MagicMirror² v2.14.0 is available! For more information about this release, check out this topic.
hourlyforecast
  • Module Developer
    https://github.com/hangorazvan/forecast_plus
    After more tests without success on weatherforecast, I found this solution for hourly forecast.
    Duplicate weatherforecast from module/default folder to module folder,
    change weatherforecast.js to hourlyforecast.js, same for css file,
    change inside js file
    Module.register("weatherforecast", to Module.register("hourlyforecast",
    forecastEndpoint: "forecast/daily" to forecastEndpoint: "forecast",
    day = moment(forecast.dt_txt, "YYYY-MM-DD hh:mm:ss").format("ddd"); to day = moment(forecast.dt_txt, "YYYY-MM-DD hh:mm:ss").format("HH:mm");
    Then put in config.js
         module: "hourlyforecast",
  • This post is deleted!
