<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror Goes blackscreen overnight]]></title><description><![CDATA[<p dir="auto">Every night my MagicMirror goes to a black screen.  My curser is seen when I move the mouse in the morning and CTRL+Q makes it go back to my home page then MagicMirror will start automatically with no issues.</p>
<p dir="auto">Has anyone had this issue yet?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11947/magicmirror-goes-blackscreen-overnight</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:10:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11947.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jan 2020 13:43:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Mon, 06 Jan 2020 15:06:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/demetry07" aria-label="Profile: demetry07">@<bdi>demetry07</bdi></a> said in <a href="/post/67381">MagicMirror Goes blackscreen overnight</a>:</p>
<p dir="auto">MMM-GoogleMapsTraffic.js:77 Unc</p>
<p dir="auto">that module has a bug, get the fix from my repo . .</p>
<p dir="auto">do</p>
<pre><code>cd ~/MagicMirror/modules
mv MMM-GoogleMapsTraffic MMM-GoogleMapsTraffic.old
git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
<p dir="auto">restart your mirror</p>
<p dir="auto">I don’t know why the others, unless it is because of this one…</p>
]]></description><link>https://forum.magicmirror.builders/post/67382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67382</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 06 Jan 2020 15:06:27 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Sun, 12 Jan 2020 19:06:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raksasas" aria-label="Profile: Raksasas">@<bdi>Raksasas</bdi></a> you can start in dev mode w</p>
<pre><code>npm start dev
<p dir="auto">From the MagicMirror folder.</p>
<p dir="auto">But you need a mouse I think to select the tab.</p>
<p dir="auto">If you have</p>
<pre><code>address: "0.0.0.0",
IpWhiteList: [],
<p dir="auto">In config.js, then you could use chrome on your PC to connect to the mirror and open the dev window there</p>
]]></description><link>https://forum.magicmirror.builders/post/67898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67898</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2020 19:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Sun, 12 Jan 2020 18:57:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I am having what appears to be the same issue: “screen going black after X hours and the cursor in the top left of the screen”</p>
<p dir="auto">How do I preform this with no keyboard/mouse attached?</p>
]]></description><link>https://forum.magicmirror.builders/post/67896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67896</guid><dc:creator><![CDATA[Raksasas]]></dc:creator><pubDate>Sun, 12 Jan 2020 18:57:36 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Tue, 07 Jan 2020 17:50:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/demetry07" aria-label="Profile: demetry07">@<bdi>demetry07</bdi></a> awesome!!..</p>
]]></description><link>https://forum.magicmirror.builders/post/67549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67549</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jan 2020 17:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Tue, 07 Jan 2020 17:49:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am glad you told me about the CTRL + Shift + I.  I was able to use that to fix some of the other Modules I was using.</p>
]]></description><link>https://forum.magicmirror.builders/post/67548</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67548</guid><dc:creator><![CDATA[demetry07]]></dc:creator><pubDate>Tue, 07 Jan 2020 17:49:47 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Tue, 07 Jan 2020 17:48:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/demetry07" aria-label="Profile: demetry07">@<bdi>demetry07</bdi></a> woohoo!!.. thanks for the update!</p>
]]></description><link>https://forum.magicmirror.builders/post/67547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67547</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jan 2020 17:48:40 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Tue, 07 Jan 2020 17:47:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yes no black screen this morning that fixed it!</p>
]]></description><link>https://forum.magicmirror.builders/post/67544</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67544</guid><dc:creator><![CDATA[demetry07]]></dc:creator><pubDate>Tue, 07 Jan 2020 17:47:33 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Tue, 07 Jan 2020 14:08:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/demetry07" aria-label="Profile: demetry07">@<bdi>demetry07</bdi></a> any update?</p>
]]></description><link>https://forum.magicmirror.builders/post/67521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67521</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jan 2020 14:08:46 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Mon, 06 Jan 2020 15:35:21 GMT]]></title><description><![CDATA[<p dir="auto">Ok updated and restarted.  Will update in the morning or if it fails before then.</p>
<p dir="auto">Thank you very much @sdetwil</p>
]]></description><link>https://forum.magicmirror.builders/post/67390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67390</guid><dc:creator><![CDATA[demetry07]]></dc:creator><pubDate>Mon, 06 Jan 2020 15:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Mon, 06 Jan 2020 15:06:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/demetry07" aria-label="Profile: demetry07">@<bdi>demetry07</bdi></a> said in <a href="/post/67381">MagicMirror Goes blackscreen overnight</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/67382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67382</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 06 Jan 2020 15:06:27 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Mon, 06 Jan 2020 14:57:58 GMT]]></title><description><![CDATA[<p dir="auto">Checked any errors and this is what came up.</p>
<p dir="auto">Thoughts?</p>
<p dir="auto">8080/modules/MMM-Snow//MMM-Snow.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)<br />
(index):1 Refused to execute script from ‘<a href="http://localhost:8080/modules/MMM-Snow//MMM-Snow.js" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/modules/MMM-Snow//MMM-Snow.js</a>’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.<br />
loader.js:187 Error on loading script: modules/MMM-Snow//MMM-Snow.js<br />
script.onerror @ loader.js:187<br />
:8080/modules/MMM-Dad-Jokes//MMM-Dad-Jokes.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)<br />
(index):1 Refused to execute script from ‘<a href="http://localhost:8080/modules/MMM-Dad-Jokes//MMM-Dad-Jokes.js" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/modules/MMM-Dad-Jokes//MMM-Dad-Jokes.js</a>’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.<br />
loader.js:187 Error on loading script: modules/MMM-Dad-Jokes//MMM-Dad-Jokes.js<br />
(index):1 Refused to apply style from ‘<a href="http://localhost:8080/css/custom.css" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/css/custom.css</a>’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.<br />
loader.js:203 Error on loading stylesheet: css/custom.css<br />
stylesheet.onerror @ loader.js:203<br />
:8080/modules/MMM-GoogleMapsTraffic//MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read property ‘length’ of undefined<br />
at HTMLScriptElement.script.onload (:8080/modules/MMM-GoogleMapsTraffic//MMM-GoogleMapsTraffic.js:77)<br />
<a href="http://maps.googleapis.com/maps/api/js?key=AIzaSyDo3gOotJfC2vkH3fugcheqIuCg-h0qRZ4:139" target="_blank" rel="noopener noreferrer nofollow ugc">maps.googleapis.com/maps/api/js?key=AIzaSyDo3gOotJfC2vkH3fugcheqIuCg-h0qRZ4:139</a> You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.<br />
Vi @ <a href="http://maps.googleapis.com/maps/api/js?key=AIzaSyDo3gOotJfC2vkH3fugcheqIuCg-h0qRZ4:139" target="_blank" rel="noopener noreferrer nofollow ugc">maps.googleapis.com/maps/api/js?key=AIzaSyDo3gOotJfC2vkH3fugcheqIuCg-h0qRZ4:139</a><br />
<a href="http://api.openweathermap.org/data/2.5/forecast/daily?id=4393217&amp;units=imperial&amp;lang=en&amp;APPID=98626cd176b5075d4d8b1fba0971e8f8:1" target="_blank" rel="noopener noreferrer nofollow ugc">api.openweathermap.org/data/2.5/forecast/daily?id=4393217&amp;units=imperial&amp;lang=en&amp;APPID=98626cd176b5075d4d8b1fba0971e8f8:1</a> Failed to load resource: the server responded with a status of 401 (Unauthorized)<br />
:8080/modules/default/weatherforecast//weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.<br />
weatherRequest.onreadystatechange @ :8080/modules/default/weatherforecast//weatherforecast.js:266<br />
(index):1 Refused to apply style from ‘<a href="http://localhost:8080/css/custom.css" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/css/custom.css</a>’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.</p>
]]></description><link>https://forum.magicmirror.builders/post/67381</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67381</guid><dc:creator><![CDATA[demetry07]]></dc:creator><pubDate>Mon, 06 Jan 2020 14:57:58 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Mon, 06 Jan 2020 14:05:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks I will check it in the morning when it does it again.</p>
]]></description><link>https://forum.magicmirror.builders/post/67375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67375</guid><dc:creator><![CDATA[demetry07]]></dc:creator><pubDate>Mon, 06 Jan 2020 14:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror Goes blackscreen overnight on Mon, 06 Jan 2020 13:50:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/demetry07" aria-label="Profile: demetry07">@<bdi>demetry07</bdi></a> not specifically… but before ctrl-Q, do<br />
ctrl-shift-i to open the developers window, select the tab labeled ‘console’ and scroll up to see if there is an error reported… usually red text…</p>
<p dir="auto">the black screen means some script failed hard and the browser UI can’t continue</p>
]]></description><link>https://forum.magicmirror.builders/post/67373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67373</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 06 Jan 2020 13:50:45 GMT</pubDate></item></channel></rss>
