<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[have 2 instances of newsfeed]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/10982/how-to-run-two-instances-of-one-module">How to run two instances of one module?</a></p>
<p dir="auto">Hello,</p>
<p dir="auto">i have a lot of duplicate instances for modules but it doesn’t work with newsfeed. Normally i copy folder, change the name and change the register name but no way here…i want it to have some rss on a another position.<br />
thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12189/have-2-instances-of-newsfeed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 14:09:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12189.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Feb 2020 18:25:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to have 2 instances of newsfeed on Tue, 11 Feb 2020 23:27:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> because the copied module is  in the default folder, but NOT in the list of default modules<br />
you have to use the folder name in front of the module name</p>
<pre><code>module: "default/newsfeed2",
<p dir="auto">works for me</p>
]]></description><link>https://forum.magicmirror.builders/post/69430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69430</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Feb 2020 23:27:41 GMT</pubDate></item><item><title><![CDATA[Reply to have 2 instances of newsfeed on Tue, 11 Feb 2020 19:26:38 GMT]]></title><description><![CDATA[<p dir="auto">you are always the king for me. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/69434</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69434</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Tue, 11 Feb 2020 19:26:38 GMT</pubDate></item><item><title><![CDATA[Reply to have 2 instances of newsfeed on Tue, 11 Feb 2020 23:27:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chassain-0" aria-label="Profile: chassain-0">@<bdi>chassain-0</bdi></a> because the copied module is  in the default folder, but NOT in the list of default modules<br />
]]></description><link>https://forum.magicmirror.builders/post/69430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69430</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Feb 2020 23:27:41 GMT</pubDate></item></channel></rss>
