<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[USB Camera use as wake up sensor]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">at first my english is not the best :D</p>
<p dir="auto">Can i use a usb Camera to wake up the mirror and after x Time  if nobody in front of camera go in standby,</p>
<p dir="auto">who can i make this if its possible code; module ??</p>
<p dir="auto">At second can i use the camera image on the mirror too.</p>
]]></description><link>https://forum.magicmirror.builders/topic/12326/usb-camera-use-as-wake-up-sensor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 01:24:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12326.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Mar 2020 07:42:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to USB Camera use as wake up sensor on Wed, 11 Mar 2020 14:06:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miked180" aria-label="Profile: Miked180">@<bdi>Miked180</bdi></a> see my response in the other topic…</p>
<p dir="auto">i wrote a module for using a webcam to control screen…</p>
<p dir="auto"><a href="https://github.com/sdetweil/MMM-SleepWake" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MMM-SleepWake</a></p>
<p dir="auto">it uses a linux module to detect camera motion<br />
sudo apt-get install motion<br />
I didn’t want to write and maintain code to interface to an unlimited list of potential cameras…<br />
you can also screen capture on movement, or movie record on movement</p>
<p dir="auto">MMM-SleepWake supports tvservice/dpms and  module hiding as ways to blank the screen<br />
(none of my TVs support dpms, and most of my MM systems are not PIs (which is only where tvservice works)</p>
]]></description><link>https://forum.magicmirror.builders/post/70459</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70459</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Mar 2020 14:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to USB Camera use as wake up sensor on Wed, 11 Mar 2020 13:59:41 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/rejas/MMM-MotionDetector" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/rejas/MMM-MotionDetector</a>.</p>
<p dir="auto">But now i have seen if its longer time off (over 30 mins) , i cant wake up . I must restart</p>
<p dir="auto">Is there any Standby mode on raspberry i should deactivate ( but i cant activate wil keyboard too )</p>
<p dir="auto">i  see that i dont have disable the screensaver.</p>
<p dir="auto">My Problem is that i have  not the folder / etc/ kbd /</p>
<p dir="auto">Where can i get this folder ??</p>
]]></description><link>https://forum.magicmirror.builders/post/70457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70457</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Wed, 11 Mar 2020 13:59:41 GMT</pubDate></item><item><title><![CDATA[Reply to USB Camera use as wake up sensor on Wed, 11 Mar 2020 09:51:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miked180" aria-label="Profile: Miked180">@<bdi>Miked180</bdi></a><br />
Which module works?</p>
]]></description><link>https://forum.magicmirror.builders/post/70455</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70455</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 11 Mar 2020 09:51:53 GMT</pubDate></item><item><title><![CDATA[Reply to USB Camera use as wake up sensor on Wed, 11 Mar 2020 09:44:35 GMT]]></title><description><![CDATA[<p dir="auto">It works, fine , thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/70454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70454</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Wed, 11 Mar 2020 09:44:35 GMT</pubDate></item><item><title><![CDATA[Reply to USB Camera use as wake up sensor on Wed, 11 Mar 2020 08:22:09 GMT]]></title><description><![CDATA[<p dir="auto">Thanks,</p>
<ol>
<li>why i need the proxyserver  here ?  --&gt; forget it, who can red exactly the readme i see the solution for this :D</li>
<li>mus i config the webcam in raspberry , usb port or other ?</li>
</ol>
<p dir="auto">So i  install motion detector and all config in the tutorial, plug in camera on usb and it works ??</p>
]]></description><link>https://forum.magicmirror.builders/post/70452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70452</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Wed, 11 Mar 2020 08:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to USB Camera use as wake up sensor on Wed, 11 Mar 2020 08:20:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miked180" aria-label="Profile: Miked180">@<bdi>Miked180</bdi></a><br />
There be already.<br />
<a href="https://github.com/rejas/MMM-MotionDetector" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/rejas/MMM-MotionDetector</a><br />
<a href="https://github.com/alexyak/motiondetector" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/alexyak/motiondetector</a></p>
<p dir="auto">Hmmm years ago I tested these 2 modules and at that time both worked. But I’m not sure they still be valid with current MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/70450</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70450</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 11 Mar 2020 08:20:13 GMT</pubDate></item></channel></rss>
