<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM on Pi Zero fails after being off for a few days]]></title><description><![CDATA[<p dir="auto">I’ve had my MM running well for months, but I had to shut it down recently to move it and when I plugged everything in again afterwards it doesn’t load on the Pi’s screen. It does however load fine if i remotely connect to the url for my MM on another computer.</p>
<p dir="auto">i assumed it might be a problem with Chromium so I removed and re-installed that, but it made no difference.</p>
<p dir="auto">Next I tried re-installing again on top of my current installation (from here <a href="http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/" target="_blank" rel="noopener noreferrer nofollow ugc">http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/</a>) but have had no luck.</p>
<p dir="auto">The description of the problem is that the Pi boots to terminal then screen goes black and I see a mouse cursor, then it drops back to the terminal and just loops between the two every 30s or so.</p>
<p dir="auto">Is there a way to diagnose what’s going on as I really don’t want to start from scratch again.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/topic/12440/mm-on-pi-zero-fails-after-being-off-for-a-few-days</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 18:17:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/12440.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Mar 2020 20:01:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 21:32:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> no idea… never tried lite<br />
you can certainly run serveronly…  as u did and the <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>  executes…</p>
<p dir="auto">if you try to run chromium-browser<br />
what happens?  on my pi0w desktop it comes up as expected</p>
]]></description><link>https://forum.magicmirror.builders/post/71415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71415</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 21:32:34 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 21:30:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It seemed to work well without it in the past, has something changed?<br />
I always found the Desktop version really laggy on the Zero so try to avoid it when not necessary.</p>
]]></description><link>https://forum.magicmirror.builders/post/71414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71414</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 21:30:02 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 20:00:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> you MUST run desktop for chromium to work…</p>
<p dir="auto">from the shell, do</p>
<p dir="auto">pgrep Xorg</p>
<p dir="auto">it should return a number</p>
]]></description><link>https://forum.magicmirror.builders/post/71397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71397</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 20:00:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 19:31:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yes, and then rebooted for good measure. Could it be anything to do with me running Raspbian Lite and not Desktop?</p>
]]></description><link>https://forum.magicmirror.builders/post/71396</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71396</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 19:31:06 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 18:52:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> did u install chromium-browser<br />
the <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> script depends on it</p>
]]></description><link>https://forum.magicmirror.builders/post/71395</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71395</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 18:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 17:59:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I renamed the old MM directory and ran your script</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
<p dir="auto">Everything went successfully, I can see the display from other computers but the pi just sits at a terminal prompt, is there something I need to do to start things off?</p>
<pre><code>$ pm2 list
│ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
│ 1  │ MagicMirror             │ 2.10.1  │ fork    │ 568      │ 2m     │ 1    │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
]]></description><link>https://forum.magicmirror.builders/post/71393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71393</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 17:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 14:52:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> i have a system that is like that… power messes up everything…</p>
<p dir="auto">I have moved to boot from sd card, RUN from ssd…</p>
<p dir="auto"><a href="https://jamesachambers.com/raspberry-pi-4-usb-boot-config-guide-for-ssd-flash-drives/" target="_blank" rel="noopener noreferrer nofollow ugc">https://jamesachambers.com/raspberry-pi-4-usb-boot-config-guide-for-ssd-flash-drives/</a><br />
see starting here<br />
USB Boot Instructions</p>
]]></description><link>https://forum.magicmirror.builders/post/71382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71382</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 14:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 14:46:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> use my install script</p>
<p dir="auto">see here<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">rename existing MM folder out of the way<br />
run the install script… it does everything…</p>
<p dir="auto">(well, not install chromium browser)<br />
sudo apt-get install chromium-browser</p>
]]></description><link>https://forum.magicmirror.builders/post/71381</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71381</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 14:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 14:36:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> looks like the quickest fix is to re-install again. It’s a pain as I probably have to do this about once or twice a year. It can be working great then either the power will unexpectedly go out or I’ll shut it down for some reason and then it takes a full wipe and re-install to get it working again.</p>
]]></description><link>https://forum.magicmirror.builders/post/71379</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71379</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 14:36:41 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 14:35:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> no… its stuck with the chromium-browser not loading…</p>
<p dir="auto">I think u need to reinstall the chromium browser…</p>
<p dir="auto">this means there was an update , or there is an sd card problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/71378</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71378</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 14:35:01 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 14:11:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/71371">MM on Pi Zero fails after being off for a few days</a>:</p>
<p dir="auto">./run-start.sh</p>
<p dir="auto">When I run</p>
<pre><code>chromium-browser  --app=https://cnn.com
<p dir="auto">I get command not found, so I tried</p>
<pre><code>chromium  --app=https://cnn.com
<p dir="auto">and I get Illegal Instruction.</p>
<p dir="auto">i tried your script, and I get the text on screen about no helper found etc, then it gets stuck when trying to fetch the calendar data.  I can access it from another computer but the pi is still blank on screen</p>
<p dir="auto">Edit: It does seem to go through the calendar step but just very slowly, still progressing to each successive calendar now. I’ll leave it running and see if it eventually successfully starts.</p>
]]></description><link>https://forum.magicmirror.builders/post/71374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71374</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 14:11:55 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:26:56 GMT]]></title><description><![CDATA[<p dir="auto">weird… seems like chrome is having trouble.</p>
<p dir="auto">if you type</p>
<p dir="auto">does it come up?</p>
<p dir="auto">in 2.10, i created a similar script for<br />
pi0w(armv6l) as electron doesn’t exist anymore</p>
<p dir="auto">try this script</p>
<pre><code>curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh &gt;~/MagicMirror/run-start.sh
chmod +x ~/MagicMirror/run-start.sh
<p dir="auto">then</p>
<pre><code>cd ~/MagicMirror
./run-start.sh
]]></description><link>https://forum.magicmirror.builders/post/71371</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71371</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:26:56 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:21:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it works in as much as I can see the magic mirror on another computer when I point to the correct IP, but the pi itself does not display anything at all, it sits at a terminal prompt or if I reboot and let it try to start on its own it’ll switch from prompt to black screen with mouse pointer as if it’s trying to start, then it loops back to a prompt and cycles between the two states.</p>
]]></description><link>https://forum.magicmirror.builders/post/71370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71370</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:21:52 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:18:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> weird…</p>
<p dir="auto">and if you do pm2 start 0 it works ok?</p>
]]></description><link>https://forum.magicmirror.builders/post/71369</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71369</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:18:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:10:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>#!/bin/sh
unclutter &amp;
xset -dpms # disable DPMS (Energy Star) features.
xset s off # disable screen saver
xset s noblank # don’t blank the video device
matchbox-window-manager &amp;
chromium-browser -–incognito --start-fullscreen -–kiosk http://localhost:8080/
]]></description><link>https://forum.magicmirror.builders/post/71365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71365</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:10:29 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:09:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> said in <a href="/post/71361">MM on Pi Zero fails after being off for a few days</a>:</p>
<p dir="auto">xinit /home/pi/chromium_start.sh</p>
<p dir="auto">and that one?</p>
]]></description><link>https://forum.magicmirror.builders/post/71363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71363</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:09:25 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:08:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>#!/bin/bash
cd ~/MagicMirror
node serveronly &amp;
sleep 30
]]></description><link>https://forum.magicmirror.builders/post/71361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71361</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:08:08 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:07:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> said in <a href="/post/71358">MM on Pi Zero fails after being off for a few days</a>:</p>
<p dir="auto">/home/pi/mmstart.sh</p>
<p dir="auto">can u show that file</p>
]]></description><link>https://forum.magicmirror.builders/post/71360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71360</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:07:04 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:05:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>Describing process with id 0 - name mmstart
│ status            │ stopped                              │
│ name              │ mmstart                              │
│ version           │ N/A                                  │
│ restarts          │ 1780                                 │
│ uptime            │ 0                                    │
│ script path       │ /home/pi/mmstart.sh                  │
│ script args       │ N/A                                  │
│ error log path    │ /home/pi/.pm2/logs/mmstart-error.log │
│ out log path      │ /home/pi/.pm2/logs/mmstart-out.log   │
│ pid path          │ /home/pi/.pm2/pids/mmstart-0.pid     │
│ interpreter       │ bash                                 │
│ interpreter args  │ N/A                                  │
│ script id         │ 0                                    │
│ exec cwd          │ /home/pi                             │
│ exec mode         │ fork_mode                            │
│ node.js version   │ N/A                                  │
│ node env          │ N/A                                  │
│ watch &amp; reload    │ ✘                                    │
│ unstable restarts │ 0                                    │
│ created at        │ 2020-03-28T19:51:14.338Z             │
Divergent env variables from local env
│ SSH_CONNECTION │ 192.168.1.148 54823 192.168.1.166 22 │
│ XDG_SESSION_ID │ c2                                   │
│ SSH_CLIENT     │ 192.168.1.148 54823 22               │
│ SSH_TTY        │ /dev/pts/1                           │
Add your own code metrics: http://bit.ly/code-metrics
Use `pm2 logs mmstart [--lines 1000]` to display logs
Use `pm2 env 0` to display environment variables
Use `pm2 monit` to monitor CPU and Memory usage mmstart
]]></description><link>https://forum.magicmirror.builders/post/71358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71358</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:05:55 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:04:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> pm2 info 0</p>
]]></description><link>https://forum.magicmirror.builders/post/71357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71357</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:04:18 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:03:12 GMT]]></title><description><![CDATA[<p dir="auto">Everything was stopped.</p>
<pre><code>$ pm2 status
│ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
│ 0  │ mmstart            │ fork     │ 1780 │ stopped  │ 0%       │ 0b       │
]]></description><link>https://forum.magicmirror.builders/post/71356</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71356</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:03:12 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 13:02:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a> ok,  do</p>
<p dir="auto">pm2 status</p>
<p dir="auto">it seems there is something already running</p>
]]></description><link>https://forum.magicmirror.builders/post/71355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71355</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 13:02:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 12:57:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/71334">MM on Pi Zero fails after being off for a few days</a>:</p>
<p dir="auto">pm2 logs --lines=100</p>
<p dir="auto">Here’s the last 100 lines of the pm2 log, with a few of the first PM2 lines removed as they were identical :-</p>
<pre><code>[TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
/home/pi/.pm2/pm2.log last 100 lines:
PM2        | 2020-03-29T09:27:24: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:27:58: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:27:58: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:27:58: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:28:32: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:28:32: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:28:32: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:29:05: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:29:05: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:29:05: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:29:42: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:29:42: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:29:42: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:30:16: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:30:16: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:30:16: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:30:49: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:30:49: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:30:49: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:31:23: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:31:23: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:31:23: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:31:57: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:31:57: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:31:57: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:32:31: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:32:31: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:32:31: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:33:04: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:33:04: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:33:04: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:33:38: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:33:38: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:33:38: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:34:12: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:34:12: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:34:12: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:34:48: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:34:48: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:34:48: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:35:24: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:35:24: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:35:24: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:35:58: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:35:58: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:35:58: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:36:32: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:36:32: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:36:32: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:37:06: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:37:06: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:37:06: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:44:58: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:44:58: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:44:58: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:45:35: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:45:35: PM2 log: App [mmstart:0] starting in -fork mode-
PM2        | 2020-03-29T09:45:35: PM2 log: App [mmstart:0] online
PM2        | 2020-03-29T09:46:01: PM2 log: Stopping app:mmstart id:0
PM2        | 2020-03-29T09:46:02: PM2 log: App [mmstart:0] exited with code [0] via signal [SIGINT]
PM2        | 2020-03-29T09:46:02: PM2 log: pid=27183 msg=process killed
/home/pi/.pm2/logs/mmstart-error.log last 100 lines:
0|mmstart  |     at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
0|mmstart  |     at startup (internal/bootstrap/node.js:283:19)
0|mmstart  |     at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
0|mmstart  |   code: 'EADDRINUSE',
0|mmstart  |   errno: 'EADDRINUSE',
0|mmstart  |   syscall: 'listen',
0|mmstart  |   address: '0.0.0.0',
0|mmstart  |   port: 8080 }
0|mmstart  |
0|mmstart  |
0|mmstart  | X.Org X Server 1.20.4
0|mmstart  | X Protocol Version 11, Revision 0
0|mmstart  | Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
0|mmstart  | Current Operating System: Linux KitchenPi 4.19.75+ #1270 Tue Sep 24 18:38:54 BST 2019 armv6l
0|mmstart  | Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:FF:A6:3B vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 conso$
0|mmstart  | Build Date: 05 June 2019  12:49:54PM
0|mmstart  | xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
0|mmstart  | Current version of pixman: 0.36.0
0|mmstart  |    Before reporting problems, check http://wiki.x.org
0|mmstart  |    to make sure that you have the latest version.
0|mmstart  | Markers: (--) probed, (**) from config file, (==) default setting,
0|mmstart  |    (++) from command line, (!!) notice, (II) informational,
0|mmstart  |    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 29 09:44:21 2020
0|mmstart  | (==) Using system config directory "/usr/share/X11/xorg.conf.d"
0|mmstart  | /home/pi/chromium_start.sh: 7: /home/pi/chromium_start.sh: chromium-browser: not found
0|mmstart  | xinit: connection to X server lost
0|mmstart  |
0|mmstart  | waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
0|mmstart  |
0|mmstart  | [09:44:38.366] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
0|mmstart  |     at Server.setupListenHandle [as _listen2] (net.js:1279:14)
0|mmstart  |     at listenInCluster (net.js:1327:12)
0|mmstart  |     at doListen (net.js:1460:7)
0|mmstart  |     at process._tickCallback (internal/process/next_tick.js:63:19)
0|mmstart  |
0|mmstart  |
0|mmstart  | Kernel command line: coherent_pool=1M bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:FF:A6:3B v$
0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 29 09:44:55 2020
0|mmstart  |
0|mmstart  |
0|mmstart  | [09:45:20.571] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
0|mmstart  |
0|mmstart  |
0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 29 09:45:29 2020
0|mmstart  |
0|mmstart  |
/home/pi/.pm2/logs/mmstart-out.log last 100 lines:
0|mmstart  | [09:44:04.467] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:04.475] [LOG]    Module helper loaded: calendar
0|mmstart  | [09:44:04.956] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:04.964] [LOG]    Module helper loaded: newsfeed
0|mmstart  | [09:44:04.970] [LOG]    All module helpers loaded.
0|mmstart  | [09:44:04.975] [LOG]    Starting server on port 8080 ...
0|mmstart  | [09:44:05.117] [INFO]   ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
0|mmstart  | [09:44:05.181] [LOG]    Server started ...
0|mmstart  | [09:44:05.191] [LOG]    Connecting socket for: updatenotification
0|mmstart  | [09:44:05.199] [LOG]    Connecting socket for: MMM-DarkSkyForecast
0|mmstart  | [09:44:05.207] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
0|mmstart  | [09:44:05.213] [LOG]    Connecting socket for: mmm-suncalc
0|mmstart  | [09:44:05.219] [LOG]    Starting node_helper for mmm-suncalc:
0|mmstart  | [09:44:05.228] [LOG]    Connecting socket for: calendar
0|mmstart  | [09:44:05.234] [LOG]    Starting node helper for: calendar
0|mmstart  | [09:44:05.243] [LOG]    Connecting socket for: newsfeed
0|mmstart  | [09:44:05.249] [LOG]    Starting module: newsfeed
0|mmstart  | [09:44:05.251] [LOG]    Sockets connected &amp; modules started ...
0|mmstart  | [09:44:05.254] [LOG]
0|mmstart  | Ready to go! Please point your browser to: http://0.0.0.0:8080
0|mmstart  | [09:44:05.328] [LOG]    Whoops! There was an uncaught exception...
0|mmstart  | [09:44:05.388] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|mmstart  | [09:44:05.393] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|mmstart  | [09:44:31.284] [LOG]    Starting MagicMirror: v2.10.1
0|mmstart  | [09:44:31.360] [LOG]    Loading config ...
0|mmstart  | [09:44:31.398] [LOG]    Loading module helpers ...
0|mmstart  | [09:44:31.413] [LOG]    No helper found for module: alert.
0|mmstart  | [09:44:31.758] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:31.768] [LOG]    Module helper loaded: updatenotification
0|mmstart  | [09:44:31.777] [LOG]    No helper found for module: clock.
0|mmstart  | [09:44:34.609] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:34.618] [LOG]    Module helper loaded: MMM-DarkSkyForecast
0|mmstart  | [09:44:34.649] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:34.657] [LOG]    Module helper loaded: mmm-suncalc
0|mmstart  | [09:44:34.663] [LOG]    No helper found for module: calendar_monthly.
0|mmstart  | [09:44:37.531] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:37.541] [LOG]    Module helper loaded: calendar
0|mmstart  | [09:44:37.947] [LOG]    Initializing new module helper ...
0|mmstart  | [09:44:37.955] [LOG]    Module helper loaded: newsfeed
0|mmstart  | [09:44:37.960] [LOG]    All module helpers loaded.
0|mmstart  | [09:44:37.965] [LOG]    Starting server on port 8080 ...
0|mmstart  | [09:44:38.049] [INFO]   ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
0|mmstart  | [09:44:38.114] [LOG]    Server started ...
0|mmstart  | [09:44:38.124] [LOG]    Connecting socket for: updatenotification
0|mmstart  | [09:44:38.134] [LOG]    Connecting socket for: MMM-DarkSkyForecast
0|mmstart  | [09:44:38.143] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
0|mmstart  | [09:44:38.149] [LOG]    Connecting socket for: mmm-suncalc
0|mmstart  | [09:44:38.153] [LOG]    Starting node_helper for mmm-suncalc:
0|mmstart  | [09:44:38.159] [LOG]    Connecting socket for: calendar
0|mmstart  | [09:44:38.167] [LOG]    Starting node helper for: calendar
0|mmstart  | [09:44:38.176] [LOG]    Connecting socket for: newsfeed
0|mmstart  | [09:44:38.184] [LOG]    Starting module: newsfeed
0|mmstart  | [09:44:38.198] [LOG]    Sockets connected &amp; modules started ...
0|mmstart  | [09:44:38.252] [LOG]
0|mmstart  | [09:44:38.356] [LOG]    Whoops! There was an uncaught exception...
0|mmstart  | [09:44:38.418] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|mmstart  | [09:44:38.423] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|mmstart  | [09:45:06.640] [LOG]    Starting MagicMirror: v2.10.1
0|mmstart  | [09:45:06.856] [LOG]    Loading config ...
0|mmstart  | [09:45:06.930] [LOG]    Loading module helpers ...
0|mmstart  | [09:45:06.945] [LOG]    No helper found for module: alert.
0|mmstart  | [09:45:07.656] [LOG]    Initializing new module helper ...
0|mmstart  | [09:45:07.674] [LOG]    Module helper loaded: updatenotification
0|mmstart  | [09:45:07.689] [LOG]    No helper found for module: clock.
0|mmstart  | [09:45:13.291] [LOG]    Initializing new module helper ...
0|mmstart  | [09:45:13.310] [LOG]    Module helper loaded: MMM-DarkSkyForecast
0|mmstart  | [09:45:13.362] [LOG]    Initializing new module helper ...
0|mmstart  | [09:45:13.380] [LOG]    Module helper loaded: mmm-suncalc
0|mmstart  | [09:45:13.389] [LOG]    No helper found for module: calendar_monthly.
0|mmstart  | [09:45:19.079] [LOG]    Initializing new module helper ...
0|mmstart  | [09:45:19.087] [LOG]    Module helper loaded: calendar
0|mmstart  | [09:45:19.960] [LOG]    Initializing new module helper ...
0|mmstart  | [09:45:19.987] [LOG]    Module helper loaded: newsfeed
0|mmstart  | [09:45:20.007] [LOG]    All module helpers loaded.
0|mmstart  | [09:45:20.031] [LOG]    Starting server on port 8080 ...
0|mmstart  | [09:45:20.159] [INFO]   ^[[33mYou're using a full whitelist configuration to allow for all IPs^[[39m
0|mmstart  | [09:45:20.292] [LOG]    Server started ...
0|mmstart  | [09:45:20.303] [LOG]    Connecting socket for: updatenotification
0|mmstart  | [09:45:20.321] [LOG]    Connecting socket for: MMM-DarkSkyForecast
0|mmstart  | [09:45:20.331] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
0|mmstart  | [09:45:20.339] [LOG]    Connecting socket for: mmm-suncalc
0|mmstart  | [09:45:20.343] [LOG]    Starting node_helper for mmm-suncalc:
0|mmstart  | [09:45:20.359] [LOG]    Connecting socket for: calendar
0|mmstart  | [09:45:20.369] [LOG]    Starting node helper for: calendar
0|mmstart  | [09:45:20.378] [LOG]    Connecting socket for: newsfeed
0|mmstart  | [09:45:20.394] [LOG]    Starting module: newsfeed
0|mmstart  | [09:45:20.397] [LOG]    Sockets connected &amp; modules started ...
0|mmstart  | [09:45:20.410] [LOG]
0|mmstart  | [09:45:20.554] [LOG]    Whoops! There was an uncaught exception...
0|mmstart  | [09:45:20.680] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|mmstart  | [09:45:20.687] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|mmstart  | [09:45:53.656] [LOG]    Starting MagicMirror: v2.10.1
0|mmstart  | [09:45:53.864] [LOG]    Loading config ...
0|mmstart  | [09:45:53.987] [LOG]    Loading module helpers ...
0|mmstart  | [09:45:54.028] [LOG]    No helper found for module: alert.
0|mmstart  | [09:45:55.278] [LOG]    Initializing new module helper ...
0|mmstart  | [09:45:55.292] [LOG]    Module helper loaded: updatenotification
0|mmstart  | [09:45:55.321] [LOG]    No helper found for module: clock.
]]></description><link>https://forum.magicmirror.builders/post/71353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71353</guid><dc:creator><![CDATA[kellogg76]]></dc:creator><pubDate>Sun, 29 Mar 2020 12:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Pi Zero fails after being off for a few days on Sun, 29 Mar 2020 06:09:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kellogg76" aria-label="Profile: kellogg76">@<bdi>kellogg76</bdi></a></p>
<p dir="auto">It does however load fine if i remotely connect to the url for my MM on another computer.</p>
<p dir="auto">sounds like its trying to start a second time, and failing… (cause the 1st time is running , maybe in serveronly mode?_</p>
<p dir="auto">use ssh into the pi, and use whatever mechanism to stop  mirror app…<br />
pm2, whatever autostart process…</p>
<p dir="auto">IF you reinstall, I suggest you use my install script…</p>
<p dir="auto">does all the work.</p>
<p dir="auto">what starts this? pm2?   pm2 logs --lines=100 will show the logs</p>
]]></description><link>https://forum.magicmirror.builders/post/71334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/71334</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 29 Mar 2020 06:09:40 GMT</pubDate></item></channel></rss>
