<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No sound input and no sound output from the MagicMirror]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">My mirror is almost finished. Everything works fine on the screen but i don’t have sound and the mirror is not listening<br />
However I’m sure that the sound input and output are goods. Because i can record a sound and play it via the command prompt<br />
Here is my config : Raspberry Pi2 with jack sound output and USB cam for sound input. I installed MMM Assistant<br />
How can I check the problem ? Somebody knows the problem ?</p>
<p dir="auto">Thanks to all</p>
]]></description><link>https://forum.magicmirror.builders/topic/12047/no-sound-input-and-no-sound-output-from-the-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 19:41:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12047.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Jan 2020 09:06:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No sound input and no sound output from the MagicMirror on Mon, 20 Jan 2020 04:18:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vinck6927" aria-label="Profile: vinck6927">@<bdi>vinck6927</bdi></a> look at the output of two commands</p>
<p dir="auto">list recording devices (microphones)</p>
<pre><code>arecord -l
<p dir="auto">list output devices (speakers)</p>
<pre><code>aplay -l
<p dir="auto">which device did u use for MMM Assistant  config?</p>
<p dir="auto">see <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=110302" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/forums/viewtopic.php?t=110302</a><br />
for speakers</p>
]]></description><link>https://forum.magicmirror.builders/post/68417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68417</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Jan 2020 04:18:04 GMT</pubDate></item></channel></rss>
