<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NowPlayingOnSpotify With erro]]></title><description><![CDATA[<p dir="auto">With that out. Does not display what I am playing.</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start
&gt; magicmirror@2.10.0 start /home/pi/MagicMirror
&gt; ./run-start.sh
[02:08:45.316] [LOG] Starting MagicMirror: v2.10.0
[02:08:45.349] [LOG] Loading config ...
[02:08:45.368] [LOG] Loading module helpers ...
[02:08:45.377] [LOG] No helper found for module: alert.
[02:08:45.563] [LOG] Initializing new module helper ...
[02:08:45.570] [LOG] Module helper loaded: updatenotification
[02:08:45.573] [LOG] No helper found for module: clock.
[02:08:47.019] [LOG] Initializing new module helper ...
[02:08:47.022] [LOG] Module helper loaded: calendar
[02:08:47.025] [LOG] No helper found for module: compliments.
[02:08:48.211] [LOG] Initializing new module helper ...
[02:08:48.214] [LOG] Module helper loaded: MMM-DarkSkyForecast
[02:08:49.639] [LOG] Initializing new module helper ...
[02:08:49.642] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
[02:08:49.752] [LOG] Initializing new module helper ...
[02:08:49.755] [LOG] Module helper loaded: newsfeed
[02:08:49.759] [LOG] All module helpers loaded.
[02:08:49.766] [LOG] Starting server on port 8080 ...
[02:08:49.846] [LOG] Server started ...
[02:08:49.855] [LOG] Connecting socket for: updatenotification
[02:08:49.866] [LOG] Connecting socket for: calendar
[02:08:49.873] [LOG] Starting node helper for: calendar
[02:08:49.878] [LOG] Connecting socket for: MMM-DarkSkyForecast
[02:08:49.882] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
[02:08:49.886] [LOG] Connecting socket for: MMM-NowPlayingOnSpotify
[02:08:49.890] [LOG] Connecting socket for: newsfeed
[02:08:49.894] [LOG] Starting module: newsfeed
[02:08:49.896] [LOG] Sockets connected &amp; modules started ...
[02:08:49.900] [LOG]
Ready to go! Please point your browser to: http://localhost:8080
Starting chromium browser now, have patience, it takes a minute
 --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
[02:09:02.796] [ERROR]  (node:8894) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
[02:09:03.877] [ERROR]  Error while refreshing:
[02:09:03.880] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
    at doWrite (_stream_writable.js:411:19)
    at writeOrBuffer (_stream_writable.js:399:5)
    at Socket.Writable.write (_stream_writable.js:299:11)
    at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
    at refreshAccessToken.then (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24:19)
    at process._tickCallback (internal/process/next_tick.js:68:7)
[02:09:03.952] [ERROR]  Error while refreshing:
[02:09:03.968] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
[02:09:04.036] [ERROR]  Error while refreshing:
[02:09:04.041] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
[02:09:04.745] [ERROR]  Error while refreshing:
[02:09:04.748] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
[02:09:05.293] [ERROR]  Error while refreshing:
[02:09:05.297] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
]]></description><link>https://forum.magicmirror.builders/topic/12025/mmm-nowplayingonspotify-with-erro</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 03:20:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12025.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 16 Jan 2020 04:17:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NowPlayingOnSpotify With erro on Fri, 17 Jan 2020 00:57:22 GMT]]></title><description><![CDATA[<p dir="auto">reboot. The module is ok.</p>
]]></description><link>https://forum.magicmirror.builders/post/68172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68172</guid><dc:creator><![CDATA[iorifly]]></dc:creator><pubDate>Fri, 17 Jan 2020 00:57:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NowPlayingOnSpotify With erro on Fri, 17 Jan 2020 00:42:57 GMT]]></title><description><![CDATA[<p dir="auto">My module is forever loading. Does not display the data.</p>
]]></description><link>https://forum.magicmirror.builders/post/68169</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68169</guid><dc:creator><![CDATA[iorifly]]></dc:creator><pubDate>Fri, 17 Jan 2020 00:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NowPlayingOnSpotify With erro on Thu, 16 Jan 2020 15:34:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iorifly" aria-label="Profile: iorifly">@<bdi>iorifly</bdi></a> fix reported in HASS topic</p>
]]></description><link>https://forum.magicmirror.builders/post/68121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68121</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jan 2020 15:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NowPlayingOnSpotify With erro on Thu, 16 Jan 2020 14:18:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iorifly" aria-label="Profile: iorifly">@<bdi>iorifly</bdi></a> &gt;what can I do?</p>
<p dir="auto">Wait!</p>
<p dir="auto">This is a volunteer effort.</p>
]]></description><link>https://forum.magicmirror.builders/post/68114</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68114</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jan 2020 14:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NowPlayingOnSpotify With erro on Thu, 16 Jan 2020 13:38:29 GMT]]></title><description><![CDATA[<p dir="auto">boy, what can i do? I am getting crazy !</p>
<p dir="auto">   you think you better reinstall everything! ???</p>
<p dir="auto">Thank you for your tireless help.</p>
]]></description><link>https://forum.magicmirror.builders/post/68110</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68110</guid><dc:creator><![CDATA[iorifly]]></dc:creator><pubDate>Thu, 16 Jan 2020 13:38:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NowPlayingOnSpotify With erro on Thu, 16 Jan 2020 04:38:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iorifly" aria-label="Profile: iorifly">@<bdi>iorifly</bdi></a> this is the same problem as the Hass stuff</p>
]]></description><link>https://forum.magicmirror.builders/post/68093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68093</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Jan 2020 04:38:15 GMT</pubDate></item></channel></rss>
