<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleMapsTraffic module stops MMM-MySportsboard from working]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/4691/mmm-googlemapstraffic">MMM-GoogleMapsTraffic</a></p>
<p dir="auto">When I enable MMM-GoogleMapsTraffic it works great but it stops MySportsboard from loading.</p>
<p dir="auto">When I disable MMM-GoogleMapsTraffic - MySportsboard module works great.</p>
<p dir="auto">Other modules also affected if MMM-GoogleMapsTraffic enabled.</p>
<p dir="auto">Is it an API key issue?</p>
<p dir="auto">Thank you for any help :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/12002/mmm-googlemapstraffic-module-stops-mmm-mysportsboard-from-working</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 23:33:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12002.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Jan 2020 17:21:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic module stops MMM-MySportsboard from working on Sun, 05 Feb 2023 19:39:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thegeekfather" aria-label="Profile: TheGeekfather">@<bdi>TheGeekfather</bdi></a> Absolute hero!!!</p>
<p dir="auto">I was having the exact same issue with it stopping MMM-TFL-Status</p>
<p dir="auto">Used your updated version and worked straight away.</p>
]]></description><link>https://forum.magicmirror.builders/post/107702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107702</guid><dc:creator><![CDATA[dan3411]]></dc:creator><pubDate>Sun, 05 Feb 2023 19:39:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic module stops MMM-MySportsboard from working on Mon, 13 Jan 2020 17:34:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Sam, Once again</p>
<p dir="auto">THANK YOU !!!</p>
<p dir="auto">Worked PERFECTLY with all modules loading :)</p>
]]></description><link>https://forum.magicmirror.builders/post/67931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67931</guid><dc:creator><![CDATA[TheGeekfather]]></dc:creator><pubDate>Mon, 13 Jan 2020 17:34:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic module stops MMM-MySportsboard from working on Mon, 13 Jan 2020 17:24:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thegeekfather" aria-label="Profile: TheGeekfather">@<bdi>TheGeekfather</bdi></a> that module has a bug, I have a fixed version, which I submitted to the author, but not yet applied…</p>
<p dir="auto">do this</p>
<p dir="auto">stop the mirror app</p>
<pre><code>cd ~/MagicMirror/modules
mv MMM-GoogleMapsTraffic MMM-GoogleMapsTraffic.original
git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic
cd MMM-GoogleMapsTraffic
npm install
<p dir="auto">restart mirror app</p>
]]></description><link>https://forum.magicmirror.builders/post/67930</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/67930</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Jan 2020 17:24:35 GMT</pubDate></item></channel></rss>
