<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stuck on booting in portrait mode]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I am a beginner to magic mirror and raspberry pi in general. I installed mm and it’s running ok in landscape mode. However when I try to specify display rotate= 1 in boot config file, the display rotated but magic mirror software gets stuck on loading screen. I have tried rebooting pi many times and killing mm software and restarting it. Also tried various options like lcd rotate and display rotate= 1,3 etc. however even after pi display is rotated, magic mirror fails to load modules</p>
<p dir="auto">All modules are default ones, and set up works perfectly in landscape mode.<br />
Please help me debug this.</p>
<p dir="auto">Raspberry pi 4 with 2gb ram and dell monitor with dvi input, I am using hdmi to dvi adapter.<br />
Note if I press ctrl+w ( I read about this somewhere online) I see magic mirror momentarily flashes the modules but they go almost instantly. Also I notice the pi becomes a bit slow in general when magic mirror is trying to load in portrait mode.</p>
<p dir="auto">I am running pi hole besides magic. Mirror software. Do you think 2gb ram is insufficient for both to run nicely?</p>
<p dir="auto">Thanks for help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12203/stuck-on-booting-in-portrait-mode</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 17:00:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12203.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Feb 2020 09:59:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stuck on booting in portrait mode on Thu, 13 Feb 2020 11:07:27 GMT]]></title><description><![CDATA[<p dir="auto">Reading this : <a href="https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/245">https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/245</a></p>
<p dir="auto">The last post says that the rotation doesn’t work with the drivers that are standard for Rpi 4.</p>
<p dir="auto">So I would suggest you keep it in landscape mode and rotate it with html/css instead.<br />
<a href="https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi">https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi</a></p>
]]></description><link>https://forum.magicmirror.builders/post/69501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69501</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Thu, 13 Feb 2020 11:07:27 GMT</pubDate></item></channel></rss>
