<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotating Screen now...]]></title><description><![CDATA[<p dir="auto">I’m confused as to how to rotate the screen now.</p>
<pre><code>PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
<p dir="auto">How do you do it with this OS Version? The documentation confuses me because of all the “If this OS/driver then …”</p>
<p dir="auto">I’m using defaults for video driver, other than locking the resolution because I turn off the screen when not in use, and the device reboots nightly for other software running on it.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12231/rotating-screen-now</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 16:17:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12231.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Feb 2020 23:24:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotating Screen now... on Sat, 22 Feb 2020 11:51:29 GMT]]></title><description><![CDATA[<p dir="auto">I’ve added the following line to /etc/xdg/lxsession/LXDE-pi</p>
<pre><code>@xrandr --output HDMI-1 --rotate right
<p dir="auto">YMMV, you might have to fiddle with it to suit your rotation and output.</p>
]]></description><link>https://forum.magicmirror.builders/post/69839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/69839</guid><dc:creator><![CDATA[hweigel]]></dc:creator><pubDate>Sat, 22 Feb 2020 11:51:29 GMT</pubDate></item></channel></rss>
