<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I can't get the config to open]]></title><description><![CDATA[<p dir="auto">I have the program installed, I went through thee complete setup guide, but now I don’t know how to open the  config to change the weather, location, etc.  I have already changed the file in the config folder to config.js.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1210/i-can-t-get-the-config-to-open</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 06:12:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1210.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Dec 2016 23:32:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I can't get the config to open on Sun, 18 Dec 2016 11:26:00 GMT]]></title><description><![CDATA[<p dir="auto">I am also very new to this, but it isn’t that hard once you’ve stay up till 1:00 3 or 4 times.  Everything I needed to know was here: <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6</a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a><br />
The section you probably need is under “Installing MirrorMirror2” at the end.<br />
I was able to do everything from the forum until I needed to change the weather settings.  For that, I used file manager.  It isn’t as hard as it may seem (even though to a newbie like me all of this stuff seems hard).  After a long time just playing around with it I finally got the MagicMirror2 app set up with autostart, which has a tutorial at: <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a><br />
I hope this helps.  I know how it feels to have no clue of what to do.</p>
]]></description><link>https://forum.magicmirror.builders/post/9516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9516</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Sun, 18 Dec 2016 11:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to I can't get the config to open on Sun, 18 Dec 2016 05:07:48 GMT]]></title><description><![CDATA[<p dir="auto">so im stuck as well… so im clear we need 2 config files in the config folder? one being the one we have to edit  and one being the orginal… as well if we throw in a  module does that also has to be in the config …i ask cause my sytem is not detecting any config files. and.where do i download jslint from… sorry very new to this followed instruction to the T</p>
]]></description><link>https://forum.magicmirror.builders/post/9508</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9508</guid><dc:creator><![CDATA[impuislupus]]></dc:creator><pubDate>Sun, 18 Dec 2016 05:07:48 GMT</pubDate></item><item><title><![CDATA[Reply to I can't get the config to open on Sun, 18 Dec 2016 01:10:16 GMT]]></title><description><![CDATA[<p dir="auto">That must have been it.  I’ll take that into consideration.</p>
]]></description><link>https://forum.magicmirror.builders/post/9506</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9506</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Sun, 18 Dec 2016 01:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to I can't get the config to open on Sun, 18 Dec 2016 00:35:27 GMT]]></title><description><![CDATA[<p dir="auto">I might have solved the issue.  I’m supposed to change the script in the folder not from the terminal aren’t I?</p>
]]></description><link>https://forum.magicmirror.builders/post/9504</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9504</guid><dc:creator><![CDATA[DarthMosh]]></dc:creator><pubDate>Sun, 18 Dec 2016 00:35:27 GMT</pubDate></item><item><title><![CDATA[Reply to I can't get the config to open on Sat, 17 Dec 2016 23:45:05 GMT]]></title><description><![CDATA[<p dir="auto">Try going here: <a href="https://github.com/MichMich/MagicMirror/wiki#default-modules" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki#default-modules</a><br />
There is a complete guide to what to do. Click on one of the default modules to learn how to set it up.  I am new to all of this, but I hope this helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/9503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9503</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Sat, 17 Dec 2016 23:45:05 GMT</pubDate></item><item><title><![CDATA[Reply to I can't get the config to open on Sat, 17 Dec 2016 23:38:16 GMT]]></title><description><![CDATA[<p dir="auto">I have had the same problem.  Was it necessary to change the file in the config folder to config.js?  I never saw that in the tutorial.  That might be exactly what I have been missing.</p>
]]></description><link>https://forum.magicmirror.builders/post/9502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9502</guid><dc:creator><![CDATA[AAPS]]></dc:creator><pubDate>Sat, 17 Dec 2016 23:38:16 GMT</pubDate></item></channel></rss>
