<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Voice control with Raspbian Buster]]></title><description><![CDATA[<p dir="auto">Hello everybody,</p>
<p dir="auto">as i have been trying several modules both for Alexa and Google Assistant without success now:<br />
can anyone of you give a recommendation for a recent Voice Module on a Pi3 with Raspbian Buster?</p>
<p dir="auto">The intention is to control an extra OpenHAB-Server via Magicmirror.</p>
<p dir="auto">If not, any recommendations of a working combination of Raspbian and Voice module?<br />
Is it wishful thinking to have this combination even not too complicate to install and setup?<br />
Additional modules to be used:<br />
MMM-PIR-Sensor<br />
MMM-IPCam<br />
MMM-MyCommute<br />
MMM-CalenderExt<br />
MMM-GoogleMapsTraffic</p>
<p dir="auto">Any comments appreciated… ;-)</p>
]]></description><link>https://forum.magicmirror.builders/topic/12429/voice-control-with-raspbian-buster</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 03:03:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12429.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Mar 2020 17:23:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Voice control with Raspbian Buster on Fri, 10 Jul 2020 18:02:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zeisolf" aria-label="Profile: zeisolf">@<bdi>zeisolf</bdi></a> : At the difference with a real Google Home/ Google Nest. MMM-GoogleAssistant Don’t send ANY audio information to Google in stand-by mode<br />
It don’t know that you use <code>Alexa</code> for activating because I don’t use a Google Service for activating ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/78310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78310</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 10 Jul 2020 18:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to Voice control with Raspbian Buster on Fri, 10 Jul 2020 17:30:18 GMT]]></title><description><![CDATA[<p dir="auto">Dear holidayv,</p>
<p dir="auto">thanks for your recommendation.<br />
Finally i tried and quickly succeeded with installation of bugsounet’s Google Assistant, which seems to be the successor of Assistant MK2.<br />
Although i must admit that for “WAF-reasons”;-) i use Alexa as hotword to start GoogleAssistant.<br />
I guess Google will not be happy, sure they already know…!</p>
]]></description><link>https://forum.magicmirror.builders/post/78303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/78303</guid><dc:creator><![CDATA[zeisolf]]></dc:creator><pubDate>Fri, 10 Jul 2020 17:30:18 GMT</pubDate></item><item><title><![CDATA[Reply to Voice control with Raspbian Buster on Mon, 11 May 2020 04:52:07 GMT]]></title><description><![CDATA[<p dir="auto">I’ve had good luck with AssistantMK2. It’s well put together, constantly being updated and improved. And the developer is pretty active in the forum.</p>
]]></description><link>https://forum.magicmirror.builders/post/75009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/75009</guid><dc:creator><![CDATA[holidayv]]></dc:creator><pubDate>Mon, 11 May 2020 04:52:07 GMT</pubDate></item></channel></rss>
