<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default module calendar issue&#x2F;bug maybe discovered]]></title><description><![CDATA[<p dir="auto">Hi<br />
Have used MagicMirror for about 18 months<br />
I think I’m pretty good at how it works.</p>
<p dir="auto">When the new version came out, I had some issues with some modules but also ran my MM where I have run update on update, so chose to do a clean install of latest Raspian and Magic Mirror.<br />
Now I am setting it up again and have detected an error with “default calendar”.</p>
<p dir="auto">in the config for the module “calendar” i’m running:</p>
<pre><code>maximumEntries: 100,
fullDayEventDateFormat: "DD MMM",
timeFormat: "absolute",
urgency: 7,
<p dir="auto">It’s working fine… great<br />
My problem is when i’m adding more then one calendar entries, then it randomly changes the format for the entries from “DD MMM” too “MMM DD” ??</p>
<p dir="auto">Now I have almost 35 entries, and one thing I can see though and that is that the format is the same for the same calendar, so the same calendar on a URL is the same entry, so calendar 1 access / input can be format “MMM DD” and calendars 2 and 3 access / input can be “DD MMM”.<br />
Can some help with what is happening and how I can solve this?</p>
<p dir="auto">And another thing I can see is that it changes the format of the enteries that have been made over a longer period in google calendar, that is to say that every Thursday in the period 10/01/20 (DD / MM / YY) to 30 / 07/20 (DD / MM / YY) there is a task, possibly my daughter’s swimming, everyone else works/fits, it is actually only this type of task created in that way, that changes format from “DD MMM” to " MMM DD "<br />
Can some help with this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/11984/default-module-calendar-issue-bug-maybe-discovered</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 09:27:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/11984.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Jan 2020 18:12:19 GMT</pubDate><ttl>60</ttl></channel></rss>
