<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-History Alignment]]></title><description><![CDATA[<p dir="auto">Hi - first time poster here.</p>
<p dir="auto">I have this module in the bottom_right region.  It seems to be defaulting to align to the bottom of that boundary.  I’d prefer it to align vertically to the top, but can’t figure out how to do so.  Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12073/mmm-history-alignment</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 19:05:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12073.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jan 2020 02:56:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-History Alignment on Wed, 29 Jan 2020 22:51:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swendl" aria-label="Profile: swendl">@<bdi>swendl</bdi></a></p>
<p dir="auto">:thumbsup:</p>
<p dir="auto">Kindly mark the topic as solved if you are satisfied with the result. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/68788</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68788</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 29 Jan 2020 22:51:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-History Alignment on Wed, 29 Jan 2020 22:37:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a></p>
<p dir="auto">Thank you!  This helped a great deal.</p>
]]></description><link>https://forum.magicmirror.builders/post/68787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68787</guid><dc:creator><![CDATA[swendl]]></dc:creator><pubDate>Wed, 29 Jan 2020 22:37:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-History Alignment on Mon, 27 Jan 2020 00:26:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swendl" aria-label="Profile: swendl">@<bdi>swendl</bdi></a> said in <a href="/post/68562">MMM-History Alignment</a>:</p>
<p dir="auto">to the top of the region.</p>
<p dir="auto">Well , this would be one way. By pushing up the <code>.xsmall.bright.title</code> in your custom.css file you can accomplish this. If you are using a header it will go along. Add this to your custom.css file. Adjust to your liking.</p>
<pre><code>.MMM-History .xsmall.bright.title {
  margin-bottom: 170px;
]]></description><link>https://forum.magicmirror.builders/post/68681</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68681</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 27 Jan 2020 00:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-History Alignment on Fri, 24 Jan 2020 03:17:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi - to the top of the region.</p>
]]></description><link>https://forum.magicmirror.builders/post/68562</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68562</guid><dc:creator><![CDATA[swendl]]></dc:creator><pubDate>Fri, 24 Jan 2020 03:17:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-History Alignment on Fri, 24 Jan 2020 03:16:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swendl" aria-label="Profile: swendl">@<bdi>swendl</bdi></a> said in <a href="/post/68560">MMM-History Alignment</a>:</p>
<p dir="auto">I’d prefer it to align vertically to the top,</p>
<p dir="auto">To the top of the region or the top of the right side of the display?</p>
]]></description><link>https://forum.magicmirror.builders/post/68561</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68561</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 24 Jan 2020 03:16:54 GMT</pubDate></item></channel></rss>
