<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RPi 3B+ / high %CPU / high temp]]></title><description><![CDATA[<p dir="auto">Hello Everyone,<br />
I am quite new user here and I would like to ask you for some advise. I have some problems with %CPU and temperature (70-75C)<br />
Platform: RPi 3B+<br />
Electron: v3.1.13<br />
MM: v2.10.1<br />
Cooling: only Al heat sink (no fan)</p>
<p dir="auto">Please find below nmon screenshots:<br />
<img src="undefined" alt="0_1584115655606_proc.jpg" class="img-markdown  img-fluid" /><br />
<img src="undefined" alt="0_1584115660945_memo.jpg" class="img-markdown  img-fluid" /></p>
<p dir="auto">Do you have any ideas how can I solve my problem. I checked previous discussions but information there is quite old:<br />
<a href="https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/122?page=13">link text</a></p>
<p dir="auto">I hope you have some solutions for those problems;)</p>
]]></description><link>https://forum.magicmirror.builders/topic/12340/rpi-3b-high-cpu-high-temp</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 09:35:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12340.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Mar 2020 16:15:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Mon, 16 Mar 2020 21:59:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebson" aria-label="Profile: Ebson">@<bdi>Ebson</bdi></a> said in <a href="/post/70637">RPi 3B+ / high %CPU / high temp</a>:</p>
<p dir="auto">Anyway, I will increase a value.</p>
<p dir="auto">No, I meant that 60 minutes is more than adequate.</p>
<p dir="auto">BTW, it is also nice module for weather.</p>
<p dir="auto">I use a few of my own.</p>
]]></description><link>https://forum.magicmirror.builders/post/70674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70674</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 16 Mar 2020 21:59:05 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Mon, 16 Mar 2020 10:38:26 GMT]]></title><description><![CDATA[<p dir="auto">DarkSky:</p>
<pre><code>  setInterval(function() {
    self.getData();
  }, self.config.updateInterval * 60 * 1000); //convert to milliseconds
<p dir="auto">So, value should be given in minutes in config file. Anyway, I will increase a value. BTW, it is also nice module for weather.</p>
]]></description><link>https://forum.magicmirror.builders/post/70637</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70637</guid><dc:creator><![CDATA[Ebson]]></dc:creator><pubDate>Mon, 16 Mar 2020 10:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Mon, 16 Mar 2020 10:17:00 GMT]]></title><description><![CDATA[<p dir="auto">You are right. I will change it into 6h… or even longer.<br />
There is written in DarkSky’s Documentation that the value should be given in minutes. I don’t really know how to check whether it is not a mistake in Doc. I will make some testing;)</p>
]]></description><link>https://forum.magicmirror.builders/post/70636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70636</guid><dc:creator><![CDATA[Ebson]]></dc:creator><pubDate>Mon, 16 Mar 2020 10:17:00 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Sun, 15 Mar 2020 23:50:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebson" aria-label="Profile: Ebson">@<bdi>Ebson</bdi></a></p>
<p dir="auto">Honestly, I don’t think a 60 minute updateInterval is necessary for WeatherOrNot.</p>
<p dir="auto">DarkSky updateInterval is 60 ms??? (I don’t use that module). If that is miiliseconds it would certainly cause trouble.</p>
]]></description><link>https://forum.magicmirror.builders/post/70630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70630</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 15 Mar 2020 23:50:01 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Sun, 15 Mar 2020 08:42:04 GMT]]></title><description><![CDATA[<p dir="auto">I used:</p>
<ul>
<li>Weather or Not:<br />
<code>updateInterval: 60 * 60 * 1000,</code><br />
<code>icons: Climacons </code>(no animation)</li>
<li>DarkSky:<br />
<code>useAnimatedIcons: false,</code><br />
<code>animateMainIconOnly: false,</code><br />
<code>updateInterval: 60,</code><br />
<code>requestDelay: 1000,</code><br />
<code>updateFadeSpeed: 2000</code></li>
<li>2x Newsfeed:<br />
<code>reloadInterval: 10*60*1000,</code><br />
<code>updateInterval: 15000,</code><br />
<code>animationSpeed: 0</code></li>
</ul>
<p dir="auto">and I ended up with:<br />
<a href="https://ibb.co/M2zPyB0"><img src="https://i.ibb.co/j6C39JX/finnnnnnn.jpg" alt="finnnnnnn" /></a><br />
I still need to consider adding fan but increasing intervals and turning off animation helped a lot<br />
Maybe I will play also with some older electrons.</p>
<p dir="auto">Thank you for your reply;)</p>
]]></description><link>https://forum.magicmirror.builders/post/70609</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70609</guid><dc:creator><![CDATA[Ebson]]></dc:creator><pubDate>Sun, 15 Mar 2020 08:42:04 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Sun, 15 Mar 2020 00:45:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebson" aria-label="Profile: Ebson">@<bdi>Ebson</bdi></a> said in <a href="/post/70589">RPi 3B+ / high %CPU / high temp</a>:</p>
<p dir="auto">'Weather or Not’</p>
<p dir="auto">CPU usage and heat have arisen now and again. If you search the forum you’ll find lots to read and perhaps a solution. At times it has been the version of Pi and other times the version of electron.</p>
<p dir="auto">Concerning MMM-WeatherOrNot: There are only 2 things that I can think of that <em>might</em> affect your Pi negatively.</p>
<ol>
<li>
<p dir="auto">An extremely low updateInternal. The default is <code>updateInterval: 10 * 60 * 1000,</code> (10 minutes)</p>
</li>
<li>
<p dir="auto">The use of the animated icons option.</p>
</li>
</ol>
<p dir="auto">I would like to hear from others if they are having the same issue, whether with a low updateInterval or the animated icons.</p>
]]></description><link>https://forum.magicmirror.builders/post/70598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70598</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 15 Mar 2020 00:45:40 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Sat, 14 Mar 2020 05:14:25 GMT]]></title><description><![CDATA[<p dir="auto">Please discard my previous post. Here is some more detailed testing:<br />
<a href="https://ibb.co/3WWCxjp"><img src="https://i.ibb.co/0ZZG06C/final.jpg" alt="final" /></a></p>
<p dir="auto">It looks like ‘Weather or Not’ and ‘DarkSky’ forecast cause some problems. I will try to play with update interval.</p>
<p dir="auto">Anyway, like in here: <a href="https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/138?page=14">old discussion</a>, my %CPU with default modules look a bit higher than the one presented in old post.</p>
<p dir="auto">Do you think that electron version has some influence?<br />
Could someone else present own %CPU with default modules?</p>
]]></description><link>https://forum.magicmirror.builders/post/70589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70589</guid><dc:creator><![CDATA[Ebson]]></dc:creator><pubDate>Sat, 14 Mar 2020 05:14:25 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Sat, 14 Mar 2020 02:53:30 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://ibb.co/dKJ9Y94"><img src="https://i.ibb.co/VBpy4yY/MM-stop.jpg" alt="MM-stop" /></a>)<br />
I guess too many 3rd party modules ;/ I will try to look for the one that causes problems.</p>
]]></description><link>https://forum.magicmirror.builders/post/70586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70586</guid><dc:creator><![CDATA[Ebson]]></dc:creator><pubDate>Sat, 14 Mar 2020 02:53:30 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Fri, 13 Mar 2020 17:20:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebson" aria-label="Profile: Ebson">@<bdi>Ebson</bdi></a> what does it look like without MM started?</p>
]]></description><link>https://forum.magicmirror.builders/post/70580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70580</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Mar 2020 17:20:08 GMT</pubDate></item><item><title><![CDATA[Reply to RPi 3B+ / high %CPU / high temp on Fri, 13 Mar 2020 16:36:39 GMT]]></title><description><![CDATA[<p dir="auto">![CPU](<a href="https://ibb.co/5xMS9Rw"><img src="https://i.ibb.co/Cs1YtHD/proc.jpg" alt="proc" /></a>)<br />
![Proc](<a href="https://ibb.co/h1MHtnd"><img src="https://i.ibb.co/7NzV6Tp/memo.jpg" alt="memo" /></a>)</p>
]]></description><link>https://forum.magicmirror.builders/post/70571</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70571</guid><dc:creator><![CDATA[Ebson]]></dc:creator><pubDate>Fri, 13 Mar 2020 16:36:39 GMT</pubDate></item></channel></rss>
