<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror]]></title><description><![CDATA[<p dir="auto">I could not find a “good enough” Home Assistant Module for the Mirror, so I forked and developed a bit on the one I thought worked the best.</p>
<h1>Description:</h1>
<p dir="auto">Adds the defined Home Assistant Sensors to your Magic Mirror.</p>
<h1>Screenshots:</h1>
<p dir="auto">Simplest possible:<br />
<img src="https://github.com/Snille/MMM-homeassistant-sensors/raw/master/.github/screen02-simple.png" alt="simple" class=" img-fluid img-markdown" /><br />
Different pictures depending on values from the sensors (with some modified CSS):<br />
<img src="https://github.com/Snille/MMM-homeassistant-sensors/raw/master/.github/screen03-simple+css.png" alt="simple+css" class=" img-fluid img-markdown" /><br />
Different icons depending on values from the sensors:<br />
<img src="https://github.com/Snille/MMM-homeassistant-sensors/raw/master/.github/screen04-simple+icons.png" alt="simple+icons" class=" img-fluid img-markdown" /></p>
<p dir="auto">And here is my personal advanced “look”… :)<br />
<img src="https://github.com/Snille/MMM-homeassistant-sensors/raw/master/.github/screen01-advanced.png" alt="Advanced" class=" img-fluid img-markdown" /></p>
<h1>Download:</h1>
<p dir="auto">[card:Snille/MMM-homeassistant-sensors]</p>
]]></description><link>https://forum.magicmirror.builders/topic/12053/mmm-homeassistant-sensors-development-show-your-ha-sensors-on-your-mirror</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 21:59:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12053.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Jan 2020 17:42:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Thu, 02 Mar 2023 15:38:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joecas65" aria-label="Profile: joecas65">@<bdi>joecas65</bdi></a> said in <a href="/post/108068">MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: Snille">@<bdi>Snille</bdi></a> Hi, is it possible to add a line separator between sensors ?<br />
thanks</p>
<p dir="auto">I like the way the MMM-MyScoreboard does, by adding this line</p>
<pre><code>border-bottom: solid 1px #222;
<p dir="auto">You can add it to your custom.css file (for more info about how to write in css, check <a href="https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1677609386326">https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1677609386326</a>)</p>
]]></description><link>https://forum.magicmirror.builders/post/108070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108070</guid><dc:creator><![CDATA[luisestrada]]></dc:creator><pubDate>Thu, 02 Mar 2023 15:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Thu, 02 Mar 2023 11:59:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: Snille">@<bdi>Snille</bdi></a> Hi, is it possible to add a line separator between sensors ?<br />
thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/108068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108068</guid><dc:creator><![CDATA[joecas65]]></dc:creator><pubDate>Thu, 02 Mar 2023 11:59:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Fri, 03 Feb 2023 22:21:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luisestrada" aria-label="Profile: luisestrada">@<bdi>luisestrada</bdi></a> Yes, however, It can only be “one” control sensor / HA-module.  So, if you have a bunch of lights, and you want to have only one “show” only when that specific light is “on”. You will have to add the module one time / light…<br />
But if you have a specific light that you want to use as a “control sensor” for all the lights, only one module is needed…<br />
I think you could also use an “icon” and some trickery to only show an Icon when the light is lit and when it’s not, not show anything… But not sure… :)</p>
]]></description><link>https://forum.magicmirror.builders/post/107665</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107665</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Fri, 03 Feb 2023 22:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Fri, 03 Feb 2023 20:09:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi, this is not an issue but a question. I have a bunch of lights and I’d like to hide them when they are off,  just to show them when they are on.</p>
<p dir="auto">Is this possible?</p>
]]></description><link>https://forum.magicmirror.builders/post/107664</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/107664</guid><dc:creator><![CDATA[luisestrada]]></dc:creator><pubDate>Fri, 03 Feb 2023 20:09:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Tue, 26 Apr 2022 11:18:32 GMT]]></title><description><![CDATA[<p dir="auto">This goes into your custom.css file in the css directory.<br />
You can change size, color, font weight and line height.   You may need to make changes to these depending on how you want it to look.<br />
Remember when you change the font size you’ll need to change line-height size as well… Line height should be bigger then font size ;)</p>
<pre><code>.MMM-HomeAssistant-Sensors .ha-small {
  font-size: 22px;
  line-height: 18px;
  font-weight: bold;
  color: #fff
.MMM-HomeAssistant-Sensors .ha-normal {
  font-size: 30px;
  line-height: 25px;
  color: #fff
.MMM-HomeAssistant-Sensors .ha-big {
  font-size: 42px;
  line-height: 26px;
  color: #fff
]]></description><link>https://forum.magicmirror.builders/post/101487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101487</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 26 Apr 2022 11:18:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Mon, 25 Apr 2022 07:10:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> duly noted and agreed. That approach is the right one.</p>
]]></description><link>https://forum.magicmirror.builders/post/101452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101452</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Mon, 25 Apr 2022 07:10:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sun, 24 Apr 2022 12:04:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: Ivanov_d">@<bdi>Ivanov_d</bdi></a> OR the better way,  never change files supplied by mm or a module(as this breaks upgrades or fix distribution). the system is designed to support your local changes</p>
<p dir="auto">edit ~/MagicMirror/css/custom.css<br />
(if it doesn’t exist, create it)</p>
<p dir="auto">add all those definitions but  add the module name (and a space) in front of each</p>
<p dir="auto">.MMM-HomeAssistant-Sensors</p>
<p dir="auto">notice the leading dot</p>
]]></description><link>https://forum.magicmirror.builders/post/101391</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101391</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Apr 2022 12:04:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Mon, 25 Apr 2022 07:11:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/proxxym" aria-label="Profile: proxxym">@<bdi>proxxym</bdi></a> open the following file:</p>
<pre><code>~/MagicMirror/modules/MMM-homeassistant-sensors/MMM-homeassistant-sensors.css
<p dir="auto">find the following lines:</p>
<pre><code>.ha-small {
  font-size: 15px;
  line-height: 18px;
  font-weight: bold;
  color: #999
.ha-normal {
  font-size: 20px;
  line-height: 25px;
  color: #999
.ha-big {
  font-size: 22px;
  line-height: 26px;
  color: #999
<p dir="auto">and either change the .ha-big font-size from 22px to something bigger (e.g. 30px, 36px, etc.)</p>
<p dir="auto">or add a completely separate style:</p>
<pre><code>.ha-extra-big {
  font-size: 36px;
  line-height: 30px;
  color: #999
<p dir="auto">and change this in your config</p>
<pre><code>rowClass = 'extra-big'
]]></description><link>https://forum.magicmirror.builders/post/101380</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101380</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Mon, 25 Apr 2022 07:11:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Fri, 22 Apr 2022 13:35:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/proxxym" aria-label="Profile: proxxym">@<bdi>proxxym</bdi></a> I don’t know, but you can use the developers window to learn what needs to be changed, and test it out</p>
<p dir="auto">see<br />
<a href="https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1650634458947">https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1650634458947</a></p>
]]></description><link>https://forum.magicmirror.builders/post/101336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101336</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 Apr 2022 13:35:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Fri, 22 Apr 2022 13:21:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: Ivanov_d">@<bdi>Ivanov_d</bdi></a>  Thanks,<br />
for me big font is to smal :).<br />
an extra large font or something similar was needed</p>
]]></description><link>https://forum.magicmirror.builders/post/101335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101335</guid><dc:creator><![CDATA[proxxym]]></dc:creator><pubDate>Fri, 22 Apr 2022 13:21:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Mon, 18 Apr 2022 20:47:11 GMT]]></title><description><![CDATA[<p dir="auto">Been working great for me!  I had to change some entities today and it’s still chuggin along :)</p>
]]></description><link>https://forum.magicmirror.builders/post/101258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101258</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 18 Apr 2022 20:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Mon, 18 Apr 2022 14:40:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/proxxym" aria-label="Profile: proxxym">@<bdi>proxxym</bdi></a><br />
<img src="/assets/uploads/files/1650292839318-afaf132e-851b-4ccb-b36b-1d2bebbfd5fc-image.png" alt="afaf132e-851b-4ccb-b36b-1d2bebbfd5fc-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/101247</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101247</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Mon, 18 Apr 2022 14:40:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Mon, 18 Apr 2022 14:27:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
is posible to increase the size of fonts?<br />
something like …small , medium, large…<br />
Thanks,</p>
]]></description><link>https://forum.magicmirror.builders/post/101246</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101246</guid><dc:creator><![CDATA[proxxym]]></dc:creator><pubDate>Mon, 18 Apr 2022 14:27:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Wed, 23 Mar 2022 06:20:48 GMT]]></title><description><![CDATA[<p dir="auto">I finally found out what the issue is. It was an electron bug that is fixed in MM v. 2.18 (I was using an older version). Now everything works.</p>
]]></description><link>https://forum.magicmirror.builders/post/100504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100504</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Wed, 23 Mar 2022 06:20:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 12:27:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: snille">@<bdi>snille</bdi></a> in the config.js:</p>
<p dir="auto"><img src="/assets/uploads/files/1645273618485-c1f76c95-765d-49e9-8755-361f904e1fdf-image.png" alt="c1f76c95-765d-49e9-8755-361f904e1fdf-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/99754</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99754</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sat, 19 Feb 2022 12:27:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 11:41:06 GMT]]></title><description><![CDATA[<p dir="auto">Now it’s working again… On both mu mirrors… I don’t understand why… I fixed the “moment” problem at least, I hope… Pushed that… But I guess it’s still the SSL problems left. But I can’t replicate it. <a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: Ivanov_d">@<bdi>Ivanov_d</bdi></a> Where did you set the debug flag to get the errors?</p>
]]></description><link>https://forum.magicmirror.builders/post/99752</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99752</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Sat, 19 Feb 2022 11:41:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 11:14:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: ivanov_d">@<bdi>ivanov_d</bdi></a> Nah… Not really, never been down the SSL rabbit hole… :) I have just forked this module and “fixed” the things I needed… I hope someone else can give some tips (PR:s)… My javascript skills are not that great ether… :)</p>
]]></description><link>https://forum.magicmirror.builders/post/99751</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99751</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Sat, 19 Feb 2022 11:14:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:55:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: snille">@<bdi>snille</bdi></a> in my case non-SSL connections don’t fail, only SSL ones. Any idea how to find which package might be missing or outdated? My coding skills are a bit rusty :D</p>
]]></description><link>https://forum.magicmirror.builders/post/99749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99749</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:52:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: ivanov_d">@<bdi>ivanov_d</bdi></a>  Interesting… Maybe it’s a package missing, but that would not explain why the non SSL connections would fail…<br />
I found another ting, if you don’t have the “clock” module enabled, the “moment.js” is not loaded, and therefore errors out my module (that uses the moment function)… So I have to fix that somehow as well… :)</p>
]]></description><link>https://forum.magicmirror.builders/post/99748</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99748</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:46:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: snille">@<bdi>snille</bdi></a> said in <a href="/post/99744">MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror</a>:</p>
<p dir="auto">curl -X GET -H “Authorization: Bearer VeRy-LoNg-API-ToKen” -H “Content-Type: application/json” <a href="http://ha-IP:8123/api/states" target="_blank" rel="noopener noreferrer nofollow ugc">http://ha-IP:8123/api/states</a></p>
<p dir="auto">Same here … I get all states with the following URLs:</p>
<p dir="auto"><a href="https://myhome.org:443/api/states" target="_blank" rel="noopener noreferrer nofollow ugc">https://myhome.org:443/api/states</a><br />
<a href="https://myhome/api/states" target="_blank" rel="noopener noreferrer nofollow ugc">https://myhome/api/states</a></p>
<p dir="auto">However, when I try to use the local IP I can’t and that is normal as the certificate is not for that domain:</p>
<pre><code>pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:443/api/states
curl: (7) Failed to connect to 192.168.1.19 port 443: Connection refused
pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:8123/api/states
curl: (60) SSL: no alternative certificate subject name matches target host name '192.168.1.19'
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
<p dir="auto">What is wierd though is that although using SSL, the default port is still 8123, however, the connection is secured</p>
]]></description><link>https://forum.magicmirror.builders/post/99747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99747</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:38:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: Snille">@<bdi>Snille</bdi></a> I think that I found out what the issue might be (at least for my case). I turned on debugging and here is what popped-up:</p>
<pre><code>0|MagicMirror  | [19.02.2022 12:34.16.715] [ERROR]
0|MagicMirror  | MMM-homeassistant-sensors ERROR: Error: certificate has expired
0|MagicMirror  |     at TLSSocket.onConnectSecure (_tls_wrap.js:1501:34)
0|MagicMirror  |     at TLSSocket.emit (events.js:315:20)
0|MagicMirror  |     at TLSSocket._finishInit (_tls_wrap.js:936:8)
0|MagicMirror  |     at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:710:12) {
0|MagicMirror  |   code: 'CERT_HAS_EXPIRED'
0|MagicMirror  | }
0|MagicMirror  | [19.02.2022 12:34.16.721] [ERROR]
0|MagicMirror  | Whoops! There was an uncaught exception...
0|MagicMirror  | [19.02.2022 12:34.16.727] [ERROR]
0|MagicMirror  | TypeError: Cannot read property 'statusCode' of undefined
0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:22:77)
0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:185:22)
0|MagicMirror  |     at Request.emit (events.js:315:20)
0|MagicMirror  |     at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:877:8)
0|MagicMirror  |     at ClientRequest.emit (events.js:315:20)
0|MagicMirror  |     at TLSSocket.socketErrorListener (_http_client.js:426:9)
0|MagicMirror  |     at emitErrorNT (internal/streams/destroy.js:92:8)
0|MagicMirror  |     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
0|MagicMirror  |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
<p dir="auto">The certificate is valid though:<br />
<img src="/assets/uploads/files/1645267061075-34fa0f78-0e55-4957-a4bd-fc5e9d345303-image.png" alt="34fa0f78-0e55-4957-a4bd-fc5e9d345303-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/99746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99746</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:38:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:27:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: snille">@<bdi>snille</bdi></a> I think you struck the same obstacle as me, mate :D My setup is a bit different as I am not using reverse proxy - it is either SSL or no SSL within the local network and outside of it.<br />
I am looking at the JS code right now … it might have something to do with how the URL is structured as it might not cover both cases, but I have to confirm that.</p>
]]></description><link>https://forum.magicmirror.builders/post/99745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99745</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:27:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:26:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: ivanov_d">@<bdi>ivanov_d</bdi></a> Interesting, I’m not using SSL in HA (I have a Reverse-proxy) that SSL:s everything… So, internally I can get to HA via http (or https) but externally I’ll always go through the reverse-proxy (and SSL). However, the development MM works both with and without SSL. But my real MM now don’t work with either… Darn! :)<br />
What I CAN do, is use curl from ssh on the real MM and get the “status” from all sensors with this…</p>
<pre><code>curl -X GET -H "Authorization: Bearer VeRy-LoNg-API-ToKen" -H "Content-Type: application/json" http://ha-IP:8123/api/states
<p dir="auto">And it lists everything… Hm…</p>
]]></description><link>https://forum.magicmirror.builders/post/99744</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99744</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:26:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror on Sat, 19 Feb 2022 10:08:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/snille" aria-label="Profile: snille">@<bdi>snille</bdi></a> lol sorry to hear that. I managed to get it to work on my main HA instance by removing SSL from my HA configuration.yaml file:</p>
<p dir="auto"><img src="/assets/uploads/files/1645265265986-b3f64a7f-d0e1-4a24-9964-673dceaa165b-image.png" alt="b3f64a7f-d0e1-4a24-9964-673dceaa165b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">However, that doesn’t suit my needs as I control my house through my phone over the Internet and I want SSL to be enabled. I am continuing testing. Will keep you posted.</p>
]]></description><link>https://forum.magicmirror.builders/post/99743</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99743</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sat, 19 Feb 2022 10:08:52 GMT</pubDate></item></channel></rss>
