<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM on NanopiM4 using Lubuntu...]]></title><description><![CDATA[<p dir="auto">howdy folks,</p>
<p dir="auto">So as above, ive got a NanopiM4 4gb spare and i was wondering if its possible to install MM on it?</p>
<p dir="auto">if so is it just plow on as per usual?</p>
<p dir="auto">Commets/criticisms… GO!</p>
]]></description><link>https://forum.magicmirror.builders/topic/12297/mm-on-nanopim4-using-lubuntu</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 22:43:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12297.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Mar 2020 04:13:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Fri, 13 Mar 2020 19:27:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a>  I have updated the <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> script… if you would like the latest copy do</p>
<pre><code>cd ~/MagicMirror
curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh &gt; run-start.sh
]]></description><link>https://forum.magicmirror.builders/post/70583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70583</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Mar 2020 19:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Fri, 13 Mar 2020 02:08:53 GMT]]></title><description><![CDATA[<p dir="auto">Perfect, thanks a lot for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/70554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70554</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Fri, 13 Mar 2020 02:08:53 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Fri, 13 Mar 2020 01:15:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a> cool. Edit the <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> and change</p>
<p dir="auto">pgrep Xorg<br />
To<br />
pgrep X</p>
<p dir="auto">Until I can make the right change</p>
<p dir="auto">Thank you for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/70553</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70553</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Mar 2020 01:15:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Fri, 13 Mar 2020 01:01:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">894</p>
]]></description><link>https://forum.magicmirror.builders/post/70552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70552</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Fri, 13 Mar 2020 01:01:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Fri, 13 Mar 2020 00:58:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a> cool.</p>
<p dir="auto">Can u try pgrep X</p>
]]></description><link>https://forum.magicmirror.builders/post/70550</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70550</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Mar 2020 00:58:09 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Fri, 13 Mar 2020 00:34:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">result of <code>ps -ef</code>:</p>
<pre><code>UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 11:16 ?        00:00:07 /sbin/init
root         2     0  0 11:16 ?        00:00:00 [kthreadd]
root         3     2  0 11:16 ?        00:00:00 [ksoftirqd/0]
root         4     2  0 11:16 ?        00:00:00 [kworker/0:0]
root         5     2  0 11:16 ?        00:00:00 [kworker/0:0H]
root         7     2  0 11:16 ?        00:00:11 [rcu_sched]
root         8     2  0 11:16 ?        00:00:00 [rcu_bh]
root         9     2  0 11:16 ?        00:00:00 [migration/0]
root        10     2  0 11:16 ?        00:00:00 [watchdog/0]
root        11     2  0 11:16 ?        00:00:00 [watchdog/1]
root        12     2  0 11:16 ?        00:00:00 [migration/1]
root        13     2  0 11:16 ?        00:00:00 [ksoftirqd/1]
root        15     2  0 11:16 ?        00:00:00 [kworker/1:0H]
root        16     2  0 11:16 ?        00:00:00 [watchdog/2]
root        17     2  0 11:16 ?        00:00:00 [migration/2]
root        18     2  0 11:16 ?        00:00:00 [ksoftirqd/2]
root        20     2  0 11:16 ?        00:00:00 [kworker/2:0H]
root        21     2  0 11:16 ?        00:00:00 [watchdog/3]
root        22     2  0 11:16 ?        00:00:00 [migration/3]
root        23     2  0 11:16 ?        00:00:00 [ksoftirqd/3]
root        25     2  0 11:16 ?        00:00:00 [kworker/3:0H]
root        26     2  0 11:16 ?        00:00:00 [watchdog/4]
root        27     2  0 11:16 ?        00:00:00 [migration/4]
root        28     2  0 11:16 ?        00:00:00 [ksoftirqd/4]
root        30     2  0 11:16 ?        00:00:00 [kworker/4:0H]
root        31     2  0 11:16 ?        00:00:00 [watchdog/5]
root        32     2  0 11:16 ?        00:00:00 [migration/5]
root        33     2  0 11:16 ?        00:00:00 [ksoftirqd/5]
root        35     2  0 11:16 ?        00:00:00 [kworker/5:0H]
root        36     2  0 11:16 ?        00:00:00 [kdevtmpfs]
root        37     2  0 11:16 ?        00:00:00 [netns]
root        38     2  0 11:16 ?        00:00:00 [perf]
root        39     2  0 11:16 ?        00:00:00 [khungtaskd]
root        40     2  0 11:16 ?        00:00:00 [writeback]
root        41     2  0 11:16 ?        00:00:00 [khugepaged]
root        42     2  0 11:16 ?        00:00:00 [crypto]
root        43     2  0 11:16 ?        00:00:00 [bioset]
root        44     2  0 11:16 ?        00:00:00 [kblockd]
root        46     2  0 11:16 ?        00:00:00 [ata_sff]
root        47     2  0 11:16 ?        00:00:00 [devfreq_wq]
root        48     2  0 11:16 ?        00:00:00 [cfg80211]
root        49     2  0 11:16 ?        00:00:06 [cfinteractive]
root        51     2  0 11:16 ?        00:00:00 [rpciod]
root        66     2  0 11:16 ?        00:00:00 [kswapd0]
root        67     2  0 11:16 ?        00:00:00 [vmstat]
root        68     2  0 11:16 ?        00:00:00 [fsnotify_mark]
root        69     2  0 11:16 ?        00:00:00 [SquashFS read w]
root        70     2  0 11:16 ?        00:00:00 [nfsiod]
root       115     2  0 11:16 ?        00:00:00 [kthrotld]
root       116     2  0 11:16 ?        00:00:00 [irq/231-rockchi]
root       117     2  0 11:16 ?        00:00:00 [vcodec]
root       118     2  0 11:16 ?        00:00:00 [irq/47-ff650000]
root       119     2  0 11:16 ?        00:00:00 [irq/46-ff650000]
root       121     2  0 11:16 ?        00:00:00 [vcodec]
root       122     2  0 11:16 ?        00:00:00 [irq/49-ff660000]
root       123     2  0 11:16 ?        00:00:00 [kworker/1:1]
root       124     2  0 11:16 ?        00:00:00 [bioset]
root       125     2  0 11:16 ?        00:00:00 [bioset]
root       126     2  0 11:16 ?        00:00:00 [bioset]
root       127     2  0 11:16 ?        00:00:00 [bioset]
root       128     2  0 11:16 ?        00:00:00 [bioset]
root       129     2  0 11:16 ?        00:00:00 [bioset]
root       130     2  0 11:16 ?        00:00:00 [bioset]
root       131     2  0 11:16 ?        00:00:00 [bioset]
root       132     2  0 11:16 ?        00:00:00 [bioset]
root       133     2  0 11:16 ?        00:00:00 [bioset]
root       134     2  0 11:16 ?        00:00:00 [bioset]
root       135     2  0 11:16 ?        00:00:00 [bioset]
root       136     2  0 11:16 ?        00:00:00 [bioset]
root       137     2  0 11:16 ?        00:00:00 [bioset]
root       138     2  0 11:16 ?        00:00:00 [bioset]
root       139     2  0 11:16 ?        00:00:00 [bioset]
root       140     2  0 11:16 ?        00:00:00 [bioset]
root       141     2  0 11:16 ?        00:00:00 [memory_wq]
root       142     2  0 11:16 ?        00:00:00 [nvme]
root       145     2  0 11:16 ?        00:00:00 [kworker/2:1]
root       146     2  0 11:16 ?        00:00:00 [kworker/5:1]
root       147     2  0 11:16 ?        00:00:00 [goodix_wq]
root       148     2  0 11:16 ?        00:00:00 [irq/123-rk808]
root       149     2  0 11:16 ?        00:00:00 [fusb302_wq]
root       150     2  0 11:16 ?        00:00:00 [irq/104-fusb302]
root       151     2  0 11:16 ?        00:00:00 [irq/39-rockchip]
root       152     2  0 11:16 ?        00:00:00 [dm_bufio_cache]
root       154     2  0 11:16 ?        00:00:00 [irq/27-mmc1]
root       156     2  0 11:16 ?        00:00:00 [ipv6_addrconf]
root       157     2  0 11:16 ?        00:00:00 [krfcommd]
root       159     2  0 11:16 ?        00:00:00 [deferwq]
root       160     2  0 11:16 ?        00:00:00 [irq/243-rockchi]
root       161     2  0 11:16 ?        00:00:00 [irq/244-rockchi]
root       162     2  0 11:16 ?        00:00:00 [irq/245-rockchi]
root       163     2  0 11:16 ?        00:00:00 [irq/64-analogix]
root       164     2  0 11:16 ?        00:00:00 [hpd_queue]
root       165     2  0 11:16 ?        00:00:00 [irq/63-ff940000]
root       169     2  0 11:16 ?        00:00:00 [gpu_power_off_w]
root       172     2  0 11:16 ?        00:00:00 [kbase_job_fault]
root       174     2  0 11:16 ?        00:00:00 [bioset]
root       175     2  0 11:16 ?        00:00:16 [mmcqd/0]
root       176     2  0 11:16 ?        00:00:00 [kworker/3:1]
root       228     2  0 11:16 ?        00:00:00 [kworker/4:1H]
root       243     2  0 11:16 ?        00:00:00 [jbd2/mmcblk0p1-]
root       244     2  0 11:16 ?        00:00:00 [ext4-rsv-conver]
root       266     2  0 11:16 ?        00:00:00 [jbd2/mmcblk0p2-]
root       267     2  0 11:16 ?        00:00:00 [ext4-rsv-conver]
root       294     2  0 11:16 ?        00:00:00 [kauditd]
root       303     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-journald
root       331     2  0 11:16 ?        00:00:00 [kworker/4:2]
root       355     2  0 11:16 ?        00:00:00 [kworker/2:1H]
root       369     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-udevd
root       387     2  0 11:16 ?        00:00:00 [kworker/3:2]
root       463     1  0 11:16 ?        00:00:00 /usr/lib/accountsservice/account
gpsd       467     1  0 11:16 ?        00:00:00 /usr/sbin/gpsd -N
syslog     469     1  0 11:16 ?        00:00:00 /usr/sbin/rsyslogd -n
avahi      485     1  0 11:16 ?        00:00:02 avahi-daemon: running [FriendlyE
message+   515     1  0 11:16 ?        00:00:06 /usr/bin/dbus-daemon --system --
avahi      541   485  0 11:16 ?        00:00:00 avahi-daemon: chroot helper
root       573     2  0 11:16 ?        00:00:00 [kworker/5:1H]
root       636     1  0 11:16 ?        00:00:08 /usr/sbin/NetworkManager --no-da
root       659     1  0 11:16 ?        00:00:00 /usr/sbin/cups-browsed
root       668     1  0 11:16 ?        00:00:00 /lib/systemd/systemd-logind
root       690     1  0 11:16 ?        00:00:00 /usr/sbin/cron -f
root       705     2  0 11:16 ?        00:00:00 [wl_escan_handle]
root       706     2  0 11:16 ?        00:00:01 [dhd_watchdog_th]
root       709     2  0 11:16 ?        00:00:02 [dhd_dpc]
root       710     2  0 11:16 ?        00:00:00 [dhd_rxf]
root       770     1  0 11:16 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
root       795     1  0 11:16 ?        00:00:00 /usr/sbin/lightdm
dnsmasq    815     1  0 11:16 ?        00:00:00 /usr/sbin/dnsmasq -x /var/run/dn
root       863     2  0 11:16 ?        00:00:00 [kworker/3:1H]
root       894   795  3 11:16 tty7     00:04:40 /usr/bin/X -core :0 -seat seat0
root       997     2  0 11:16 ?        00:00:00 [kbase_event]
root      1007     2  0 11:16 ?        00:00:00 [dhd_eventd]
root      1008     2  0 11:16 ?        00:00:00 [kworker/1:1H]
root      1010     1  0 11:16 ?        00:00:01 /sbin/wpa_supplicant -u -s -O /r
root      1026   795  0 11:16 ?        00:00:00 lightdm --session-child 12 15
pi        1032     1  0 11:16 ?        00:00:00 /lib/systemd/systemd --user
pi        1035  1032  0 11:16 ?        00:00:00 (sd-pam)
pi        1038  1026  0 11:16 ?        00:00:00 /sbin/upstart --user
pi        1098  1038  0 11:16 ?        00:00:00 upstart-udev-bridge --daemon --u
pi        1101  1038  0 11:16 ?        00:00:00 dbus-daemon --fork --session --a
pi        1136  1038  0 11:16 ?        00:00:00 gnome-keyring-daemon --start --c
pi        1149  1038  0 11:16 ?        00:00:00 upstart-dbus-bridge --daemon --s
pi        1153  1038  0 11:16 ?        00:00:00 upstart-file-bridge --daemon --u
pi        1155  1038  0 11:16 ?        00:00:00 upstart-dbus-bridge --daemon --s
pi        1165  1038  0 11:16 ?        00:00:00 gpg-agent --homedir /home/pi/.gn
pi        1182  1038  0 11:16 ?        00:00:00 /usr/bin/lxsession -s Lubuntu -e
pi        1187  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd
pi        1192  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd-fuse /run/us
root      1200     2  0 11:16 ?        00:00:00 [kworker/0:1H]
pi        1204  1182  0 11:16 ?        00:00:01 openbox --config-file /home/pi/.
pi        1207  1182  0 11:16 ?        00:00:34 lxpanel --profile Lubuntu
pi        1209  1182  0 11:16 ?        00:00:04 pcmanfm --desktop --profile lubu
pi        1215  1038  0 11:16 ?        00:00:00 /usr/bin/ssh-agent -s
pi        1224  1038  0 11:16 ?        00:00:08 nm-applet
pi        1237  1038  0 11:16 ?        00:00:00 xfce4-power-manager
pi        1245  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/xfc
pi        1249  1038  0 11:16 ?        00:00:01 /usr/bin/pulseaudio --start --lo
rtkit     1250     1  0 11:16 ?        00:00:00 /usr/lib/rtkit/rtkit-daemon
root      1259     1  0 11:16 ?        00:00:00 /usr/lib/upower/upowerd
pi        1270  1038  0 11:16 ?        00:00:00 /usr/lib/menu-cache/menu-cached
pi        1291  1038  0 11:16 ?        00:00:00 /usr/lib/at-spi2-core/at-spi-bus
pi        1300  1291  0 11:16 ?        00:00:00 /usr/bin/dbus-daemon --config-fi
pi        1305  1038  0 11:16 ?        00:00:00 /usr/lib/at-spi2-core/at-spi2-re
pi        1318  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-udisks2-volum
root      1321     1  0 11:16 ?        00:00:00 /usr/lib/udisks2/udisksd --no-de
pi        1348  1038  0 11:16 ?        00:00:00 /usr/lib/indicator-sound-gtk2/in
pi        1349  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/ind
root      1411     1  0 11:16 ?        00:00:00 /sbin/dhclient -1 -v -pf /run/dh
pi        1412  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-mo
pi        1442  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volum
pi        1497  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-goa-volume-mo
pi        1526  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfs-afc-volume-mo
root      1530     1  0 11:16 ?        00:00:00 /usr/bin/python3 /usr/share/unat
root      1545     1  0 11:16 ?        00:00:00 /usr/sbin/sshd -D
pi        1555  1038  0 11:16 ?        00:00:00 /usr/lib/gvfs/gvfsd-trash --spaw
whoopsie  1568     1  0 11:16 ?        00:00:00 /usr/bin/whoopsie -f
root      1597     2  0 11:16 ?        00:00:00 [hci0]
root      1598     2  0 11:16 ?        00:00:00 [hci0]
root      1599     1  0 11:16 ?        00:00:00 /usr/bin/hciattach /dev/ttyS0 bc
root      1606     1  0 11:16 ?        00:00:12 /bin/bash /usr/bin/start-rk3399-
root      1611     1  0 11:16 ttyFIQ0  00:00:00 /sbin/agetty --keep-baud 115200
root      1612     1  0 11:16 tty1     00:00:00 /sbin/agetty --noclear tty1 linu
root      1616     1  0 11:16 ?        00:00:00 /usr/lib/bluetooth/bluetoothd
pi        1622     1  0 11:16 ?        00:00:02 PM2 v4.2.3: God Daemon (/home/pi
pi        1693  1038  0 11:16 ?        00:00:05 /usr/bin/python /usr/bin/x-termi
ntp       1700     1  0 11:16 ?        00:00:02 /usr/sbin/ntpd -p /var/run/ntpd.
pi        1747  1038  0 11:16 ?        00:00:00 /usr/lib/arm-linux-gnueabihf/gco
pi        1752  1693  0 11:16 ?        00:00:00 gnome-pty-helper
pi        1753  1693  0 11:16 pts/1    00:00:00 /bin/bash
pi        2623  1207  1 11:18 ?        00:02:03 /usr/lib/chromium-browser/chromi
pi        2637  2623  0 11:18 ?        00:00:00 /usr/lib/chromium-browser/chromi
pi        2639  2637  0 11:18 ?        00:00:00 /usr/lib/chromium-browser/chromi
pi        2660  2623  3 11:18 ?        00:04:22 /usr/lib/chromium-browser/chromi
pi        2664  2623  0 11:18 ?        00:00:20 /usr/lib/chromium-browser/chromi
root      2671     2  0 11:18 ?        00:00:00 [kbase_event]
pi        2714  2639  0 11:18 ?        00:00:06 /usr/lib/chromium-browser/chromi
pi        2760  2639  0 11:18 ?        00:00:17 /usr/lib/chromium-browser/chromi
pi        3054  2639  1 11:18 ?        00:02:10 /usr/lib/chromium-browser/chromi
root      3587     1  0 11:21 ?        00:00:00 /usr/sbin/cupsd -l
root      4334     2  0 11:28 ?        00:00:00 [kworker/5:2]
root      4498     2  0 11:28 ?        00:00:07 [kworker/1:0]
pi        4562  1038  0 11:29 ?        00:00:01 /usr/bin/python /usr/bin/x-termi
pi        4572  4562  0 11:29 ?        00:00:00 gnome-pty-helper
pi        4573  4562  0 11:29 pts/2    00:00:00 /bin/bash
pi        4792  1209  0 11:31 ?        00:00:03 leafpad /home/pi/MagicMirror/con
pi        5864  2639  1 11:44 ?        00:01:25 /usr/lib/chromium-browser/chromi
pi        5927  2639  0 11:44 ?        00:00:00 /usr/lib/chromium-browser/chromi
root      6603     2  0 11:51 ?        00:00:00 [kworker/2:2]
root      7776     2  0 12:07 ?        00:00:00 [kworker/4:1]
root      8056     2  0 12:11 ?        00:00:03 [kworker/u12:2]
root     10915     2  0 12:49 ?        00:00:04 [kworker/0:2]
root     12454     2  0 13:11 ?        00:00:00 [kworker/u13:0]
root     12691     2  0 13:15 ?        00:00:00 [kworker/u12:0]
root     12846     2  0 13:17 ?        00:00:00 [kworker/u13:2]
root     13049     2  0 13:20 ?        00:00:00 [kworker/u12:1]
root     13163     2  0 13:21 ?        00:00:00 [kworker/0:1]
root     13231     2  0 13:22 ?        00:00:00 [kworker/u13:1]
root     13260  1606  0 13:22 ?        00:00:00 sleep 2s
pi       13261  1753  0 13:22 pts/1    00:00:00 ps -ef
pi@FriendlyELEC:~/MagicMirror$
<p dir="auto">and result of <code>lsb-release-a </code> :</p>
<pre><code>pi@FriendlyELEC:~/MagicMirror$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 16.04.6 LTS
Release:	16.04
Codename:	xenia
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/70549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70549</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Fri, 13 Mar 2020 00:34:35 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 23:17:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a> this says xwindows not running( ie text console mode)</p>
<pre><code> pgrep Xorg
+ xorg=
<p dir="auto">Can u do</p>
<pre><code>ps -ef
<p dir="auto">So I can fix the script…</p>
<p dir="auto">And also</p>
<p dir="auto">lsb_release -a</p>
]]></description><link>https://forum.magicmirror.builders/post/70547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70547</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Mar 2020 23:17:35 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 22:23:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>~/MagicMirror$ bash -x ./run-start.sh
+ '[' -f ./untrack-css.sh ']'
+ ./untrack-css.sh
+ grep docker /proc/1/cgroup -qa
+ '[' -z :0.0 ']'
++ uname -m
+ arch=aarch64
+ false=false
++ grep -v '^[[:blank:]]*//' config/config.js
++ awk '{print tolower($2)}'
++ grep -i serveronly:
++ tr -d ',"'\''\r'
+ serveronly=
+ serveronly=false
++ pgrep Xorg
+ xorg=
++ uname
+ mac=Linux
+ '[' false. '!=' false. -o aarch64 == armv6l ']'
+ '[' . == . -a Linux '!=' Darwin ']'
+ '[' false. == true. ']'
+ node serveronly
<p dir="auto">seems to show serveronly to be false?</p>
]]></description><link>https://forum.magicmirror.builders/post/70546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70546</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Thu, 12 Mar 2020 22:23:57 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 15:06:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a> this means u are starting in server only mode.</p>
<p dir="auto">Can u tell me more?</p>
<p dir="auto">execute<br />
cd ~/MagicMirror<br />
bash -x ./run-start.sh</p>
<p dir="auto">And then post the output. (maybe 15 lines)</p>
<p dir="auto">Usually this is because it cannot find xwindows running</p>
<p dir="auto">I made all the changes to run-start</p>
<p dir="auto">on my machine, the output looks like this</p>
<pre><code>bash -x ./run-start.sh
+ ./untrack-css.sh
+ '[' -z :0.0 ']'
++ uname -m
+ arch=x86_64
+ false=false
++ tr -d ',"'\''\r'
+ serveronly=
+ serveronly=false
++ pgrep Xorg
+ xorg=621
++ uname
+ mac=Linux
+ '[' false. '!=' false. -o x86_64 == armv6l ']'
+ '[' 621. == . -a Linux '!=' Darwin ']'
+ node_modules/.bin/electron js/electron.js
]]></description><link>https://forum.magicmirror.builders/post/70522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70522</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Mar 2020 15:06:09 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 10:05:51 GMT]]></title><description><![CDATA[<p dir="auto">with pm2 stopped, when i type <code>npm start </code> nothin happens untill i manually open chrome and goto localhost</p>
]]></description><link>https://forum.magicmirror.builders/post/70516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70516</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Thu, 12 Mar 2020 10:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 09:57:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
So pure MM also cannot be executable standalone?</p>
]]></description><link>https://forum.magicmirror.builders/post/70514</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70514</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 12 Mar 2020 09:57:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 09:56:14 GMT]]></title><description><![CDATA[<p dir="auto">it is a complete fresh install, ran this from link above.</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
]]></description><link>https://forum.magicmirror.builders/post/70513</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70513</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Thu, 12 Mar 2020 09:56:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 09:13:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
Hmmm.<br />
First, Could your default pure MM(without hotword and AMK2) be executed standalone?<br />
Second, if so, you mean when it would be issued only with Hotword and AMK2? (But in browser, both modules work?)<br />
Third, if so, It means your Hotword and AMK2 might have missed or failed on <code>electron-rebuild</code> step.</p>
]]></description><link>https://forum.magicmirror.builders/post/70511</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70511</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 12 Mar 2020 09:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 09:10:35 GMT]]></title><description><![CDATA[<p dir="auto">im using Lubuntu… not sure about electron, have only come across it when installing hotword and MK2assistant.</p>
<p dir="auto">not sure how to launch with kiosk fullscreen mode</p>
]]></description><link>https://forum.magicmirror.builders/post/70510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70510</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Thu, 12 Mar 2020 09:10:35 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 09:04:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
And you can launch Chrom(Chromium) with kiosk fullscreen mode on startup of MagicMirror. It could be alternative solution.</p>
]]></description><link>https://forum.magicmirror.builders/post/70509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70509</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 12 Mar 2020 09:04:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 09:01:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
Electron is not installed? What kind of OS are you using? Almost all Debian clones could handle MM. The possible issue might be about GPU driver.</p>
]]></description><link>https://forum.magicmirror.builders/post/70508</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70508</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 12 Mar 2020 09:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Thu, 12 Mar 2020 08:45:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi again,</p>
<p dir="auto">so i  have MM installed on my M4 and its working, however i can only see it thru my internet browser, where as on my RPI3b+ when i typed <code> npm start</code> a separate window opened.</p>
<p dir="auto">how can i get it back to opening a separate window for MM?</p>
<p dir="auto">thanks again</p>
]]></description><link>https://forum.magicmirror.builders/post/70507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70507</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Thu, 12 Mar 2020 08:45:50 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Sun, 08 Mar 2020 00:32:28 GMT]]></title><description><![CDATA[<p dir="auto">Thanks gents!</p>
]]></description><link>https://forum.magicmirror.builders/post/70323</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70323</guid><dc:creator><![CDATA[banbutcher]]></dc:creator><pubDate>Sun, 08 Mar 2020 00:32:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Sat, 07 Mar 2020 18:55:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a>    run the install script from here<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/70313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Mar 2020 18:55:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM on NanopiM4 using Lubuntu... on Sat, 07 Mar 2020 08:47:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/banbutcher" aria-label="Profile: banbutcher">@<bdi>banbutcher</bdi></a><br />
I haven’t used it. But  99.9% of Debian/Ubuntu clones will work. At least, default MM will. some h/w dependent modules might not work but rare.</p>
]]></description><link>https://forum.magicmirror.builders/post/70302</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70302</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 07 Mar 2020 08:47:51 GMT</pubDate></item></channel></rss>
