<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror and BME280 sensor how to do it?]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’m using MM a while and I thinking when internet or ISP will have technical issue the MM will not work as a weather  forecast. But when connected the bme280 sensor to Raspberry you can have independent from internet weather station.<br />
The problem is that I dont Know how to do it.<br />
Sensor use the i2c and truly said its very easy to connect to Raspberry.<br />
Using script writed in Python or use Domoticz You can see that the sensor works fine, but how to add to MM?<br />
Anyone can help?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12342/magicmirror-and-bme280-sensor-how-to-do-it</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 13:13:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12342.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Mar 2020 17:35:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror and BME280 sensor how to do it? on Tue, 17 Mar 2020 21:49:45 GMT]]></title><description><![CDATA[<p dir="auto">this will take some programming, MM and integration skills…  nothing simple</p>
]]></description><link>https://forum.magicmirror.builders/post/70703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70703</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Mar 2020 21:49:45 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror and BME280 sensor how to do it? on Tue, 17 Mar 2020 21:26:06 GMT]]></title><description><![CDATA[<p dir="auto">Ok.I still fighting.<br />
I found a module for MM but its for caravanpiclimate and its not working.<br />
I installed domoticz and domoticz module and I 've got “Loading Domoticz data…”<br />
and still nothing happened.what I doing wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/70702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70702</guid><dc:creator><![CDATA[Hato]]></dc:creator><pubDate>Tue, 17 Mar 2020 21:26:06 GMT</pubDate></item></channel></rss>
