<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Buttons to activate MMM-Assistantmk2 (v3)]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am looking to activate MMM-Assistantmk2 (v3) by using the MMM-Buttons module.<br />
i.e - Press a physical push button to then activate the google assistant.</p>
<p dir="auto">I have the buttons working as i can get the speakers to make a sound when i press the button, and the 4 circles start to spin around.<br />
issue is nothing happens beyond this point. they just continue to spin in a circle…</p>
<p dir="auto">I have the below config</p>
<pre><code>{
    module: "MMM-Buttons",
        buttons: [
                pin: 25,
                shortPress: {
                    notification: "ASSISTANT_ACTIVATE",
                    payload: {}
  module: "MMM-AssistantMk2",
  position: "top_center",
	ui: "Classic",
	assistantConfig: {
      latitude:xxxxxxxxxxxxxxx,
      longitude: -xxxxxxxxxxxxxxxx,
     defaultProfile: "default",
    micConfig: {
      recorder: "arecord",
      device: "plughw:0",
<p dir="auto">i have even tried putting in a payload…</p>
<pre><code>payload: {type:"MIC"}
<p dir="auto">and this gets the 4 dots in a line doing a wave pattern… but again no further</p>
<p dir="auto">my mic is working as per testing it on</p>
<p dir="auto">arecord -D plughw:0,0 -d 3 test.wav &amp;&amp; aplay test.wav</p>
<p dir="auto">Any help would be great,<br />
thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/12034/mmm-buttons-to-activate-mmm-assistantmk2-v3</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 22:31:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12034.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jan 2020 01:01:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Wed, 22 Jan 2020 22:46:54 GMT]]></title><description><![CDATA[<p dir="auto">@Sean</p>
<p dir="auto">thanks for the response :) i will close this as solve for now.<br />
thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/68534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68534</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Wed, 22 Jan 2020 22:46:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Wed, 22 Jan 2020 21:31:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apartment_moose" aria-label="Profile: Apartment_Moose">@<bdi>Apartment_Moose</bdi></a><br />
We found some issues under specific condition about memory shortage. so we are trying another approach to use smaller memory. wait a while. sorry.</p>
]]></description><link>https://forum.magicmirror.builders/post/68529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68529</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 22 Jan 2020 21:31:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Wed, 22 Jan 2020 18:20:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I seem to have fixed the issue by switching everything to my raspberry 4.<br />
didn’t look like the 3 b+ could handle it for some reason and now it is all working.<br />
thank you for your help, it was greatly appreciated!</p>
<p dir="auto">quick one for you if you don’t, (after upgrading to 3.0.1) When i speak a command and it responds, the google wheel continues to spin as per the picture. (log file doesn’t do anything unless i press the button to activate again)</p>
<p dir="auto"><img src="undefined" alt="0_1579716480007_Capture.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">is this normal? or should it return to the floating bubbles?<br />
also, log files show after any open questions such as “hello google” its status goes to standby after responding with the log showing the continue line on set to “false”.</p>
<p dir="auto">if i press the button and dont say anything, then it resets due to the timer setting.</p>
]]></description><link>https://forum.magicmirror.builders/post/68523</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68523</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Wed, 22 Jan 2020 18:20:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Sun, 19 Jan 2020 23:56:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">thanks for the help so far, I have edited the vm map count as per the link you linked (with the 16gb used in the example)</p>
<p dir="auto">i am still getting the same log error however</p>
<pre><code>mmap() failed: Cannot allocate memory
Failed to create permanent mapping for memfd region with ID = 738611435
Ignoring received block reference with non-registered memfd ID = 738611435
<p dir="auto">any ideas as i am stumped…</p>
]]></description><link>https://forum.magicmirror.builders/post/68411</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68411</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Sun, 19 Jan 2020 23:56:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 18:37:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apartment_moose" aria-label="Profile: Apartment_Moose">@<bdi>Apartment_Moose</bdi></a> i just did a search on google for “mmap Cannot allocate memory”</p>
]]></description><link>https://forum.magicmirror.builders/post/68245</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68245</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jan 2020 18:37:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 17:44:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for getting back to me on this. I will check it out over the weekend when I next am free (probably sunday). I will report back on if this fixed it. Thanks again for the support as I couldnt find anything on google.</p>
]]></description><link>https://forum.magicmirror.builders/post/68238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68238</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Fri, 17 Jan 2020 17:44:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 17:24:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apartment_moose" aria-label="Profile: Apartment_Moose">@<bdi>Apartment_Moose</bdi></a> said in <a href="/post/68223">MMM-Buttons to activate MMM-Assistantmk2 (v3)</a>:</p>
<p dir="auto">do you potentially know what could cause this ?</p>
<p dir="auto">mmap is memory mapped file</p>
<p dir="auto">here is a site with a pretty decent dewscription of what to look for and what to change<br />
<a href="https://mroonga.org/docs/faq/mmap_cannot_allocate_memory.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://mroonga.org/docs/faq/mmap_cannot_allocate_memory.html</a></p>
]]></description><link>https://forum.magicmirror.builders/post/68234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68234</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jan 2020 17:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 15:19:25 GMT]]></title><description><![CDATA[<p dir="auto">@Sean</p>
<p dir="auto">ok thanks for taking a look.<br />
dont know what the mmap() issue is but i will look into it</p>
]]></description><link>https://forum.magicmirror.builders/post/68223</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68223</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Fri, 17 Jan 2020 15:19:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 15:16:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apartment_moose" aria-label="Profile: Apartment_Moose">@<bdi>Apartment_Moose</bdi></a><br />
Well, the module itself is working as log says. But the <code>mmap() failed</code> means, you have not enough memory. (I don’t know why) <code>mmap()</code> issue could happen with various reasons, so hard to point out exactly.<br />
I think it is not related to my module directly because there was no same issue report but I cannot declare definitely.</p>
]]></description><link>https://forum.magicmirror.builders/post/68222</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68222</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 17 Jan 2020 15:16:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 15:12:16 GMT]]></title><description><![CDATA[<p dir="auto">see below</p>
<pre><code>[15:09:19.817] [LOG]    [AMK2] QUERY: { type: 'MIC',
  profile: { profileFile: 'default.json', lang: 'en-US' },
  key: null,
  lang: null,
  useScreenOutput: true,
  useAudioOutput: true,
  session: 1579273759810,
  status: 'standby',
  secretMode: false,
  sayMode: false }
[15:09:19.985] [LOG]    [AMK2:AS] MIC:RECORDING START.
Failed to create permanent mapping for memfd region with ID = 2467795728
Ignoring received block reference with non-registered memfd ID = 2467795728
[15:09:20.546] [LOG]    [AMK2:AS] CONVERSATION:RESPONSE
[15:09:22.659] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'test', done: false }
[15:09:22.792] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: false }
[15:09:23.520] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: false }
[15:09:23.548] [LOG]    [AMK2:AS] CONVERSATION:END_OF_UTTERANCE
[15:09:23.551] [LOG]    [AMK2:AS] MIC:RECORDING_END
[15:09:23.585] [LOG]    [AMK2:AS] Recorder Error: arecord has exited with error code 1.
Enable debugging with the environment variable DEBUG=record.
[15:09:23.599] [LOG]    [AMK2:AS] CONVERSATION:TRANSCRIPTION { transcription: 'testing', done: true }
[15:09:23.906] [LOG]    [AMK2:AS] CONVERSATION:SCREEN object
[15:09:23.915] [LOG]    [AMK2:AS] CONVERSATION:ACTION { requestId: '5e215c36-0000-2e45-8016-089e0826d0a0' }
[15:09:23.918] [LOG]    [AMK2:AS] CONVERSATION:RESPONSE
[15:09:23.929] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.931] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.933] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.937] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.938] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.940] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.941] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.943] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.944] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.945] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.947] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.949] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.950] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.951] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.953] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.955] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.959] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.962] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.966] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.968] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.970] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.972] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.975] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.979] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.982] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.984] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.986] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.987] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.989] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.990] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.992] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.993] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.995] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.997] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:23.999] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.000] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.002] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.004] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.006] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.008] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.010] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.012] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.015] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.017] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.019] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.022] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.027] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.031] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.034] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.036] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.039] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.041] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.043] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.046] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.051] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.056] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 1600
[15:09:24.058] [LOG]    [AMK2:AS] CONVERSATION:AUDIO 14
[15:09:24.065] [LOG]    [AMK2:AS] CONVERSATION_ALL_RESPONSES_RECEIVED
[15:09:24.066] [LOG]    [AMK2:AS] CONVERSATION_END:COMPLETED
[15:09:24.067] [LOG]    [AMK2:AS] CONVERSATION_PP:RESPONSE_AUDIO_MAKING
[15:09:24.097] [LOG]    [AMK2:BW] RESPONSE_WAV_FILE_CREATED
[15:09:24.099] [LOG]    [AMK2:AS] CONVERSATION_PP:RESPONSE_AUDIO_CREATED tmp/lastResponse.wav
[15:09:24.228] [LOG]    [AMK2] { session: 1579273759810,
  error: null,
  action: { requestId: '5e215c36-0000-2e45-8016-089e0826d0a0' },
  text: null,
  screen:
   { help: [ 'What can you do?' ],
     trysay: 'Try saying…',
     links: [],
     text: 'You\'re coming in loud and clear 👌',
     photos: [],
     path:
      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/lastScreenOutput.html',
     uri: 'tmp/lastScreenOutput.html' },
  audio:
   { path:
      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/lastResponse.wav',
     uri: 'tmp/lastResponse.wav' },
  transcription: { transcription: 'testing', done: true },
  continue: false,
  lastQuery:
   { type: 'MIC',
     key: null,
     lang: null,
     status: 'standby',
     secretMode: false,
     sayMode: false } }
Failed to create permanent mapping for memfd region with ID = 3652511026
Ignoring received block reference with non-registered memfd ID = 3652511026
]]></description><link>https://forum.magicmirror.builders/post/68220</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68220</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Fri, 17 Jan 2020 15:12:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 15:06:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apartment_moose" aria-label="Profile: Apartment_Moose">@<bdi>Apartment_Moose</bdi></a><br />
I have no idea about <code>mmap()</code>. I’m not sure even whether this issue would be related to my module.<br />
Set <code>debug:true</code> of MMM-AssistantMk2 then show me the log of MMM-AssistantMk2.</p>
]]></description><link>https://forum.magicmirror.builders/post/68219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68219</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 17 Jan 2020 15:06:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 14:59:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi @Sean  &amp; <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">i restarted the raspberrypi last night and now the module is working (? no idea how) and the assistant is working when i speak.<br />
my issue now is i have no audio with the assistant (even though recording &amp; playback are fine) &amp; the assistant doesn’t turn off until i repeat the button press a few times until it doesn’t understands me.</p>
<p dir="auto">I have run the log with only one failure in the log when i press the button to activate</p>
<pre><code>
Failed to create permanent mapping for memfd region with ID = 2853658957
Ignoring received block reference with non-registered memfd ID = 2853658957
Failed to create permanent mapping for memfd region with ID = 2893321627
Ignoring received block reference with non-registered memfd ID = 2893321627
<p dir="auto">any help here ?<br />
thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/68218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68218</guid><dc:creator><![CDATA[Apartment_Moose]]></dc:creator><pubDate>Fri, 17 Jan 2020 14:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 12:21:23 GMT]]></title><description><![CDATA[<p dir="auto">@Sean said in <a href="/post/68192">MMM-Buttons to activate MMM-Assistantmk2 (v3)</a>:</p>
<p dir="auto">ou’d better remove all other modules from config.js.</p>
<p dir="auto">just add</p>
<pre><code>disabled:true,
<p dir="auto">after the each module:  u want to turn off</p>
]]></description><link>https://forum.magicmirror.builders/post/68203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68203</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jan 2020 12:21:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Buttons to activate MMM-Assistantmk2 (v3) on Fri, 17 Jan 2020 09:50:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apartment_moose" aria-label="Profile: Apartment_Moose">@<bdi>Apartment_Moose</bdi></a><br />
Can you show me the logs? To make things simple, except <code>clock</code>, <code>MMM-Button</code>, <code>MMM-AssistantMk2</code>, You’d better remove all other modules from <code>config.js</code>. Execute MM, then show me what happens in log. (add <code>debug:true</code> to MMM-AssistantMk2’s config)</p>
]]></description><link>https://forum.magicmirror.builders/post/68192</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68192</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 17 Jan 2020 09:50:28 GMT</pubDate></item></channel></rss>
