<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic Mirror updated now doesnt work]]></title><description><![CDATA[<p dir="auto">Hi all</p>
<p dir="auto">I have update my MM to 2.10.0 and now my MM doesnt show on the screen. Here are my logs:</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
2 info using npm@6.13.4
3 info using node@v10.18.0
5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr$
9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
10 silly lifecycle magicmirror@2.10.0~start: Args: [ '-c', './run-start.sh' ]
11 silly lifecycle magicmirror@2.10.0~start: Returned: code: 1  signal: null
12 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
13 verbose stack Error: magicmirror@2.10.0 start: `./run-start.sh`
13 verbose stack Exit status 1
13 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack     at EventEmitter.emit (events.js:198:13)
13 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack     at ChildProcess.emit (events.js:198:13)
13 verbose stack     at maybeClose (internal/child_process.js:982:16)
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
14 verbose pkgid magicmirror@2.10.0
15 verbose cwd /home/pi/MagicMirror
16 verbose Linux 4.19.75-v7l+
17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
18 verbose node v10.18.0
19 verbose npm  v6.13.4
20 error code ELIFECYCLE
21 error errno 1
22 error magicmirror@2.10.0 start: `./run-start.sh`
22 error Exit status 1
23 error Failed at the magicmirror@2.10.0 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
<p dir="auto">Can anyone help please?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/11966/magic-mirror-updated-now-doesnt-work</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 02:09:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11966.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jan 2020 12:24:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Sun, 12 Jan 2020 18:33:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it seems to be working fine now after few reboots to the pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/67894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67894</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Sun, 12 Jan 2020 18:33:03 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Sun, 12 Jan 2020 19:02:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> cool. Thx for the update!</p>
]]></description><link>https://forum.magicmirror.builders/post/67897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67897</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2020 19:02:17 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Sun, 12 Jan 2020 18:33:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it seems to be working fine now after few reboots to the pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/67894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67894</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Sun, 12 Jan 2020 18:33:03 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Sun, 12 Jan 2020 14:39:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> which Home Assistant module are u using?</p>
]]></description><link>https://forum.magicmirror.builders/post/67890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67890</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2020 14:39:23 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 22:08:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> here is a link of a little video in gif format showing you what I mean by homeassistant module turning on and off.</p>
<p dir="auto"><a href="https://ibb.co/hLx6KJr" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/hLx6KJr</a></p>
]]></description><link>https://forum.magicmirror.builders/post/67698</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67698</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 22:08:00 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 21:28:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sorry which 2 logs?</p>
]]></description><link>https://forum.magicmirror.builders/post/67695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67695</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 21:28:50 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 20:57:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> we found a security gap. The doc says, if not specified, it is localhost. But we allowed anyone.</p>
<p dir="auto">Home assistant on/off what does that mean?   Show me the two logs.</p>
<p dir="auto">I will be away for a few hours</p>
]]></description><link>https://forum.magicmirror.builders/post/67691</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67691</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 20:57:59 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 20:42:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> omg that worked !!! I remember before there was no need to put any thing. How come its changed?</p>
<p dir="auto">Anyway I have another problem, my home assistant module keeps on turning on and off  like rapidly. It never used to do that before.</p>
]]></description><link>https://forum.magicmirror.builders/post/67688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67688</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 20:42:51 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 20:39:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> said in <a href="/post/67681">Magic Mirror updated now doesnt work</a>:</p>
<p dir="auto">address: “”,  &lt; — means ONLY the local system  can connect</p>
<p dir="auto">change to<br />
address: “0.0.0.0”,</p>
<p dir="auto">means whitelist controls who can connect</p>
]]></description><link>https://forum.magicmirror.builders/post/67684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67684</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 20:39:07 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 20:19:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> there you go:</p>
<pre><code>var config = {
        address: "", // Address to listen on, can be:
        port: 8181,
        ipWhitelist: [], // Set [] to allow all IP addresses
                                                               // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"$
                                                               // or IPv4 range of 192.168.3.0 --&gt; 192.168.3.15 use CIDR format$
                                                               // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/$
        language: "en",
        timeFormat: 24,
        units: "metric",
//        customCss: 'css/custom.css',
//                      module: "alert",
]]></description><link>https://forum.magicmirror.builders/post/67681</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67681</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 20:19:53 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 18:38:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> said in <a href="/post/67644">Magic Mirror updated now doesnt work</a>:</p>
<p dir="auto">I cannot access my mirror from another device at home</p>
<p dir="auto">i’m not sure I understand what you said…</p>
<p dir="auto">access is a vague term</p>
<p dir="auto">ssh is part of access<br />
load mirror on browser is part of access<br />
ftp files is part of access</p>
<p dir="auto">I THINK what you meant was</p>
<p dir="auto">the mirror app is running, and u can see it.<br />
but you cannot use a browser on another machine to pull up the the same view…</p>
<p dir="auto">so, can we see your config.js.</p>
<p dir="auto">I ‘think’ this is the change to address: “”,<br />
which is supposed to default to “localhost”,<br />
but DID default to 0.0.0.0</p>
]]></description><link>https://forum.magicmirror.builders/post/67647</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67647</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 18:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 18:38:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> any idea?</p>
]]></description><link>https://forum.magicmirror.builders/post/67646</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67646</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 18:38:41 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 18:28:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok I can conclude one thing is that I cannot access my mirror from another device at home. My mirror is working but it’s not accessible from a different device. Something is blocking it or stopping it within the mirror.</p>
<p dir="auto">My config hasn’t changed and its after the update that I cannot access it from another device.</p>
]]></description><link>https://forum.magicmirror.builders/post/67644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67644</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 18:28:06 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 16:16:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> ok. we need to see the front end console log thru the dev window</p>
]]></description><link>https://forum.magicmirror.builders/post/67638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67638</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 16:16:29 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 16:15:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I mean when I updated my to 2.10 that’s when all the problem started. Before updating my I installed mmm remote control now I don’t know if that module has caused this issue of me not being able to access magic mirror remotely.</p>
]]></description><link>https://forum.magicmirror.builders/post/67637</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67637</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 16:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 16:04:52 GMT]]></title><description><![CDATA[<p dir="auto">from the prior message, the backend is happy (node_helpers, web server)</p>
]]></description><link>https://forum.magicmirror.builders/post/67636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67636</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 16:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 16:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> said in <a href="/post/67634">Magic Mirror updated now doesnt work</a>:</p>
<p dir="auto">The thing that stopped working was when I updated MM I cannot access it anymore remotely.</p>
<p dir="auto">i don’t understand that. update app has nothing to do with ssh type access…</p>
<p dir="auto">if u mean MMM-remotecontrol type access, correct, the mirror app is down for some reason… that is what we are debugging</p>
]]></description><link>https://forum.magicmirror.builders/post/67635</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67635</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 16:03:42 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 16:00:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I dont have access to the mirror now as I am not home. The thing that stopped working was when I updated MM I cannot access it anymore remotely. Before updating mm I could as my ports are also forwarded.</p>
]]></description><link>https://forum.magicmirror.builders/post/67634</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67634</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 16:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:54:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> ok, so the node_helper side is working ok…</p>
<p dir="auto">now open the developers window, ctrl-shift-i, select the console tab, and scroll up to see any errors</p>
]]></description><link>https://forum.magicmirror.builders/post/67633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67633</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:54:41 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:51:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok I have done that and here is the result:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
&gt; magicmirror@2.10.0 start /home/pi/MagicMirror
&gt; ./run-start.sh
+ ./untrack-css.sh
+ '[' -z '' ']'
+ export DISPLAY=:0
+ DISPLAY=:0
++ uname -m
+ arch=armv7l
+ false=false
++ grep -v '^\s//' config/config.js
++ grep -i serveronly:
++ awk '{print tolower($2)}'
++ tr -d ',"'\'''
+ serveronly=
+ serveronly=false
++ pgrep Xorg
+ xorg=519
++ uname
+ mac=Linux
+ '[' false. '!=' false. -o armv7l == armv6l ']'
+ '[' 519. == . -a Linux '!=' Darwin ']'
+ electron js/electron.js
[15:51:26.871] [LOG]    Starting MagicMirror: v2.10.0
[15:51:26.879] [LOG]    Loading config ...
[15:51:26.884] [LOG]    Loading module helpers ...
[15:51:26.924] [LOG]    Initializing new module helper ...
[15:51:26.925] [LOG]    Module helper loaded: updatenotification
[15:51:26.926] [LOG]    No helper found for module: clock.
[15:51:27.306] [LOG]    Initializing new module helper ...
[15:51:27.306] [LOG]    Module helper loaded: MMM-SystemStats
[15:51:27.307] [LOG]    No helper found for module: currentweather.
[15:51:27.308] [LOG]    No helper found for module: weatherforecast.
[15:51:27.308] [LOG]    No helper found for module: random_quotes.
[15:51:27.310] [LOG]    Initializing new module helper ...
[15:51:27.311] [LOG]    Module helper loaded: MMM-homeassistant-sensors
[15:51:27.697] [LOG]    Initializing new module helper ...
[15:51:27.698] [LOG]    Module helper loaded: MMM-UKNationalRail
[15:51:27.699] [LOG]    No helper found for module: MMM-TFL.
[15:51:27.735] [LOG]    Initializing new module helper ...
[15:51:27.735] [LOG]    Module helper loaded: newsfeed
[15:51:27.736] [LOG]    All module helpers loaded.
[15:51:27.737] [LOG]    Starting server on port 8181 ...
[15:51:27.744] [INFO]   You're using a full whitelist configuration to allow for all IPs
[15:51:27.750] [LOG]    Server started ...
[15:51:27.751] [LOG]    Connecting socket for: updatenotification
[15:51:27.752] [LOG]    Connecting socket for: MMM-SystemStats
[15:51:27.753] [LOG]    Connecting socket for: MMM-homeassistant-sensors
[15:51:27.754] [LOG]    Connecting socket for: MMM-UKNationalRail
[15:51:27.754] [LOG]    MMM-UKNationalRail helper started ...
[15:51:27.755] [LOG]    Connecting socket for: newsfeed
[15:51:27.756] [LOG]    Starting module: newsfeed
[15:51:27.756] [LOG]    Sockets connected &amp; modules started ...
[15:51:27.943] [LOG]    Launching application.
[15:51:29.943] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/news/england/rss.xml - Interval: 300000
[15:51:29.984] [LOG]    Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 300000
]]></description><link>https://forum.magicmirror.builders/post/67631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67631</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:51:54 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:48:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a></p>
<p dir="auto">please read my posts</p>
<p dir="auto">do</p>
<pre><code>pm2 status
<p dir="auto">if anything is running, not stopped then do</p>
<pre><code>pm2 stop ??
where xx is the name or number of the item running
<p dir="auto">once u have nothing running, then redo the npm start from the MagicMirror folder so we can diagnose the rest of the problem</p>
]]></description><link>https://forum.magicmirror.builders/post/67627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67627</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:48:47 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:47:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok so what shall I do now? I am lost. I always avoid updating my magicmirror as the new update always breaks it.</p>
]]></description><link>https://forum.magicmirror.builders/post/67626</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67626</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:45:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> version = instance… sorry</p>
<p dir="auto">pm2 status</p>
<p dir="auto">if something is running, shut it down</p>
]]></description><link>https://forum.magicmirror.builders/post/67624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67624</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:44:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> nope its only one version</p>
]]></description><link>https://forum.magicmirror.builders/post/67623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67623</guid><dc:creator><![CDATA[bachoo786]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:44:25 GMT</pubDate></item><item><title><![CDATA[Reply to Magic Mirror updated now doesnt work on Wed, 08 Jan 2020 15:43:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bachoo786" aria-label="Profile: bachoo786">@<bdi>bachoo786</bdi></a> said in <a href="/post/67620">Magic Mirror updated now doesnt work</a>:</p>
<p dir="auto">do I have to do that? I never did update the modules after I upgraded the mirror.</p>
<p dir="auto">yes… if the base dependencies change, then u should update the dependencies of the modules</p>
<p dir="auto">my automated upgrade script does all this.</p>
]]></description><link>https://forum.magicmirror.builders/post/67621</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67621</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 08 Jan 2020 15:43:05 GMT</pubDate></item></channel></rss>
