<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with Holiday Calendar]]></title><description><![CDATA[<p dir="auto">I’ve been having problem with both the default calendar and MMM-CalendarExt2 and have narrowed it down to a problem with the US_Holidays.ics calendar.  If I comment that calendar out everything works OK but if I leave it in, the default calendar does not load any holidays and not all my calendar events show up in MMM-CalendarExt2.</p>
<p dir="auto">Does anyone have a fix for both modules or an alternate source for US Holidays?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12181/problem-with-holiday-calendar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 03:15:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12181.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Feb 2020 20:49:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with Holiday Calendar on Mon, 10 Feb 2020 21:52:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I’m just saying general ways. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/69393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69393</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 10 Feb 2020 21:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with Holiday Calendar on Mon, 10 Feb 2020 21:50:47 GMT]]></title><description><![CDATA[<p dir="auto">@Sean said in <a href="/post/69390">Problem with Holiday Calendar</a>:</p>
<p dir="auto">clean your old calendar</p>
<p dir="auto">the US calendar from caledarLabs is now presenting both 2019 and 2020 cal events for all holidays. as unique events without repeating rule<br />
we cannot ‘clean it’…</p>
]]></description><link>https://forum.magicmirror.builders/post/69391</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69391</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Feb 2020 21:50:47 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with Holiday Calendar on Mon, 10 Feb 2020 21:44:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/edo" aria-label="Profile: EdO">@<bdi>EdO</bdi></a><br />
calext2’s week/month view will load limited number of events for performance. default might be 100(recently i raised up to 1000 with new updates)<br />
if there be too many old events(usually happens by repeating rules), loading quota will be exhausted before handling nowadays events.</p>
<p dir="auto">solutions: one of belows;</p>
<ul>
<li>set ‘maxItems’ of view to enough</li>
<li>filter/sort events for view by your purpose and priority</li>
<li>clean your old calendar</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/69390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69390</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 10 Feb 2020 21:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with Holiday Calendar on Mon, 10 Feb 2020 21:10:24 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I just saw that and followed your guidance.  I was in the process of re-posting it here when your post showed up.  It did fix the basic calendar, but didn’t fix the problem with MMM-CalendarExt2 where it is one of three calendars I used to display a monthly calendar, mine, my wife’s and the holidays.  The result is only my calendar is displayed and no holidays or my wife’s events.  However, if I comment the holiday calendar out, both my calendar and my wife’s displays fine.  I suspect the empty repeating rule messes up MMM-CalendarExt2.</p>
]]></description><link>https://forum.magicmirror.builders/post/69384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69384</guid><dc:creator><![CDATA[EdO]]></dc:creator><pubDate>Mon, 10 Feb 2020 21:10:24 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with Holiday Calendar on Mon, 10 Feb 2020 21:06:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/edo" aria-label="Profile: EdO">@<bdi>EdO</bdi></a> the us holidays calendar has started putting in an empty repeating rule, which the code can’t handle ( and I don’t think is correct, and have reported).</p>
<p dir="auto">See my post here for the short term fix<br />
<a href="https://github.com/MichMich/MagicMirror/issues/1922" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/1922</a></p>
]]></description><link>https://forum.magicmirror.builders/post/69383</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69383</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 10 Feb 2020 21:06:05 GMT</pubDate></item></channel></rss>
