<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update troubles. Again.]]></title><description><![CDATA[<p dir="auto">Every time I update, it seems to break something. This is getting frustrating, because I can’t diagnose the problem. This time, it shows MM is running in PM2, but all I see is my Pi desktop. I don’t even know where to begin to fix the issue, because it seems like everything should be working.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11926/update-troubles-again</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 00:50:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11926.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Jan 2020 18:49:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 22:08:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uatuba" aria-label="Profile: uatuba">@<bdi>uatuba</bdi></a><br />
No need to apologize, but you were asked to supply the <strong>exact</strong> steps taken.<br />
A <code>git pull </code>  followed by <code>npm install</code> in the MM homedir will most likely solve your electron error message.<br />
If not, the upgrade script from Sam will solve it or at least will provide with some info to check for.</p>
]]></description><link>https://forum.magicmirror.builders/post/67199</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67199</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 04 Jan 2020 22:08:55 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 21:38:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uatuba" aria-label="Profile: uatuba">@<bdi>uatuba</bdi></a> the update posting says</p>
<pre><code>git pull &amp; npm install
<p dir="auto">did you do the npm install part? in the MagicMirror folder?</p>
<p dir="auto">the new distribution needs dependencies (libraries)  newer than previously installed.<br />
so you have to redo npm install to update them</p>
<p dir="auto">if u ran the script  from the new updater topic, please post the contents of</p>
<pre><code>MagicMirror/installers/upgrade.log
]]></description><link>https://forum.magicmirror.builders/post/67197</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67197</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Jan 2020 21:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 20:45:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a> my apologies…I DID use both. After rebooting again, I now get “line 66: electron not found.”</p>
]]></description><link>https://forum.magicmirror.builders/post/67196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67196</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Sat, 04 Jan 2020 20:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 19:36:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uatuba" aria-label="Profile: uatuba">@<bdi>uatuba</bdi></a></p>
<p dir="auto">The v2.20.0 announcement said<br />
<a href="https://forum.magicmirror.builders/topic/11899/v2-10-0">https://forum.magicmirror.builders/topic/11899/v2-10-0</a></p>
<pre><code>Please update using the following command: git pull &amp;&amp; npm install.
<p dir="auto">Note that one has to be in the MagicMirror directory before issuing these commands (<code>cd ~/MagicMirror</code>).</p>
<p dir="auto">The <a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a> shows 2 commands, see:<br />
<a href="https://github.com/MichMich/MagicMirror/blob/master/README.md#updating" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/blob/master/README.md#updating</a></p>
<p dir="auto">Not a sign of just an single <code>git pull</code> anywhere.</p>
<p dir="auto">Anyway, I would suggest you to try the commands from the first post in this topic:<br />
<a href="https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1">https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1</a><br />
The only note would be that it is advised to stop MM (e.g. using <code>pm2 stop mm</code>).</p>
<p dir="auto">Success.</p>
]]></description><link>https://forum.magicmirror.builders/post/67192</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67192</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sat, 04 Jan 2020 19:36:39 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 19:07:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdream" aria-label="Profile: bdream">@<bdi>bdream</bdi></a> said in <a href="/post/67189">Update troubles. Again.</a>:</p>
<p dir="auto">link text</p>
<p dir="auto">This seems like a great feature that would prevent a lot of issues. I don’t think it will help me in my current predicament, though, since I already updated according to the readme.</p>
]]></description><link>https://forum.magicmirror.builders/post/67190</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67190</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Sat, 04 Jan 2020 19:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 19:05:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uatuba" aria-label="Profile: uatuba">@<bdi>uatuba</bdi></a> I had trouble also.<br />
As mentiones by Stedweil I used script from first threat in <a href="https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing">link text</a></p>
<p dir="auto">Make sure to stop MM before running update</p>
]]></description><link>https://forum.magicmirror.builders/post/67189</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67189</guid><dc:creator><![CDATA[bdream]]></dc:creator><pubDate>Sat, 04 Jan 2020 19:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 19:05:05 GMT]]></title><description><![CDATA[<p dir="auto">Was the update intended to work with Raspbian updates, too?  Could the MagicMirror update have a breaking change if Raspbian hasn’t been updated?</p>
]]></description><link>https://forum.magicmirror.builders/post/67188</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67188</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Sat, 04 Jan 2020 19:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 18:52:46 GMT]]></title><description><![CDATA[<p dir="auto">Ssh to the device<br />
git pull (as mentioned in the readme)<br />
reboot</p>
]]></description><link>https://forum.magicmirror.builders/post/67186</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67186</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Sat, 04 Jan 2020 18:52:46 GMT</pubDate></item><item><title><![CDATA[Reply to Update troubles. Again. on Sat, 04 Jan 2020 18:52:03 GMT]]></title><description><![CDATA[<p dir="auto">What exact steps did you take to update?</p>
]]></description><link>https://forum.magicmirror.builders/post/67185</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67185</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sat, 04 Jan 2020 18:52:03 GMT</pubDate></item></channel></rss>
