<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with the calendar module in Danish]]></title><description><![CDATA[<p dir="auto">Hi All</p>
<p dir="auto">I’m looking into the magic mirror again, now that the mirror piece is getting closer to being ordered.</p>
<p dir="auto">I just noticed that my language code in the config was set to da for danish, but it should be dk according to the yrthen module.</p>
<p dir="auto">But if I set the language code in the config to dk, the calendar will not load, it just shows loading, the YrThen module shows danish though.<br />
If I set it to da, the calendar is showing the right language, but then the weather is showing norwegian instead.</p>
<p dir="auto">So what is the correct language code, is it the YrThen module that is wrong?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12292/problem-with-the-calendar-module-in-danish</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 01:19:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12292.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Mar 2020 14:27:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with the calendar module in Danish on Fri, 06 Mar 2020 21:54:04 GMT]]></title><description><![CDATA[<p dir="auto">@Sean Gotcha, thankyou for clearing it up.<br />
So now <a class="plugin-mentions-user plugin-mentions-a" href="/user/fmandal" aria-label="Profile: fmandal">@<bdi>fmandal</bdi></a> just needs to modify the files to reflect on da instead of dk :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/70291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70291</guid><dc:creator><![CDATA[fribse]]></dc:creator><pubDate>Fri, 06 Mar 2020 21:54:04 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with the calendar module in Danish on Fri, 06 Mar 2020 21:05:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fribse" aria-label="Profile: fribse">@<bdi>fribse</bdi></a><br />
‘dk’ is country code(ISO-3166) for Denmark.<br />
‘da’ is language code(ISO-639) for Danish.<br />
They could be composed to present locale ‘da-dk’. That scheme is named as IETF language tag(RFC-5646)<br />
Ideally, ‘da’ should be used for linguistic identification . ‘dk’ should be used for location identification. But sometimes both are confused by mistakes or ignorance(of developer)</p>
]]></description><link>https://forum.magicmirror.builders/post/70289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70289</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 06 Mar 2020 21:05:18 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with the calendar module in Danish on Fri, 06 Mar 2020 14:46:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fribse" aria-label="Profile: fribse">@<bdi>fribse</bdi></a> Ok, I modified the MMM-YrThen.js so it checks for the language code da instead of dk, then it’s shown correctly, but which is it, is it da or dk for danish in MagicMirror, usually it’s da but who knows here?</p>
]]></description><link>https://forum.magicmirror.builders/post/70278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70278</guid><dc:creator><![CDATA[fribse]]></dc:creator><pubDate>Fri, 06 Mar 2020 14:46:27 GMT</pubDate></item></channel></rss>
