<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend!]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/11991/mmm-assistantmk2-v3">MMM-AssistantMk2 (v3)</a><br />
Friend!<br />
First congratulations on the excellent work!<br />
Everything is working perfectly on my MagicMirror / raspberry PI4.<br />
But I can’t get the STOP VIDEO, PAUSE VIDEO commands to work …<br />
Could you explain in more detail how to make these commands work and also explain how to change the language for these commands (pt-BR)? Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/12107/mmm-youtube-stop-video-pause-video-commands-friend</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 09:53:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12107.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jan 2020 13:09:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Thu, 13 Feb 2020 18:46:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ludacriss57" aria-label="Profile: ludacriss57">@<bdi>ludacriss57</bdi></a><br />
if you think this would be a kind of bug so you want to get a help from developers of this module, post the issue on github repository issue boards.</p>
]]></description><link>https://forum.magicmirror.builders/post/69516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69516</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 13 Feb 2020 18:46:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Thu, 13 Feb 2020 17:48:02 GMT]]></title><description><![CDATA[<p dir="auto">I’m sorry but google still doesn’t respond to any commands :(</p>
<p dir="auto">neither youtube nor reboot / restart …</p>
<p dir="auto">I don’t understand</p>
]]></description><link>https://forum.magicmirror.builders/post/69515</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69515</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Thu, 13 Feb 2020 17:48:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Mon, 10 Feb 2020 22:21:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ludacriss57" aria-label="Profile: ludacriss57">@<bdi>ludacriss57</bdi></a> At the end of the page<br />
<a href="https://github.com/eouia/MMM-YouTube" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-YouTube</a>   says the following:<br />
KNOWN ISSUE: When you use stopVideo, it will not stop the video but replay current video. Use pauseVideo instead. I’ll fix this someday… Sorry.</p>
]]></description><link>https://forum.magicmirror.builders/post/69397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69397</guid><dc:creator><![CDATA[meusprojetoskali]]></dc:creator><pubDate>Mon, 10 Feb 2020 22:21:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 07 Feb 2020 21:10:53 GMT]]></title><description><![CDATA[<p dir="auto">module: “MMM-AssistantMk2”,<br />
position: “top_center”,<br />
config: {<br />
ui: “Classic”,<br />
assistantConfig: {<br />
latitude: ***,<br />
longitude: ***<br />
},<br />
responseConfig: {<br />
useScreenOutput: true,<br />
useAudioOutput: true,<br />
useChime: true,<br />
timer: 5000,<br />
myMagicWord: false<br />
},<br />
micConfig: { // put there configuration generated by auto-installer<br />
recorder: “arecord”,<br />
device: “plughw:1”,<br />
},<br />
recipes: [“Reboot-Restart-Shutdown.js” , “with-MMM-Hotword.js”, “with-MMM-Youtube.js” ],<br />
profiles: {<br />
“default”: {<br />
profileFile: “default.json”,<br />
lang: “fr-FR”,</p>
]]></description><link>https://forum.magicmirror.builders/post/69249</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69249</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 07 Feb 2020 21:10:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 07 Feb 2020 21:08:44 GMT]]></title><description><![CDATA[<p dir="auto">alors j’ai pas compris ce que tu a marquer sur la premiere ligne de ton post lol</p>
<p dir="auto">sinon pour le reste je viens de tester, et Jarvis me dis en gros qu’il ne peu rien faire pour moi</p>
<p dir="auto">var recipe = {<br />
transcriptionHooks: {<br />
“STOP_YOUTUBE”: {<br />
pattern: “stop vidéo”,<br />
command: “STOP_YOUTUBE”</p>
]]></description><link>https://forum.magicmirror.builders/post/69248</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69248</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 07 Feb 2020 21:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 07 Feb 2020 20:47:43 GMT]]></title><description><![CDATA[<p dir="auto">en fait, j’ai mis default les patterns (ordre de recherche vocale pour activer les fonctions) en anglais</p>
<p dir="auto">on va remettre tout en français si vous voulez ;)</p>
<p dir="auto">nous allons commencer par configurer youtube</p>
<p dir="auto">pour cela il faut editer le fichier<br />
`~/MagicMirror/modules/MMM-AssistantMk2/recipes/with-MMM-Youtube.js</p>
<pre><code class="language-js">var recipe = {
    "STOP_YOUTUBE": {
      pattern: "stop video",
      command: "STOP_YOUTUBE"
<p dir="auto">changez <code>pattern: "stop video",</code> en <code>pattern: "stop vidéo",</code></p>
<p dir="auto">un accent sur vidéo fait la différence :)<br />
sauvegardez votre fichier<br />
redemarrer MagicMirror</p>
<p dir="auto">essayer maintenant dire pour arreter une video <code>Jarvis stop vidéo</code><br />
et la video s’arretera :)</p>
]]></description><link>https://forum.magicmirror.builders/post/69247</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69247</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 07 Feb 2020 20:47:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 07 Feb 2020 20:16:14 GMT]]></title><description><![CDATA[<p dir="auto">non problème pas résolu :(</p>
<p dir="auto">les commande pour redémarrer le pi ou magic ne marche pas<br />
idem pour les commandes YouTube…</p>
<p dir="auto">je viens de tout réinstaller sur un pi4 2go et exactement le même problème.</p>
<p dir="auto">le miroir répond a “Jarvis” et “miroir magique”</p>
<p dir="auto">la commande “stop vidéo” je dois la dire directement ou après la commande “Jarvis” ?</p>
]]></description><link>https://forum.magicmirror.builders/post/69245</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69245</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 07 Feb 2020 20:16:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Thu, 06 Feb 2020 21:44:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ludacriss57" aria-label="Profile: ludacriss57">@<bdi>ludacriss57</bdi></a> : votre souci est il résolu ? ou avez-vous besoin de mon aide en français ?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> (MMM-AssistantMK2 développeur)</p>
]]></description><link>https://forum.magicmirror.builders/post/69216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69216</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 06 Feb 2020 21:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 15:10:35 GMT]]></title><description><![CDATA[<pre><code>module: "MMM-AssistantMk2",
position: "top_center",
  ui: "Classic",
  assistantConfig: {
  latitude: ****
  longitude: ****
responseConfig: {
    useChime: true,
    timer: 5000,
    myMagicWord: false
   recorder: "arecord",
   device: "plughw:1",
recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
profiles: {
    "default": {
      profileFile: "default.json",
      lang: "fr-FR",
]]></description><link>https://forum.magicmirror.builders/post/68856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68856</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 31 Jan 2020 15:10:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 14:50:11 GMT]]></title><description><![CDATA[<p dir="auto">at my place i have that</p>
pattern: “stop video”,<br />
]]></description><link>https://forum.magicmirror.builders/post/68855</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68855</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 31 Jan 2020 14:50:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 14:15:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meusprojetoskali" aria-label="Profile: meusprojetoskali">@<bdi>meusprojetoskali</bdi></a></p>
<p dir="auto">that’s exactly it, it opens a video called “stop video”</p>
<p dir="auto">how will i see the logs? sorry i’m very bad at raspberry …</p>
]]></description><link>https://forum.magicmirror.builders/post/68851</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68851</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 31 Jan 2020 14:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 13:07:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meusprojetoskali" aria-label="Profile: meusprojetoskali">@<bdi>meusprojetoskali</bdi></a><br />
See your recipe / transcriptionHook, whether <code>stop video</code> pattern is defined properly.</p>
]]></description><link>https://forum.magicmirror.builders/post/68848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68848</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 31 Jan 2020 13:07:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 12:44:53 GMT]]></title><description><![CDATA[<p dir="auto">In my case the problem is not really the language, kept the default language (English), when I say “STOP VIDEO”, instead of stopping the video, he makes a new search on youtube for a video called “STOP VIDEO”.<br />
Any suggestion?<br />
Use the recipe: with-MMM-Youtube.js</p>
]]></description><link>https://forum.magicmirror.builders/post/68846</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68846</guid><dc:creator><![CDATA[meusprojetoskali]]></dc:creator><pubDate>Fri, 31 Jan 2020 12:44:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 12:17:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ludacriss57" aria-label="Profile: ludacriss57">@<bdi>ludacriss57</bdi></a><br />
what log says?</p>
]]></description><link>https://forum.magicmirror.builders/post/68844</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68844</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 31 Jan 2020 12:17:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Fri, 31 Jan 2020 09:52:48 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have the same problem but I don’t think it comes from the language.</p>
<p dir="auto">in fact even saying “stop video”, nothing happens.</p>
<p dir="auto">similarly for Reboot- Restart-Shutdown, if I ask “reboot please” nothing happens.</p>
<p dir="auto">you have to start the assistant before or you have to say “stop video” or “reboot please” directly?</p>
<p dir="auto">otherwise I think I have a problem with the microphone in the google assistant. during config it marks me “configuarion not work” while it works on “hotword”.</p>
]]></description><link>https://forum.magicmirror.builders/post/68842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68842</guid><dc:creator><![CDATA[ludacriss57]]></dc:creator><pubDate>Fri, 31 Jan 2020 09:52:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-YOUTUBE, &quot;STOP VIDEO, PAUSE VIDEO&quot; COMMANDS Friend! on Tue, 28 Jan 2020 13:55:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meusprojetoskali" aria-label="Profile: meusprojetoskali">@<bdi>meusprojetoskali</bdi></a><br />
If you are using this recipe;<br />
<a href="https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js</a><br />
Change this line for your prefer <code>pattern</code> as your language.</p>
<pre><code class="language-js">  transcriptionHooks: {
    "STOP_YOUTUBE": {
<p dir="auto">Then save it as <code>with-MMM-Youtube-PTBR.js</code>(or any name you want), then in configuration, use that file instead <code>with-MMM-Youtube.js</code></p>
]]></description><link>https://forum.magicmirror.builders/post/68747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68747</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 28 Jan 2020 13:55:44 GMT</pubDate></item></channel></rss>
