<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt2 view:week show start and end date?]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">have been searching for this but can’t figure out where to adjust it - I would say, I’m good with config files, bad with css, so I assume it must be there somewhere :-)</p>
<p dir="auto">I have a count:2 view:week config showing start times of each item, but I’d love to see the end date or the duration of each appointment/item showing as well. Where can I add this?</p>
<p dir="auto">My second question is about overflow items: is there a way to use the overflowRolling option in the view:week mode? I does show a +1 or +3 right now, hight is limited on my screen, but of course my wife would like to see, what was planned in the evenings.</p>
<p dir="auto">Thank you - any hint welcome. It’s not, that I’m not willing to read, but tired of searching and reading the wrong things :-)</p>
]]></description><link>https://forum.magicmirror.builders/topic/12129/mmm-calendarext2-view-week-show-start-and-end-date</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 02:23:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12129.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Feb 2020 11:37:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt2 view:week show start and end date? on Wed, 05 Feb 2020 09:07:00 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Thxs, that helps alot! Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/69117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69117</guid><dc:creator><![CDATA[ShadowMG]]></dc:creator><pubDate>Wed, 05 Feb 2020 09:07:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 view:week show start and end date? on Sun, 02 Feb 2020 13:01:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shadowmg" aria-label="Profile: ShadowMG">@<bdi>ShadowMG</bdi></a><br />
MM’s screen is too small to display them as you wish.  <code>Week</code> or <code>Month</code> view is a kind of summary or overview.<br />
You have these options;</p>
<ul>
<li>Filter / sort  events to display by priority.</li>
<li>Broaden the area by CSS and <code>slotMaxHeight</code> but limited. Because MM has not enough space.</li>
</ul>
<p dir="auto">Or, this is my recommendation.</p>
<ul>
<li>Use other detailed views together like <code>upcoming</code> or <code>daily</code>.  They are made for that purpose, especially <code>upcoming</code> view.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/68947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68947</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 02 Feb 2020 13:01:47 GMT</pubDate></item></channel></rss>
