<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM using Arduino...]]></title><description><![CDATA[<p dir="auto">Anyone know how I can set up MM using Arduino UNO?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11921/mm-using-arduino</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 09:07:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11921.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jan 2020 04:53:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM using Arduino... on Sat, 04 Jan 2020 13:54:34 GMT]]></title><description><![CDATA[<p dir="auto">Arduino is for automatism not for informatic<br />
i dont think it is possible or it is not as simple as for the raspberry</p>
]]></description><link>https://forum.magicmirror.builders/post/67172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67172</guid><dc:creator><![CDATA[seramik]]></dc:creator><pubDate>Sat, 04 Jan 2020 13:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to MM using Arduino... on Sat, 04 Jan 2020 06:34:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/justjim1220" aria-label="Profile: justjim1220">@<bdi>justjim1220</bdi></a> with a 16mhz clockspeed, limited amount of memory… I would say you can’t.</p>
<p dir="auto">You could probably write something similar if you just want some simple text displayed on a small tft.</p>
]]></description><link>https://forum.magicmirror.builders/post/67165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67165</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sat, 04 Jan 2020 06:34:49 GMT</pubDate></item></channel></rss>
