<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installing Magic Mirror 2 Using An SD Card With A Different IMAGE]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have been fascinated by all of the work done in this community.  Originally I had used Dylan Pierce’s method to making a magic mirror as explained in his blog and forum: <a href="http://blog.dylanjpierce.com/raspberrypi/magicmirror/tutorial/2015/12/27/build-a-magic-mirror.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://blog.dylanjpierce.com/raspberrypi/magicmirror/tutorial/2015/12/27/build-a-magic-mirror.html</a><br />
<a href="http://mirrormirror.tech/?order=posts" target="_blank" rel="noopener noreferrer nofollow ugc">http://mirrormirror.tech/?order=posts</a><br />
However, the forum and the site that allowed me to control widgets on my mirror recently went down.  The forum came back up, but my mirror was completely disconnected.  I am now trying to install MagicMirror2 on my raspberry pi, but I am not sure if it will work with the image I already put on the SD card since it was configured to autostart in Chromium.  Is there any way I can get a Magic Mirror running with what I already have, or should I wipe the SD card and start fresh?<br />
Thank you for all of the help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/1203/installing-magic-mirror-2-using-an-sd-card-with-a-different-image</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 13:16:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1203.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Dec 2016 02:27:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installing Magic Mirror 2 Using An SD Card With A Different IMAGE on Mon, 09 Jan 2017 22:34:25 GMT]]></title><description><![CDATA[<p dir="auto">Just follow the tutorial and you’ll be fine</p>
]]></description><link>https://forum.magicmirror.builders/post/10765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10765</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Mon, 09 Jan 2017 22:34:25 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic Mirror 2 Using An SD Card With A Different IMAGE on Sat, 17 Dec 2016 12:41:01 GMT]]></title><description><![CDATA[<p dir="auto">Great! What operating system should I install on the raspberry pi? Could anyone give me a step by step tutorial of what to do?</p>
]]></description><link>https://forum.magicmirror.builders/post/9476</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9476</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Sat, 17 Dec 2016 12:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Magic Mirror 2 Using An SD Card With A Different IMAGE on Sat, 17 Dec 2016 08:00:21 GMT]]></title><description><![CDATA[<p dir="auto">I would say, just do a fresh start to be save!</p>
]]></description><link>https://forum.magicmirror.builders/post/9470</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9470</guid><dc:creator><![CDATA[nem1]]></dc:creator><pubDate>Sat, 17 Dec 2016 08:00:21 GMT</pubDate></item></channel></rss>
