<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[no autostart magic Mirror after new setup]]></title><description><![CDATA[<p dir="auto">I have make a new setup now it will not start after autostart. I have make the same as last timer and from tutorial<br />
<a href="https://www.doityourself.rocks/magicmirror/diy-magic-mirror-3-magic-mirror-software-installieren-und-konfigurieren/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.doityourself.rocks/magicmirror/diy-magic-mirror-3-magic-mirror-software-installieren-und-konfigurieren/</a></p>
<p dir="auto">if i command: pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> -_&gt; it starts</p>
<p dir="auto">or</p>
<p dir="auto">command: pm2 update -_&gt; it starts</p>
<p dir="auto">1: i have create file <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a><br />
2. pm2 startup<br />
3. pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a><br />
4. sudo pm2 save</p>
<p dir="auto">mostly comes the message , use: pm2 save --force</p>
<p dir="auto">and after sudo reboot its the same , no autostart.</p>
<p dir="auto">Last setup this works normaly</p>
]]></description><link>https://forum.magicmirror.builders/topic/12334/no-autostart-magic-mirror-after-new-setup</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 21:40:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12334.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Mar 2020 08:27:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 10:04:52 GMT]]></title><description><![CDATA[<p dir="auto">I have solved:</p>
<p dir="auto">After command pm2 startup  --&gt; i have add teh command ( listen as info aofter this entered)</p>
<pre><code>sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
<p dir="auto">now it works, better read from my side  :)</p>
]]></description><link>https://forum.magicmirror.builders/post/70515</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70515</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Thu, 12 Mar 2020 10:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 16:39:10 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your very n1 support</p>
]]></description><link>https://forum.magicmirror.builders/post/70533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70533</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Thu, 12 Mar 2020 16:39:10 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 16:35:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miked180" aria-label="Profile: Miked180">@<bdi>Miked180</bdi></a> glad u found the black screen problem!</p>
]]></description><link>https://forum.magicmirror.builders/post/70531</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70531</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Mar 2020 16:35:30 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 16:34:43 GMT]]></title><description><![CDATA[<p dir="auto">Ok thanks, i use this git in future</p>
<p dir="auto">My Problem with black screen was really the modul : MMM-Motion Detection,</p>
]]></description><link>https://forum.magicmirror.builders/post/70529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70529</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Thu, 12 Mar 2020 16:34:43 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 16:31:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miked180" aria-label="Profile: Miked180">@<bdi>Miked180</bdi></a> all of my scripts are here</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">the one on MM site is broken… and will be removed completely in v 2.11</p>
<p dir="auto">the doc now references optional installers…</p>
]]></description><link>https://forum.magicmirror.builders/post/70527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70527</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Mar 2020 16:31:47 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 16:18:15 GMT]]></title><description><![CDATA[<p dir="auto">yes, i used the install script from : <a href="https://www.doityourself.rocks/magicmirror/diy-magic-mirror-3-magic-mirror-software-installieren-und-konfigurieren/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.doityourself.rocks/magicmirror/diy-magic-mirror-3-magic-mirror-software-installieren-und-konfigurieren/</a></p>
<pre><code>bash -c ‚$"(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
<p dir="auto">Is thsi your script or whats your script ? Link :</p>
]]></description><link>https://forum.magicmirror.builders/post/70526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70526</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Thu, 12 Mar 2020 16:18:15 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 14:37:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miked180" aria-label="Profile: Miked180">@<bdi>Miked180</bdi></a> did u use my setup/install script?</p>
<p dir="auto">It makes that change if needed</p>
]]></description><link>https://forum.magicmirror.builders/post/70520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70520</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Mar 2020 14:37:31 GMT</pubDate></item><item><title><![CDATA[Reply to no autostart magic Mirror after new setup on Thu, 12 Mar 2020 10:04:52 GMT]]></title><description><![CDATA[<p dir="auto">I have solved:</p>
]]></description><link>https://forum.magicmirror.builders/post/70515</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70515</guid><dc:creator><![CDATA[Miked180]]></dc:creator><pubDate>Thu, 12 Mar 2020 10:04:52 GMT</pubDate></item></channel></rss>
