<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modules don&#x27;t update]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I see that certain modules as News feeds and domoticz do not update datas.<br />
My temperature probes stay not updated, while it changes in domoticz.<br />
How can I fix this issue ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/12422/modules-don-t-update</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:36:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12422.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Mar 2020 18:35:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modules don&#x27;t update on Thu, 26 Mar 2020 20:38:49 GMT]]></title><description><![CDATA[<p dir="auto">Ok, I’ll try to increase the delay.<br />
Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/71220</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71220</guid><dc:creator><![CDATA[mattx38]]></dc:creator><pubDate>Thu, 26 Mar 2020 20:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to Modules don&#x27;t update on Thu, 26 Mar 2020 19:48:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattx38" aria-label="Profile: mattx38">@<bdi>mattx38</bdi></a> no idea… 5000ms is a VERY FAST… probably could be 15000 (15 seconds)</p>
]]></description><link>https://forum.magicmirror.builders/post/71215</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71215</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Mar 2020 19:48:24 GMT</pubDate></item><item><title><![CDATA[Reply to Modules don&#x27;t update on Thu, 26 Mar 2020 19:43:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I know, but for example, the domoticz module has an update interval of 5000ms, then when I see that the temperature of my outside probe has changed 15 minutes ago and the one I see on the MMM is still the old one, there is a problem.</p>
<p dir="auto">If I restart the MMM by the SSH command “pm2 restart mm”, then all datas are up to date…</p>
]]></description><link>https://forum.magicmirror.builders/post/71214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71214</guid><dc:creator><![CDATA[mattx38]]></dc:creator><pubDate>Thu, 26 Mar 2020 19:43:12 GMT</pubDate></item><item><title><![CDATA[Reply to Modules don&#x27;t update on Thu, 26 Mar 2020 18:40:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattx38" aria-label="Profile: mattx38">@<bdi>mattx38</bdi></a> each module should have some sort of configuration for update cycle time.</p>
<p dir="auto">newsfeed has reloadInterval (default 5 minutes), that does NOT mean that the feed itself has changes…</p>
]]></description><link>https://forum.magicmirror.builders/post/71207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71207</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Mar 2020 18:40:30 GMT</pubDate></item></channel></rss>
