary files on my Raspberry PI. Now trying to solve some stuff to get it operational, however when the module is done: what is the best way to publish it?</p>
<p dir="auto">Does somebody has a kind of documentation about this?</p>
<p dir="auto">Many thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/11915/publishing-mm-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 09:31:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11915.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jan 2020 08:55:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Publishing MM module on Fri, 03 Jan 2020 09:39:38 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! I will update when the module is published.<br />
First I need to solve some issues :)</p>
]]></description><link>https://forum.magicmirror.builders/post/67074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67074</guid><dc:creator><![CDATA[rico24]]></dc:creator><pubDate>Fri, 03 Jan 2020 09:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to Publishing MM module on Fri, 03 Jan 2020 09:09:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rico24" aria-label="Profile: rico24">@<bdi>rico24</bdi></a><br />
make github repository then advertise here.</p>
]]></description><link>https://forum.magicmirror.builders/post/67072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67072</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 03 Jan 2020 09:09:19 GMT</pubDate></item></channel></rss>
