<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[fail to update Todoist]]></title><description><![CDATA[<p dir="auto">All, my mirror ask for update Todoist so trying</p>
<pre><code>cd MagicMirror/modules/MMM-Todoist/
git pull &amp;&amp; npm install
<p dir="auto">and I get the failure</p>
<pre><code>Aktualisiere 0b27f87..f9bedb8
error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
überschrieben werden:
        package-lock.json
Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen.
Abbruch
<p dir="auto">means my local changes in package-lock.json would be overwritten in case of update.<br />
I can’t remember to change anything :confounded_face:</p>
<p dir="auto">How to fix it please?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12133/fail-to-update-todoist</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 19:49:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12133.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Feb 2020 13:35:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 14:44:27 GMT]]></title><description><![CDATA[<p dir="auto">Thanks that works fine :smiling_face_with_open_mouth_closed_eyes:</p>
<p dir="auto">Other strange thing, meanwhile I got asked to update whole MM and I did.<br />
I had 2.10.0 run and got these output :confounded_face: upgrading from version 2.9.0 to 2.10.1</p>
<pre><code>bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
the log will be /home/pi/MagicMirror/installers/upgrade.log
No LSB modules are available.
doing test run = false
update log will be in /home/pi/MagicMirror/installers/upgrade.log
saving custom.css
fetching latest revisions
there are 4 local files that are different than the master repo
   modules/default/weatherforecast/weatherforecast.js
   package-lock.json
   vendor/package-lock.json
   vendor/vendor.js
any *-lock.json files do not need to be saved
do you want to save these files for later   (Y/n)?y
updating MagicMirror runtime, please wait
npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
&gt; core-js@2.6.11 postinstall /home/pi/MagicMirror/node_modules/core-js
&gt; node -e "try{require('./postinstall')}catch(e){}"
Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
&gt; https://opencollective.com/core-js
&gt; https://www.patreon.com/zloirock
Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
&gt; console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
&gt; node ./msg.js
Attention
    Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
    For more details goto: https://www.npmjs.com/package/console-stamp/v/next
&gt; electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
&gt; node install.js
Downloading tmp-13054-1-SHASUMS256.txt-3.1.13
[============================================&gt;] 100.0% of 4.79 kB (4.79 kB/s)
&gt; magicmirror@2.10.1 install /home/pi/MagicMirror
&gt; cd vendor &amp;&amp; npm install
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
removed 3 packages and audited 220 packages in 18.516s
found 5 vulnerabilities (4 low, 1 high)
  run `npm audit fix` to fix them, or `npm audit` for details
&gt; magicmirror@2.10.1 postinstall /home/pi/MagicMirror
&gt; sh untrack-css.sh &amp;&amp; sh installers/postinstall/postinstall.sh &amp;&amp; npm run install-fonts
MagicMirror installation successful!
&gt; magicmirror@2.10.1 install-fonts /home/pi/MagicMirror
&gt; cd fonts &amp;&amp; npm install
audited 1 package in 13.139s
found 0 vulnerabilities
npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
added 196 packages from 191 contributors, removed 248 packages, updated 268 packages and audited 2766 packages in 1036.068s
processing dependency changes for active modules with package.json files
processing for module MMM-Carousel please wait
audited 859 packages in 28.488s
found 6 vulnerabilities (1 moderate, 5 high)
processing complete for module MMM-Carousel
processing for module MMM-Todoist please wait
audited 63 packages in 5.206s
processing complete for module MMM-Todoist
processing for module MMM-PublicTransportHafas please wait
audited 41 packages in 3.315s
processing complete for module MMM-PublicTransportHafas
audited 41 packages in 3.798s
audited 41 packages in 3s
restoring custom.css
we stashed a set of files that appear changed from the latest repo versions. you should review them
see installers/stashed_files for the list
you can use git checkout stash@{0} -- filename to extract one file from the stash
or git stash pop to restore them all
WARNING..
WARNING.. either will overlay the file just installed by the update
WARNING..
<p dir="auto">Over all I can close this thread</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks fpor your fast help</p>
]]></description><link>https://forum.magicmirror.builders/post/68952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68952</guid><dc:creator><![CDATA[bdream]]></dc:creator><pubDate>Sun, 02 Feb 2020 14:44:27 GMT</pubDate></item><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 17:22:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> you are right - thanks again.<br />
That was the workaround cleaning up the header which shows the undefined in front of the city ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/68962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68962</guid><dc:creator><![CDATA[bdream]]></dc:creator><pubDate>Sun, 02 Feb 2020 17:22:32 GMT</pubDate></item><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 14:53:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdream" aria-label="Profile: bdream">@<bdi>bdream</bdi></a> said in <a href="/post/68952">fail to update Todoist</a>:</p>
<p dir="auto">modules/default/weatherforecast/weatherforecast.js</p>
<p dir="auto">all looks good except for that one file…</p>
<p dir="auto">if you modified it for some special purpose, you need to restore it from the stash.</p>
]]></description><link>https://forum.magicmirror.builders/post/68955</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68955</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Feb 2020 14:53:22 GMT</pubDate></item><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 14:49:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdream" aria-label="Profile: bdream">@<bdi>bdream</bdi></a> on the post that u think solves the problem, click the 3 dots to the right</p>
]]></description><link>https://forum.magicmirror.builders/post/68954</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68954</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Feb 2020 14:49:40 GMT</pubDate></item><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 14:46:15 GMT]]></title><description><![CDATA[<p dir="auto">:smiling_face_with_sunglasses: how to get it makred as solved?</p>
]]></description><link>https://forum.magicmirror.builders/post/68953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68953</guid><dc:creator><![CDATA[bdream]]></dc:creator><pubDate>Sun, 02 Feb 2020 14:46:15 GMT</pubDate></item><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 14:44:27 GMT]]></title><description><![CDATA[<p dir="auto">Thanks that works fine :smiling_face_with_open_mouth_closed_eyes:</p>
saving custom.css
   package-lock.json
   vendor/vendor.js
&gt; node ./msg.js
Attention
WARNING..
WARNING..
]]></description><link>https://forum.magicmirror.builders/post/68952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68952</guid><dc:creator><![CDATA[bdream]]></dc:creator><pubDate>Sun, 02 Feb 2020 14:44:27 GMT</pubDate></item><item><title><![CDATA[Reply to fail to update Todoist on Sun, 02 Feb 2020 14:11:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdream" aria-label="Profile: bdream">@<bdi>bdream</bdi></a> said in <a href="/post/68950">fail to update Todoist</a>:</p>
<p dir="auto">package-lock.json</p>
<p dir="auto">this file is dynamically updated when u do an npm install.</p>
<p dir="auto">so you can delete it, then do the git pull…</p>
]]></description><link>https://forum.magicmirror.builders/post/68951</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68951</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Feb 2020 14:11:59 GMT</pubDate></item></channel></rss>
